Old Jan 16, 2013, 10:11 PM
rcmaverick is offline
Find More Posts by rcmaverick
rcmaverick's Avatar
Australia, NSW, Sydney
Joined Mar 2012
Maintaining altitude & speed whilst increasing throttle
I wonder what the best way to go about this. Almost all my planes want to climb up on applying throttle (worse upwind). So I give it a bit of down elevator to keep it level. In doing this I lose a bit of speed. I am thinking about mixing the elevator with the throttle but it is such a small correction I am not sure if my DX6i is capable of it.
rcmaverick is offline Find More Posts by rcmaverick
Old Jan 16, 2013, 10:16 PM
btown2 is offline
Find More Posts by btown2
United States, IN, Bloomington
Joined Sep 2012
Planes should climb when you apply power. A properly trimmed plane flies straight and level when at a given airspeed. Increasing the throttle (and thus the airspeed) climbs and decreasing the throttle descends.
Why do you want to change this?
btown2 is offline Find More Posts by btown2
Old Jan 16, 2013, 10:17 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Use your elevator trim to maintain altitude at various throttle settings. Any airplane will gain altitude as airspeed increases and lose it as airspeed decreases.Full scale pilots use elevator trim a lot.
E-Challenged is online now Find More Posts by E-Challenged
Old Jan 16, 2013, 10:59 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Ummm.... Maybe I'm dense, but does this mean that your planes are fastest at 0% throttle?
Piece is online now Find More Posts by Piece
Old Jan 16, 2013, 11:08 PM
rcmaverick's Avatar
Joined Mar 2012
Hmm no..
I can leave the elevator alone at about 50% throttle - the plane flies level - If I now want to speed it up to 80% - 90% it starts going vertical.
Perhaps I need to trim the elevator for a higher throttle position.
Old Jan 16, 2013, 11:13 PM
Piece is online now
Piece's Avatar
Joined Aug 2009
That's normal. A bit of downthrust can be used to help reduce the nose-up tendency. A throttle-to-elevator mix will accomplish a similar effect.
Old Jan 16, 2013, 11:17 PM
caseih is offline
Find More Posts by caseih
Joined May 2005
Yes you will have to do this. This is the way all normal airplanes are flown. You trim for the airspeed you want (using a trim tab, changing the entire hstab, or the elevator), and then use throttle to make the plane sink, rise, or fly level.
caseih is offline Find More Posts by caseih
Old Jan 16, 2013, 11:18 PM
rcmaverick's Avatar
Joined Mar 2012
Planning on a race so need to optimise my "speed settings"
Old Jan 16, 2013, 11:26 PM
Logan4169 is offline
Find More Posts by Logan4169
Joined Nov 2011
The DX6i is capable of mixing that, but I think that you would be better served by understanding what is really happening before you do it.
Logan4169 is offline Find More Posts by Logan4169
Old Jan 17, 2013, 12:28 AM
PyroMan is offline
Find More Posts by PyroMan
PyroMan's Avatar
United States, KY, Paducah
Joined Mar 2011
Instead of mixing I would try a few degrees of down trust. An easy way of adding down thrust is by putting washers behind your motor mount. C4H10 also suggested this above. . .
PyroMan is offline Find More Posts by PyroMan
Old Jan 17, 2013, 12:40 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Personally i'd fine tune the CG before adding downthrust or mixes. Climbing too strongly under power is a often symptom of being nose heavy (CG too far forward). only once you are 100% sure that the CG is in the optimal position should you start adjusting thrust angle.
High wing planes usually need a fair bit of downthrust even once the CG is nailed but on mid and low wing aerobatic types you should be able to get rid of excessive climbing purely by adjusting CG.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 17, 2013, 01:16 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
That is a whole different ball-game to sport flying.
So far I have read standard model sport stuff ... but for racing you should be looking at having plane set-up as neutral as possible at WOT ... that means tailplane angle to main wing ... as little engine downthrust as possible ... all compensations are made in the design and incidence angles of the flying surfaces. We need to minimise induced drag and have power line as straight through model as possible.
A racer will descend when throttle is reduced needing elevator to maintain altitude ... should fly straight and level at WOT.
That's how I set-up my Pylon racing 20's and 40's .....
Nigel
solentlife is offline Find More Posts by solentlife
Old Jan 17, 2013, 01:59 AM
scirocco is offline
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
if it wants to pitch up that badly, it's likely to be all 3 of
a) severely overpowered compared to the design assumptions
b) excessively nose heavy cg
c) substantial longitudinal dihedral (sometimes incorrectly called decalage),where the wing is at a signficantly higher incidence angle than the stab.
If it was designed to be speed stable in a narrow range, like most trainers and low speed gliders you're going to have to fight it to go fast level.
Even fast acft need a lot of forward trim at high speed. A real-world example, P-51 based to boot: Reno racing Mustangs require full forward trim and then some stick force to maintain level at their top speed. When the elevator trim assembly failed on Galloping Ghost in 2011 the aircraft pitched up at 17.3g, blacking out the pilot and the acft crashed into the crowd. An earlier similar incident the pilot escaped - fortunately it pitched straight up at only 10g instead of rolling
scirocco is offline Find More Posts by scirocco
Old Jan 17, 2013, 02:16 AM
solentlife's Avatar
Joined Jan 2010
Sorry (with deep respect for the Reno Pilots) ..... but a model racer can be set-up to be neutral at WOT - I know from my own model racing.
A model can be altered so easily by spacer under wing mount .... cut and reglue tail .... washers in motor mount ... with no requirement to pass an Aeronautical Official Inspection ....
My RM Racer was reasonably successful and was zero trim at WOT ... I'd LOVE to have that bird again ... but passed it to another guy when I left UK.
Nigel
Old Jan 17, 2013, 04:32 AM
rcmaverick's Avatar
Joined Mar 2012
Nigel
Question is where is WOT? My P51 will go bonkers at full throttle and god knows what will happen to the ESC
Discussion maintaining altitude with HB FP bp_968 Micro Helis 5 Jun 19, 2007 11:22 AM
Discussion Why can't I maintain a steady altitude hover 5#6 kleaners Coaxial Helicopters 19 May 08, 2007 07:12 PM
Trex doesn't maintain steady altitude at hover Orion_V Mini Helis 28 Aug 21, 2005 06:34 AM
Newbie problems maintaining a constant altitude terryk Micro Helis 8 May 20, 2004 02:42 PM
Help, CP hornet won't maintain altitude... sizam Micro Helis 5 Jul 31, 2003 02:58 AM
