Old Jan 16, 2013, 07:16 PM
mccubed27388 is offline
Find More Posts by mccubed27388
Joined Jan 2013
Help!
Spektrum dx7s Question
I was curious so know if i can run my dx7s with my simulator, battery unplugged but the charger plugged in? I'm just curious to see if this can cause damage to the Tx long-term, as having to recharge the batter for use with the simulator seems abit like a waste of time.
Thank you!
mccubed27388 is offline Find More Posts by mccubed27388
Old Jan 16, 2013, 09:35 PM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Charging stops when radio on.
If you use your flight tx for sim charging batt is something you have to deal with.
freechip is offline Find More Posts by freechip
Old Jan 16, 2013, 09:38 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Don't do it!
Never try to run ANY battery operated device directly off the charger without the battery. The device should be designed to ensure it won't work, but if it does connect it is highly likely to damage the equipment. The charger is unregulated and may provide much higher voltage than the battery. If you are lucky it just won't work.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 16, 2013, 10:05 PM
Joined Jan 2013
Originally Posted by Daedalus66 View Post
Don't do it!
Thank you, you probably saved my new time murderer. (And i've killed ALOT of time with this so far. Like, 3 hours of just messing around.)
Old Jan 16, 2013, 10:22 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Keep in mind that running in trainer/simulator mode takes much less power than when transmitting, so should allow the transmitter to run for two or here times as long. You shouldn't have to charge often.
Old Jan 17, 2013, 12:28 AM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
With my JR XP9303 and previous JR transmitters, I was advised to connect a 1/8" audio jack (from Radio Shack) to the Trainer Port. This would power up the display but prevent the Tx from transmitting (I was on 72Mhz at the time). This also worked well when I was spending a great deal of time learning the programming. The Tx used much less power when either the audio jack or the Trainer Cord was connected to the Trainer Port (50ma vs 200ma).
I have not tried this with my DX8, but I believe it will work the same.
Buschbarber is offline Find More Posts by Buschbarber
Old Jan 17, 2013, 03:21 AM
FrankS is offline
Find More Posts by FrankS
United Kingdom, Glos
Joined Feb 2009
That's exactly how it works with Pheonix and the Dx6i.
FrankS is offline Find More Posts by FrankS
Old Jan 17, 2013, 08:45 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
That's how it works on virtually all transmitters that use the JR-type trainer system, including Spektrum. When used as a buddy box, the transmitter switch is OFF and plugging in the cable turns on only the encoder. Note that some transmitters work with either stereo or mono cable, but others require mono. That's why proper JR/Spektrum trainer cables are mono.
Old Jan 17, 2013, 09:04 AM
Joined Apr 2004
With the Aerofly Pro sim, the 8103 used a Mono jack and the 9303 used a Stereo jack.
Discussion Broken DX7? Super poor range with Spektrum DX7 karoliinasalmin Radios 23 Jul 04, 2014 06:04 PM
Question Spektrum DX7 lipo charging question Starving Bushman Radios 1 Dec 06, 2012 06:46 PM
Question Spektrum DX7 Dual Rates question davidjrojas Radios 4 Jul 17, 2012 10:56 AM
Discussion Question about Spektrum DX7s tranmitter battery charging Riodiler1 Electric Plane Talk 7 Mar 04, 2012 09:09 AM
For Sale Trade Spektrum Aero DX7 for a Spektrum Heli DX7 chandlert Aircraft - General - Radio Equipment (FS/W) 7 Apr 11, 2011 05:42 PM
