Old Jan 25, 2013, 02:46 PM
LittleMo is offline
Find More Posts by LittleMo
LittleMo's Avatar
United States, VA
Joined Dec 2006
With normal upright flying I tend to always use the nose as my guide no matter which direction I'm flying.
However, inverted is a mixed bag. In backwards inverted flight I tend to look at the tail with it as the "front", elevator as "normal" and aileron reversed. Then when flying forwards inverted I use the nose as the "front" with aileron normal and elevator reversed. I haven't even gotten to sideways inverted because I can barely do forwards inverted.
I think either my upright or inverted flying visualization is "wrong" in the sense that it's not letting my brain learn every orientation in the same manner. I experimented some with always using the nose when inverted and that really mixed up my brain, mainly because I had already learned using the above technique.
I need to pick a single consistent method but I would like to know what pros use since that will prevent me from learning in a way that will make future progression difficult.
LittleMo is offline Find More Posts by LittleMo
Old Jan 29, 2013, 07:34 PM
warbirdguyn951 is offline
Find More Posts by warbirdguyn951
United States, CA, Corona
Joined Nov 2003
Would anyone be intrested in a inverted training rig?
warbirdguyn951 is offline Find More Posts by warbirdguyn951
Reply With Quote  (Disabled)
Old Jan 30, 2013, 10:07 AM
gravityKills is offline
Find More Posts by gravityKills
like a rock!
gravityKills's Avatar
Finland
Joined Oct 2007
don't think too much, but spend more time with the sim
All the rational thought is just a temporary crutch until the reflexes are developed.
When driving a car you don't think "hmmm I'm about to hit that lantern post on the right so I have to turn the wheel counter-clockwise".
The same goes with helis.
gravityKills is offline Find More Posts by gravityKills
Old Jan 30, 2013, 10:19 AM
LittleMo is offline
LittleMo's Avatar
United States, VA
Joined Dec 2006
Reflexes true, but you're still using visual cues. After your reflexes develop you just don't notice what you're doing. Just like with any physical skill there are often many "wrong" ways to train those reflexes and developing bad habits can limit your ultimate skill level.
Old Jan 30, 2013, 11:00 AM
like a rock!
Finland
Joined Oct 2007
don't worry ... the pieces will fall into place, eventually.
I think learning a wrong technique for actual movements is something different. If that worries you, make sure you're flying pinch, not thumbs
Most people find tail-in inverted harder than nose-in, for example.
Old Jun 23, 2013, 10:18 AM
radhav is offline
Find More Posts by radhav
United States, CA, Folsom
Joined Jun 2011
Since Up is expensive...
Any scratch built plane that flies good inverted ?
radhav is offline Find More Posts by radhav
Discussion How do you eliminate pull to gear in knife edge flight kenh3497 Competition Aerobatics 9 Jul 05, 2013 01:18 PM
Discussion How long of a flight I can do with my plane? motoadve Electric Plane Talk 11 Oct 19, 2012 09:05 PM
Discussion How long do Graupner props last, I have 60 flights and just don't want an accident jasper7821 Multirotor Talk 27 Aug 30, 2012 10:30 AM
Discussion Inverted Flight: How do I start??? spessx Micro Helis 9 Jul 18, 2011 08:19 PM
Discussion How do I flatten out the inverted flat spins in my blenders? The L 3D Flying 11 Mar 08, 2007 10:24 PM
