Old Jan 16, 2013, 08:17 PM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
Best method to make self contained pan and tilt?
I have one channel left on the radio, the Hornet and fy31ap eat up three. I would like a stand alone unit, completely self contained to stabilize a camera. The guardian wont do it without input from a radio.
Just something that I can supply 5 volts to, and keep the camera stabilized.
Anyone else have a solution handy?
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Jan 16, 2013, 08:24 PM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, La Vista
Joined Nov 2011
Here is one solution for pan and tilt. You install the servo titled to the back. When you pan it looks down. One channel solution!
1fullbird is offline Find More Posts by 1fullbird
Old Jan 16, 2013, 08:37 PM
Joined May 2010
That's interesting. Your own home brew?
I would like to find a way stabilize in pitch only (automatically) and then just pan on the channel. This would take some of the jostling out? Or am I over thinking things?
Fullbird, do you have video from that setup?
Old Jan 16, 2013, 08:53 PM
1fullbird's Avatar
Joined Nov 2011
Filmed a few days ago through the lens with a new DVR. Aircraft is made out of EPP, Storm Chaser from Crash Test Hobby. great for the winds I encounter.
Storm Chaser - DVR first test flight (3 min 59 sec)
Old Jan 16, 2013, 09:01 PM
1fullbird's Avatar
Joined Nov 2011
Here's a post where a guy is using something called "sticky hands" to solve the jello. It's a physical solution.
http://www.rcgroups.com/forums/showp...0&postcount=58
Ascended is offline
Find More Posts by Ascended
Ascended's Avatar
Canada, AB, Calgary
Joined May 2012
I believe you can hook a FY-30A up to a camera mount for stabilisation, or at least I've seen it done. There are other camera stabilisation systems out there, however I cannot think of the name of one off the top of my head.
edit: if you're flying with the camera - you really dont want stabilisation on it. If you don't have a good reference on the aircraft in view - if the plane starts to dive or climb the stabilisation might mask this.
Ascended is offline Find More Posts by Ascended
Discussion FPV - Self Contained sykmethodz FPV Talk 9 Jun 18, 2012 04:46 PM
Discussion Best Pan Tilt, Best pan tilt servos??? justind123 FPV Talk 19 Feb 26, 2010 08:42 AM
Discussion Screw third joystick, make entire remote the third joystick for pan and tilt! headhunter23 FPV Talk 18 Mar 01, 2009 07:32 AM
Discussion What is the cheapest self-contained pan and tilt mount? MiKAP Aerial Photography 5 Nov 03, 2008 06:34 AM
Build Log How to make a pan and tilt camera bracket Joel K. Scholz Aerial Photography 4 Aug 18, 2008 12:31 PM
