THIS FIRST PAGE WILL HAVE ALL RECENT UPDATES:
This is my interpretation of Flite Test H quad plan.
I do not care much for finishing details, but I care for safety and functionality remember that this is a prototype. If it gets some day to a stage were I can say 'its done and finished', then I will build a new one all nice and polished.
Objectives:
A frame that protects and hides electronics
Stable platform for GoPro image capture (in progress)
Dirty CHEAP
Easy to build and repair
Solution:
A Quad frame that only uses three (3) main parts (2 arms and 1 body)
Body is made from PVC pipe from a rain water drainage system, with drilled holes to lighten and also strengthened to torsion by adding firewalls and cross beam diagonals.
v2.0 Arms are made from aluminium square tube and screwed to PVC.
v2.0 Landing gear with servoless system
Advantages:
v2.0 Aluminium arms are separated from fuselage with rubber vibration dampeners
Camera mount is isolated with rubber vibration dampeners
Electronics are protected
Easy to include a retractable landing gear
Frame weight is less than 300g (around 275g) without landing gear and camera gimbal
Cheap
Easy (to DIY you must have a drill bit to make holes of large diameter in PVC)
Have I said CHEAP before?
Price:
v2.0 in aluminium, PVC tube, firewalls, zip ties, 3mm screws and locknuts... I did no spend more than 8 EUR
Flying:
Super stable
Very good optical recognition of position in air
I was used to fly a Tricopter (RCExplorer Style) and this model is even more stable and has more power to handle almost 1,7kg of total weight with equipment, camera, batterry, FPV, etc
Donations and ideas for v2.0:
I'm thinking on v3.0 and I'm on one extremely low budget if anyone wants to donate-me the following materials I would thank and appreciate it:
- 1 camera gimbal for GoPro
- good quality rubber dampener to isolate the arms vibrations from fuselage, but keeping the arms solid not loosing torsion movements from motors.
- one CNC cuted box fuselage like mine with 2 internal and 2 top firewalls 70x70x470mm this would certainly pimp my ride
- thermal retractable material to cover the fuselage (I will try first with tape to see if wind force becomes an issue with such a large fuselage closed)
Everything else you want to know go ahead and ask me.
