Old Jan 16, 2013, 06:44 PM
miltonboy is offline
Find More Posts by miltonboy
miltonboy's Avatar
United States, TN, Knoxville
Joined Dec 2007
Build Log
Micko's 109 G2
Well, I've finally got all of the stuff together to start my build of D-Rock's 109. I'm going to be building it as a G2 in the scheme of Gunther Rall's "Black 13". The build might move a bit slow since I usually only have time on the weekends to build. I'm a high school social studies teacher in East TN, so I may get a few snow day's here and there to keep of the progress.
Today I punched out the parts and built the stab and elevators. Shout out to Manzano lazer on cutting the parts really nicely, and to D-Rock for such a neat, easy building design.
The materials I am using will be a Rimfire 1.20, Ice 100 esc, Genz Ace 6s lipo, Hitec HS81 servos on the ailerons and flaps, and 485HBs for the rudder and elevators, and E-Flight 85 degree electric retracts for the legs.
I have to experiment with these pictures, getting them from my i phone to my PC laptop in the right size is stumping me a bit. Anyone out there know an easy way to do it?
miltonboy is offline Find More Posts by miltonboy
Old Jan 20, 2013, 09:03 AM
D-Rock is offline
Find More Posts by D-Rock
D-Rock's Avatar
Phoenix, AZ
MB, off to a great start and looking good. Will be following your progress- subscribed
D-Rock
D-Rock is offline Find More Posts by D-Rock
Old Jan 20, 2013, 02:40 PM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
Easiest way to get the right size is to change the resolution in your phone before you take the pictures. 640x480 or 800x600 are what I usually use.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Jan 21, 2013, 08:33 AM
miltonboy's Avatar
Joined Dec 2007
Last night I got the parts cut out and organized for the fusalage. The "T" braces are built the plans are laid and the parts organized. Hopefully I'll get to slap some glue to them today. I put my Pat Tritle Tiger Moth on top of the fuse plan for size reference. I built the Tiggie in prep for this model. It's really given me the bug for stick built models. The old addage "bigger flies better" might need to be changed to lower wing loading flies better!
Old Jan 21, 2013, 03:49 PM
miltonboy's Avatar
Joined Dec 2007
This is only about 30 minutes worth of work once all of the parts were organized. Unfortunately I came to a stop for the day when I realized I didn't have any 3/8" square bass wood stock on hand. I'll have to pick some up this week along with the 1/16" strips to make the laminations for the rudder and wingtips. Its getting more and more exciting as this one takes shape!
Old Feb 03, 2013, 08:27 PM
BuildItWright is offline
Find More Posts by BuildItWright
BuildItWright's Avatar
Melbourne, Australia
Joined Jul 2008
Subscribed,
Looking good so far!
BIW.
BuildItWright is offline Find More Posts by BuildItWright
Old Feb 04, 2013, 07:31 AM
miltonboy's Avatar
Joined Dec 2007
I got a little more progress done last night on the fuse. I'll post pics later this evening. I'm enjoying the build so far.
Old Feb 04, 2013, 02:30 PM
miltonboy's Avatar
Joined Dec 2007
Here are the pictures of the formers in place. Next, possibly tonight, I'll mount the structure on the T-braces and get it lined up to add the stringers.
BIW. My thoughts on the firewall are to trace F-1 onto a piece of ply and re-cut it to front mount my engine on. I would put F-2 where it is supposed to go, and then build a bass wood truss structure around the motor between the two formers for added strength. In your opinion, would this help give the added strength I need to handle some of the torque and twisting?
Old Feb 04, 2013, 04:37 PM
Joined Jul 2008
That sounds like a good plan Miltonboy, I would recommend a double lamination of 3mm ply or some good quality 6.5mm ply for the motor firewall.
I found the ply supplied with my 109 a bit soft thus allowing the motor vibrate too much.
BIW.
Old Feb 04, 2013, 11:58 PM
D-Rock is offline
D-Rock's Avatar
Phoenix, AZ
MB, that mod for the motor should work well, just keep in mind the distance of the prop adapter back-plate and the location of the back-plate for the spinner. You want to be sure the gap is not too large. Another suggestion, if you are intending to strengthen the tail where the horizontal meets the fuse (as BIW did), you can add lite ply on either side of the rear portion of K-3 and notch them into the rear 2 most formers.
Looking good and neat seeing her shape up.
D-Rock
Old Feb 06, 2013, 10:00 AM
miltonboy's Avatar
Joined Dec 2007
D-Rock and BIW,
Thanks for the advice. I'm going to implement both of those ideas. I'm going to use my Father-In-Law's hobby size band saw this weekend and cut some parts for these locations. I'm planning to cover with Sig Koverall which I'm thinking won't be too heavy, but should give a really nice lasting finish for the scheme I've chosen.
Do you guys see any reason that I can't cover the individual parts before I assemble them? I think that the tail planes would be easier covered and then assembled. Of course I would cut away covering from where wood would be glued together. Any thoughts?
Old Feb 06, 2013, 10:09 AM
D-Rock is offline
D-Rock's Avatar
Phoenix, AZ
Covering individually should be fine, I can't recall if I did the same thing . The airframe will allow for multiple different covering materials, Koverall should work well.
D-Rock
Old Feb 18, 2013, 08:02 PM
miltonboy's Avatar
Joined Dec 2007
I was finally able to make more progress on the 109. I made the modifications outlined by D-Rock and BIW, and think they will work out great. Since the job of fabricating pieces and mounting on the T-Braces is finished, I should make quicker progress with the stringers. I really worked hard to make the fuse laser straight on the center thrust line, and pinned the mess out of the thing. At this point I think it is ready to take on a hurricane, no pun intended...... well, maybe a little intended!
Old Feb 18, 2013, 10:36 PM
D-Rock is offline
D-Rock's Avatar
Phoenix, AZ
Nice work on the new firewall and the keel update. Now that you have the T-braces in place the next part moves quickly. When I built the prototype, I spliced stiffer wood with softer wood for the stringers- the stiffer towards the nose. You may need to wet the stiffer side to pull into the shape of the firewall.
D-Rock
Old Mar 03, 2013, 04:14 PM
miltonboy's Avatar
Joined Dec 2007
Made a little more progress on the Me 109 this weekend. I worked out the motor installation and got started on the stringers. I added a piece of light ply to the rear of the main firewall to adjust the space between the firewall ring and spinner back-plate. Tonight I plan on building the trusses between the firewall and F-2.
Build Log Building Derek Micko's 80" Bf 109 G-6 BuildItWright Scale Kit/Scratch Built 320 Dec 07, 2014 09:37 AM
Wanted FMS ZERo's......109's....Parts....Whole.....Any... eggsplurt Aircraft - Electric - Airplanes (FS/W) 0 Nov 22, 2012 09:28 AM
Build Log Micko Scale Hawker Hurricane wallis_100 Scale Kit/Scratch Built 210 Sep 27, 2012 01:49 AM
Discussion S.O.S. from PT-109 SeaJay Dock Talk 17 Jul 19, 2012 08:58 AM
Build Log bf-109 G2 (Again) shotibf109 Scale Kit/Scratch Built 67 Dec 07, 2010 05:07 PM
