This thread is privately moderated by PittSpecial, who may elect to delete unwanted replies.
Old Jan 16, 2013, 07:46 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Boeing 787 dreamliner
If you all have not heard, the Federal Aviation Administration (FAA) has grounded all 787 Dreamliner Aircraft until full investigation has been performed as to the reason for this!
More at:
http://www.cnn.com/2013/01/16/travel...html?hpt=hp_t1
PittSpecial is offline Find More Posts by PittSpecial
Old Jan 16, 2013, 08:17 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Another bad rap for Lithium batteries. They were ragging on them on NPR - and I am like how many passengers CARRIED THOSE ON to the airplane.
Sigh....
Old Jan 16, 2013, 08:32 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Agreed, Cells phones, Laptops, Notebooks, and lets not forget Tablets!!!
However, the box in the picture is an Avionics Box that should be tested and tested again. There should be no reason for batteries to go out of control in a Aircraft.
Old Jan 16, 2013, 09:04 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Any electrical component can fail. Boeing was required by the FAA to show since they were using Li batteries that the device could contain the fire. Looks like it worked.
Old Jan 16, 2013, 09:09 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Oh, yes certainly, could imagine if those batteries were not contained, wow!
It would interesting what they find.
Old Jan 17, 2013, 08:18 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
Lithium Batteries don't like to be charged cold - i.e. below 0C. I wonder if this had some sort of heater on board, in between the cells to keep them warm?
After all it gets mighty chilly up at altitude...
Si.
SimonChambers is offline Find More Posts by SimonChambers
Old Jan 17, 2013, 09:13 AM
pda4you is offline
pda4you's Avatar
Joined May 2002
Simon - these are pretty sharp folks - I am confident they know the in's and out's of the battery technology. More important that charging they are really functionless at sub zero temps in putting out usable voltage. So I doubt very highly that temp is an issue - well under temp that is.
Old Jan 17, 2013, 09:32 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Isn't this whole plane outsourced?
I believe these particular batteries come from a Japanese supplier.
Granted that Bowing designed them and it is Boeing that is on the hook for any faults with them.
Watching their stock closely.
1320fastback is offline Find More Posts by 1320fastback
Old Jan 17, 2013, 09:42 AM
Radio? Screwdriver!
Joined Aug 2011
Well I was thinking that they may have some sort of electrical heater to keep the cells warm. If that malfunctioned and thermal overload switches didn't catch it, then possibly cause a problem?
Or some sort of heat outlet was aimed at it? Or maybe an internal cell failure.
No doubt these packs were extensively tested, especially as Li-Ion is a new technology for Aviation with known safety risks. Also the cell manufacturers won't hesitate rejecting a cell that doesn't look 100%. However there obviously something that has failed and/or been overlooked when the packs were engineered.
The cells are made by GS Yuasa according to the NTSB report.
Si.
Old Feb 18, 2013, 10:19 AM
302 Z28 is offline
Find More Posts by 302 Z28
302 Z28's Avatar
United States, TX
Joined May 2009
There is a short article here on the AvWeb site. And here also.
Vince
302 Z28 is offline Find More Posts by 302 Z28
Old Feb 18, 2013, 10:45 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Check it out!
http://www.nbcnews.com/business/micr...says-1C8340259
Old Mar 02, 2013, 09:08 PM
helipilot23 is offline
Find More Posts by helipilot23
Unregistered User
helipilot23's Avatar
Joined Oct 2012
That's what happens when u buy ur batteries from hobbyking.....
helipilot23 is offline Find More Posts by helipilot23
Discussion 787 Dreamliner by Boeing 8kasl Giant Electric Planes 1 Aug 28, 2015 12:27 AM
Question What happened to the Boeing Dreamliner ? cyclops2 Chit Chat 1 Jan 08, 2013 01:46 PM
Build Log Boeing 787 and Airbus A350 Build ****in planning Phases...** Keenan smith RC Airliners (Commercial, Cargo, Troop Carrier) 48 Jul 03, 2012 01:02 PM
Discussion Boeing 787 Wing Design JRuggiero Modeling Science 5 Apr 22, 2012 07:24 PM
Build Log Boeing 787 Dreamliner viper1990 Foamies (Scratchbuilt) 10 Dec 16, 2009 11:53 AM
