Old Jan 19, 2013, 04:33 PM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Originally Posted by CurrentDude View Post
It's really sad to read this thread. We're i.e. model flying pilots are supposed to be more techno savvy than a guy on the the street and yet revealing our lack of knowledge.... and allowing tabloid papers to tell us about science... outrageous.
Who's telling anyone anything about anything?
Trisquire is offline Find More Posts by Trisquire
Old Jan 19, 2013, 05:00 PM
FourDollaRacing is offline
Find More Posts by FourDollaRacing
FourDollaRacing's Avatar
United States, OR
Joined Feb 2011
This thread is overblown
All lithium batteries are not created equal.
Voltage to the receiver and servos, or other full-scale systems, is more important than the uninformed bias of any given pilot, A&P, or operator.
If the servos you run in your sailplane, aren't rated for any voltage above 4.8V, then don't use Lithium batteries without a regulator or voltage booster.
Also, NiCads and NiMH batteries are not "ancient technology".
Many gasser ignition engines specifically recommend 4.8 volts to the module and plug.
Adding a voltage regulator is impractical in many modelling applications.
It's entirely possible to use unregulated A123s, Li-Ions, and LiFePO4s for receiver power; but, these packs can display a voltage of over 7.2-7.4V, immediately after charging.
Receiver brownouts or premature servo failure is inevitable.
The long-chain molecules (i.e. polymers) in LiPo batteries are what makes them the most volatile of the Lithium types.
Once again: All lithium batteries are not created equal.
Many combustible fuels are also long-chain molecules (i.e. polymers) so the electric motor vs. internal combustion engine debate is completely unnwarranted.
And, all RC models require receiver batteries, regardless of the main power system. Try flying a nitro RC ship, without any batteries, and see how far you get.
The major reason (pro) for using LiPos in sailplanes is the relatively small size and light weight.
The major reason (con) for not using LiPos in sailplanes is the 3.7V/7.4V nominal voltage.
So, kwitcherbellyachin'&gofly.....
FourDollaRacing is offline Find More Posts by FourDollaRacing
Old Jan 19, 2013, 05:16 PM
Hamburglar is online now
Find More Posts by Hamburglar
Alphabets make great soup
Hamburglar's Avatar
Australia, QLD, Toowoomba
Joined Jul 2008
Whenever I'm sloping I use Chapstick to stop my lipos from burning.
Hamburglar is online now Find More Posts by Hamburglar
Old Jan 19, 2013, 05:18 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Ha Ha Ha!
That was funny and the cute Baby Picture Avitar as well!
PittSpecial is offline Find More Posts by PittSpecial
Old Jan 19, 2013, 05:25 PM
IceRain29 is offline
Find More Posts by IceRain29
IceRain29's Avatar
Canada, ON, Toronto
Joined Jun 2011
lol volt seems nice though
does volt use a giant lipo?
IceRain29 is offline Find More Posts by IceRain29
Old Jan 19, 2013, 05:36 PM
F7X is offline
F7X
Find More Posts by F7X
F7X
Faster!
F7X's Avatar
United States, NV, Sparks
I've seen NiCads and Lead Acids cause damage in business aircraft. We shouldn?'t be so quick to condemn lipos in full scale aircraft. A lot of early turbine? engine blew up and failed in flight. Look at where we are now with Turbofans and Turbo props. Takes time to perfect things.
My two cents.
-Joshua
F7X is offline Find More Posts by F7X
Old Jan 19, 2013, 06:35 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
My two cents.
-Joshua
^ This.
Nicads with thermal runway make a damn big mess of planes to. Have seen it happen, and had to clean up the mess.
jackosmeister is offline Find More Posts by jackosmeister
Old Jan 19, 2013, 06:54 PM
Helter Skelter is offline
Find More Posts by Helter Skelter
"Comin down Fast"
South East Pennsylvania
Joined Jun 2007
Well we heard all of the negative.
I look forward to the TV news report's broadcast of how Boeing and Boeing engineer's solved the problem.
I won't hold my breath while waiting.
Helter Skelter is offline Find More Posts by Helter Skelter
Old Jan 19, 2013, 08:38 PM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
United States, AZ, Tucson
Joined Jun 2010
Originally Posted by the_canuck View Post
Ya, but if they plug the plane in while on the ground you get Japanese power on the plane.
I can see a design engineer designing the charger for balanced 3ph power and then not consider the Japanese who are one of the only countries in the world that ground one corner of a delta 3ph power. It causes all kinds of issues with 3ph power supplies. It's hard to tell what it would do to a battery charger.
Andrew
Dude,
Airplanes aren't plugged into the wall at the hotel! The ground power is the same volts and freqs as the system on the airplane or it won't accept the power. The airplane's battery charger is powered by the airplane's electrical power system, so it's just going to be a dead airplane electrically unless the proper ground power is present.
If there is no ground power, the airplane's own APU is used to power the airplane and the battery charger is still powered by the airplanes electrical system.
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old Jan 19, 2013, 09:25 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Remember the unit was built by the lowest price contractor who bid and won.
So they have literally millions of parts on the plane, all made by the lowest bidders who won the contracts to make the parts. Looks like someone maybe cut one corner too many there.
earlwb is offline Find More Posts by earlwb
Old Jan 19, 2013, 09:46 PM
RAFster is offline
Find More Posts by RAFster
United States, TN, Blountville
Joined Oct 2002
What, you guys didn't forward the thread link to Boeing so they can save all that engineering time to solve this problem, since all the root causes have been exploded here, I mean explored here?
RAFster is offline Find More Posts by RAFster
Old Jan 19, 2013, 10:21 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Theyre already reading this thread to find a solution!!
A10FLYR is offline Find More Posts by A10FLYR
Old Jan 19, 2013, 11:59 PM
the_canuck is offline
Find More Posts by the_canuck
Where's the wind?
the_canuck's Avatar
United States, CO, Denver
Joined Jun 2004
Actually the plane does get plugged in while on the ramp at the gate. Either that or they would have to constantly run the engines to keep the lights on.
Here are the requirements:
http://www.boeing.com/commercial/aer...icle_02_3.html
Looks like 115VAC at 400Hz with 90KVA loads.
I'm just saying that the FAA may have overlooked Japan's weird power grid when approving the power circuits.
After a bit of reading the 787 uses a unique approach to power on the plane. Interesting reading if you care to look.
We all know over charging this type of battery can lead to battery failure so I was thinking of how a circuit could overcharge that would be well tested by the FAA. Well the only thought that came to mind was that it occurred in Japan which may be a factor that the design guys weren't taking into account.
I work as a quality engineer for a company that builds cabin entertainment and communications equipment for Business class aircraft. I get to troubleshoot interesting failures of our equipment on aircraft all the time. The good thing is if our equipment fails, you can't get your email or maybe not going to see the end of that blockbuster that's playing. The main batteries failing and catching fire is a much bigger deal. I used to work on industrial power supplies and Japan's power grid was always a big issue with those products.
Andrew
the_canuck is offline Find More Posts by the_canuck
Old Jan 22, 2013, 06:44 PM
United States, OR
Joined Feb 2011
Andrew
Yep,
Many commercial aircraft use 24VDC systems, as opposed to the standard 12V automotive systems. Not sure about the '87....the link explains the VAC APU systems. Alternating current makes my head spin!
Old Jan 22, 2013, 07:02 PM
bjaffee is online now
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
Originally Posted by ssautter View Post
Yep,
Last article I read said it uses 32V (or 34?).
bjaffee is online now Find More Posts by bjaffee
Data A handy site for those who don't think in metric units. peterlngh Electric Sailplanes 7 Jan 25, 2013 05:33 PM
Whoops! "...Forgive us as we forgive those who trespass against us..." iwannarc Life, The Universe, and Politics 25 Feb 03, 2008 04:09 PM
Alert For Those of You Who Use Lipos in Your Planes Minimole Electric Plane Talk 12 Dec 19, 2005 03:09 PM
Those who courted Saddam while he gassed Iranians are now waging war against him Hammer Head Life, The Universe, and Politics 39 Mar 26, 2003 03:57 AM
