Old Jan 18, 2013, 12:35 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Originally Posted by oggamesta View Post
The advantages of a LiPo system are huge.
Such as?
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Jan 18, 2013, 12:39 AM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Originally Posted by Mark Wood View Post
Such as?
They helped create a cottage industry for heavy duty fireproof bags with fancy Velcro closures?
Steve
surfimp is offline Find More Posts by surfimp
Last edited by surfimp; Jan 18, 2013 at 12:39 AM. Reason: Trolling MW... it just never gets old
Old Jan 18, 2013, 04:27 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Lol
BTW, the move to HV (high voltage) components such as servos and receivers is in response to a need to run unregulated LiFe packs. As they have a "native" voltage that is just slightly above nickel cells, they can be run as receiver packs where the components are "safe for higher voltages" without the addition of a voltage regulator. Apart from concerns about their use in fire-prone geographic areas, LiPo cells are too high in voltage for such usage, and need to be regulated when used as receiver packs.
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Jan 18, 2013, 06:00 AM
Phil.Taylor is online now
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
Just seen on ebay:
"787 battery packs - lightly used - ideal for barbeques"
Phil.Taylor is online now Find More Posts by Phil.Taylor
Old Jan 18, 2013, 06:07 AM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
Steve
Ok. Besides that.
mw
Old Jan 18, 2013, 11:22 AM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Originally Posted by Woodstock 1 View Post
Lol
Chris
LiFe is rated at 6.6v
Looks to me like the goal is unregulated 2S LiPo 7.4v...at least with Futaba and Hitec.
1000MPH is offline Find More Posts by 1000MPH
Old Jan 18, 2013, 03:43 PM
geoffers0_0 is offline
Find More Posts by geoffers0_0
I'd rather be.....
geoffers0_0's Avatar
Bristol, UK
Joined Jun 2008
Originally Posted by chris s View Post
Boeing has Lithium iron batteries ( LiFe) in the B787.C
Not sure if that's actually correct - checking on PPRUNE I found this from >thalesgroup< who supply some of the electronics for the 787
Boeing has selected leading electrical power conversion technology from Thales ... Boeing chose Thalesís lithium-ion battery technology, which provides higher reliability and improved maintenance compared to traditional solutions, for the B787 low-voltage DC emergency back-up subsystem. This is a first in civil aviation...
... and will it be the last?
geoffers0_0 is offline Find More Posts by geoffers0_0
Old Jan 19, 2013, 12:54 AM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
You are right about the battery Steve, its a Lithium-ion-polymer. Don't know what the abbreviation for that is.
LiPo is a proper abbreviation.
Lithium Ion (Li-Ion) refers to the method in which they produce current, by the transfer of ions from the negative electrode, to the positive during discharge. Li-Ion does not refer to the chemistry which is used. Li-Po, LiFe etc. indicates chemistry, or the "type" of Li-Ion cell , they are still Li-Ion. There are several hundred Li-Ion chemistries, most are obscure and arent used in anything other than experimentation, or just too expensive to make, or no longer used or experimented with at all for some reason.
KKUSA is offline Find More Posts by KKUSA
Old Jan 19, 2013, 01:44 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by glasairIII View Post
Bottom line, Boeing will find the cause. And, I'd hazard a guess that they will temporarily go back to the tried and true nickel-cadmium. I'd also hazard a guess they went to the new technology for the same reason we do. Weight and capacity.
Boeing must find the cause and it must find a solution to avoid similar cases in future.
Going back to NiCd won't likely be possible, not only because of diminishing sources, but also because there is not enough space for batteries 4 times the size. The Boeing 787 is designed to use electric power, rather than bleed air:
http://www.boeing.com/commercial/aer...icle_04_3.html
http://www.boeing.com/commercial/aer...icle_02_2.html
Battery specs: http://www.gsyuasa-lp.com/aviation-lithium-ion-markets
Those were probably the best option back in 2005. Technology made massive steps since then, but it is not that simple to get batteries certified for use in aviation.
JŁrgen
P.S.: I am bit puzzled to find this discussion in the glider subforum.
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 19, 2013, 03:04 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by Twyl View Post
Nor your Chevy Volt
That said, supposedly size does matter and a larger lipo will be more difficult to keep stable.
-Jonathan
I wonder how many cars have been incinerated due to gas (petrol) fires? ... an answer to the nearest 100,000 will do
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 19, 2013, 03:22 AM
Joined Dec 2005
Ford Pinto anyone?
Old Jan 19, 2013, 06:00 AM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Originally Posted by snakecrew View Post
apparently 787's don't fair well either
Hey Snakecrew,
It seems like you posted this thread right after I did.
Here is my thread:
http://www.rcgroups.com/forums/showthread.php?t=1810901
Additionally, we really can not JUMP into any conclusions until the experts figure out what exactly happened to this Avionics box. You really can not compare it with any of our RC Hobby designs, setups and most especially Sail Plane setups.
Allow those who are investigating do their job.
PittSpecial is online now Find More Posts by PittSpecial
Old Jan 19, 2013, 08:24 AM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
I'd be less concerned about Boeing's lithiums, and more concerned with all the lithium equipped wireless devices that passengers bring on board. Boeing will find a solution. I can't say the same for Joe Schmoe who just dropped his smartphone before coming on board.
Trisquire is offline Find More Posts by Trisquire
Old Jan 19, 2013, 08:46 AM
Ken Lilja is online now
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
In an early electric plane, I had a ni-cad melt down. Ni-cad batteries were used because they had lower internal resistance than lead acid. Aircraft ni-cads requires a temperature monitoring gauge on the instrument panel to prevent thermal runaway. The maintenance required is very extensive also.
I do not know how many Volt cars have had fires in the wild. When crash testing one did burn up. 3 weeks after the test. They did not disconnect the battery as required by the manufacture. All other cars get the gas drained and battery disconnected right after the test. And remember that electrical fires destroy a lot of cars every year.
LiP batteries burn. So does gas and kerosene. About the only thing that does not ignite easily is glow fuel.
For sailplnes we can have a LiPo fire or a fire from a shorted, red hot wire, from any type of battery.
Ken
Ken Lilja is online now Find More Posts by Ken Lilja
Old Jan 19, 2013, 08:49 AM
onemetre is offline
Find More Posts by onemetre
USA, TX, Mansfield
Joined Aug 2004
Originally Posted by bjaffee View Post
Is anyone running LiFe packs in gliders? I've heard they don't require a regulator, and they are not as prone to fire as LiPos.
I'm only running LiFe in my sailplanes.
onemetre is offline Find More Posts by onemetre
Data A handy site for those who don't think in metric units. peterlngh Electric Sailplanes 7 Jan 25, 2013 05:33 PM
Whoops! "...Forgive us as we forgive those who trespass against us..." iwannarc Life, The Universe, and Politics 25 Feb 03, 2008 04:09 PM
Alert For Those of You Who Use Lipos in Your Planes Minimole Electric Plane Talk 12 Dec 19, 2005 03:09 PM
Those who courted Saddam while he gassed Iranians are now waging war against him Hammer Head Life, The Universe, and Politics 39 Mar 26, 2003 03:57 AM
