St. Mary, Maryland, United States
Joined Dec 1996
I've used HS-55's on the ailerons of lots of 80-100 mph 3-3.5 pound EDF's with no problems. I do use an HS-81, HS-85 or JR - 331/341/351 on the elevator though.
On the other hand, if your ailerons are likely to hit the ground on landing (low wing) then I'd go with an HS-81 or HS-85. And if the plane is heavier than 4 pounds make em metal geared. I had HS-81's on the ailerons of my 6.75 pound Banshee. Both plastic geared servo's stripped on different landings so they got swapped out for HS-85MG's |
HS-85 MG on the bigger stuff, JR 9g or HS-55's servos on the smaller stuff. Never had a problem with any Hitec servo in 4 years.
Latest blog entry: BAe Hawk 90mm EDF
servo load spreadsheet
If anyone's interested, I did a spreadsheet to calculate servo loads, based on an article that ran in RCM about two years ago.
| Thread Tools | |
| Discussion What size 3S pack are you using? | BowerR64 | Micro Helis | 25 | Jun 03, 2007 05:31 PM |
| Discussion GW e3d lipo/ what pack are you using? | txfly | 3D Flying | 0 | Sep 04, 2006 09:35 PM |
| Question What kind of batteries are you using? | KevinW | Hand Launch | 8 | May 22, 2002 02:06 PM |
| What digital scale are you using? | sportwin | Indoor and Micro Models | 28 | May 04, 2002 05:54 AM |
| What gauge wire are you using? | CheeseWing | Parkflyers | 1 | Sep 10, 2001 02:52 PM |
