Old Jan 16, 2013, 10:04 PM
yamskie19 is offline
Find More Posts by yamskie19
new user
Joined Jan 2013
Question
first time creating a quadcopter
sirs.. need help creating a quadcopter.. dont know the circuit i will use and how to program whats inside it.. manila area here.. just need some codes and how will i use it.. or a help creating a quadcopter.. thank you..
yamskie19 is offline Find More Posts by yamskie19
Old Jan 18, 2013, 01:26 AM
speedactyl is offline
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
whats your Flight control board.? this will dictate your setup.
you can see the hobbyshops and supplies section to begin with .then select the type of flight controller you would be using. . from there its all on the manual of the control board used.
then its the size weight and purpose of your quadcopter that will dictate what power systems you would use.
your frame have to be sturdy and stiff . you dont want flexing on your frame that would make your craft unstable.
speedactyl is offline Find More Posts by speedactyl
Old Jan 18, 2013, 07:26 AM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
There are different kinds of boards? What type has an auto leveling feature?
The payload i'm planning is just FPV gear and two 2200mah batteries in parallel.
It has to have legs so i can land in grass and places with garbage scattered about.
Ano magandang starting point? Matagal pa 'ko magiipon so me time pa maghanap, pero kelangan ko ng advice kung ano magandang basic kit.
Hajile is online now Find More Posts by Hajile
Old Jan 20, 2013, 08:24 AM
speedactyl's Avatar
Joined Jun 2012
K this is a Large one base on your function
possible option
Rabbit Flight Controller
BUMBLE BEE Flight control
IDJ NAZA
they should come with Autolevel function possible GPS option
as for your systems
4pcs
25A - 40A ESC
(Note: higher KV smaller Prop)
650KV - 950KV Motors
9 inch - 12 inch Props
1Pcs LOW Voltage Alarm or battery telemetry (important advance warning that you dont run out of power in flight) recommended for all rotary craft flyers
Old Jan 20, 2013, 10:10 AM
Joined Jul 2012
Hmm... so eto baseline ko?
Motors 750kv ($18.56 = 74.24)
http://www.hobbyking.com/hobbyking/s...ter_Motor.html
ESC 40A ($18.33 = 73.32)
http://www.hobbyking.com/hobbyking/s...ontroller.html
Blades ???
No idea how i'm supposed to choose blades
Flight Controller ($65.23)
http://www.hobbyking.com/hobbyking/s...PS_Module.html
Can't find the ones you mentioned so i'll put this in the list for now.
Kulang na lang yung frame. Considering na matindi mag tax ang customs pag nakakita sila ng malaking package, malamang local na lang ako kukuhan ng frame.
Old Jan 21, 2013, 12:28 AM
speedactyl's Avatar
Joined Jun 2012
2 bladed 10x4.5 -11x4.5 inch will do.
I find customs a bit too much for larger package. its the reason large kits are expensive here over the small ones. heard lots of stories on customs .especially if you ship using big major courier
Old Jan 21, 2013, 03:32 AM
Joined Jul 2012
Thanks.
RCV 28: DJI Naza GPS vs KK2, my thoughts (13 min 14 sec)
FPV Quad - MultiWii GPS Return To Home from 600m (2 min 56 sec)
Flight Controller ($29.99) Either this or the $65 multiwii.
http://www.hobbyking.com/hobbyking/s...rol_Board.html
Blades ($3.85)
http://www.hobbyking.com/hobbyking/s...7SF_4_pc_.html
Total: $181.4 (7,646php)
Meron kaya frame kay Wilsons? Mga magkano kaya ang frame na me paa locally?
Old Jan 22, 2013, 02:29 AM
speedactyl's Avatar
Joined Jun 2012
better contact the hobby shops locally to see if they have a frame that suit your size requirements.
Props are CCW and CW a pair each
Old May 16, 2014, 10:55 AM
alexraz is offline
Find More Posts by alexraz
Philippines, NCR, QC
Joined Apr 2014
I have a first quad build question.
I hooked up 4 ESCs (AfroESC 30As) to the KK2.1 board, no motors. Hooked up a 3S. I fiddled with the board settings a bit (set motor config, calibrated acc etc) then I noticed that the ESCs were warm.
Is it normal for the ESCs to warm up like that?
alexraz is offline Find More Posts by alexraz
Old May 16, 2014, 11:26 AM
speedactyl's Avatar
Joined Jun 2012
not normal when there is no load or your not running anything. I still suspect its the frequency of the esc not matching with the flightcontroller. in fact in getting the same problem as you now. any further will have to replace the esc
Old May 16, 2014, 01:10 PM
alexraz is offline
Joined Apr 2014
Isn't there a calibration procedure to sync up the ESCs to the board or is it totally unrelated? I haven't tried it. Still waiting for servo leads for the Rx.
Old May 16, 2014, 02:19 PM
speedactyl's Avatar
Joined Jun 2012
does it have a bec onboard? Or throttle brake function? if so im suspecting those features are consuming power even w/o load
Old May 16, 2014, 04:42 PM
alexraz is offline
Joined Apr 2014
Yes, they do have BECs that can give .5A. I cut the power wires of 3 of the ESCs and only have one of them having all 3 wires connected. Not too sure about the break function, though. These were pre flashed with SimonK firmware and from what I understand were configured for mulitrotors having the low power cut off and break disabled.
It does have a motor stop feature where it's supposed to stop the motor if the props are physically stopped (like by a tree or an idiot). Could not having any motors attached be affecting it since it can't detect the motor state? I'm totaling guessing and grasping at straw.
Old May 16, 2014, 11:41 PM
speedactyl's Avatar
Joined Jun 2012
the brake function stops the prop from feathering when the throttle is cut. useful for gliders or fixwings but not for multirotors. but not all esc has feature of over amp protection like when the prop gets stuck it shouts down completely for safety.
still if the esc comes with instructions i wouldnt mine trying other settings to see if it solves the issue. also make sure your wires are properly connected and proper guage.
Old May 16, 2014, 11:44 PM
speedactyl's Avatar
Joined Jun 2012
lastly will have to check the frequency or motor compatibility.
funny i will still fly on this setup till I can replace my esc. for the mean time
Discussion Long Time RC Flyer, First Time FPV'er. daubut FPV Talk 57 May 01, 2014 12:44 PM
Build Log My first time budget build Quadcopter momofx Multirotor Talk 18 Oct 03, 2012 05:17 PM
Help! Long time viewer, first time poster. Need help with my KKboard Quad... IBeHoey Multirotor Talk 5 Sep 24, 2012 03:11 PM
Question A quadcopter for first-time flying? mun35 Multirotor Talk 9 Mar 09, 2012 07:15 AM
