Old Jan 19, 2013, 04:10 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Originally Posted by eflightray View Post
Are you saying that an airplane with a symmetrical airfoil would always pitch up with increased throttle ?, not matter how it is set up ?
That it will react the same as a positive cambered wing with increased throttle ?
Perhaps I have just always got it wrong, that the reason for using a symmetrical section as used by pylon racers, aerobatic model etc, was that they don't noticeably change pitch with throttle.
I wasn't saying anything. I was asking a question. But since you brought it up, yes, a zero camber symmetrical wing will pitch up with increased throttle just like a cambered airfoil. That is with the caveat that the airplane has positive longitudinal stability. If it has neutral longitudinal stability then it will not pitch up with increased throttle. But then, neither will a cambered airfoil with neutral longitudinal stability.
As far as using symmetrical wings on aerobatic models and pylon racers is concerned, aerobatic models use them so they fly basically the same inverted as they do upright. Aerobatic models are also usually set up with neutral longitudinal stability so the pitch angle doesn't change with throttle change. Pylon racers would use thin symmetrical airfoils to reduce drag. A symmetrical airfoil has the best lift to drag ratio. Pitching up with increased throttle is eliminated on pylon racers basically by setting up the relative angle between the wing and the horizontal stabilizer, sometimes called decalage but more properly known as longitudinal dihedral, so that the plane flies level at full throttle. In that case it would tend to pitch down strongly with decreased throttle.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Jan 19, 2013, 06:45 PM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
scirocco is offline Find More Posts by scirocco
Old Jan 19, 2013, 06:50 PM
scirocco is offline
scirocco's Avatar
Joined Feb 2001
Originally Posted by Lnagel View Post
Are you saying then that an airplane that has a wing with a symetrical airfoil would not pitch up with increased throttle?
Larry
No. The wing's pitching moment will not change, but if the tail is carrying a down load eg trimmed for show flight or a fwd CG, or the thrust line is below the wing etc the acft will pitch up if not retrimmed. That's not to say that a well set up model can't exhibit minimal pitch change with power and speed, they clearly can! But just as clearly the Op's model is not set up that way.
Old Jan 19, 2013, 06:54 PM
scirocco is offline
scirocco's Avatar
Joined Feb 2001
I agree with Larry 100%. Good explanation!.
Old Jan 19, 2013, 11:51 PM
derpron is offline
Find More Posts by derpron
darn you, kakka carrot cake.
derpron's Avatar
Australia, WA, Perth
Joined Aug 2012
Originally Posted by rcmaverick View Post
Hmm no..
I can leave the elevator alone at about 50% throttle - the plane flies level - If I now want to speed it up to 80% - 90% it starts going vertical.
Perhaps I need to trim the elevator for a higher throttle position.
i only usally notice this when i have a heavy cambered wing, i guess you should trim in elevator. not really any other way to fix it
derpron is offline Find More Posts by derpron
Old Jan 20, 2013, 03:50 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
+2 on what Larry just posted, exactly what I've been trying to say all along but maybe Larry said it better.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Discussion maintaining altitude with HB FP bp_968 Micro Helis 5 Jun 19, 2007 11:22 AM
Discussion Why can't I maintain a steady altitude hover 5#6 kleaners Coaxial Helicopters 19 May 08, 2007 07:12 PM
Trex doesn't maintain steady altitude at hover Orion_V Mini Helis 28 Aug 21, 2005 06:34 AM
Newbie problems maintaining a constant altitude terryk Micro Helis 8 May 20, 2004 02:42 PM
Help, CP hornet won't maintain altitude... sizam Micro Helis 5 Jul 31, 2003 02:58 AM
