Old Dec 21, 2003, 08:27 PM
isaac-bees is offline
Find More Posts by isaac-bees
isaac-bees's Avatar
Newport, WA US
Joined Aug 2000
Why can't I go vertical with my mIFO?
I have been flying my mini IFO for a while and have always thought I couldn't go vertical because of my motor or battery. But now I have a newish motor and a great battery and it still won't perform like I would wish.
What I have.
GWS A drive motor with a 1080 prop.
Kokam 1200 2 cell pack.
It is a pretty light plane I am not sure exactly what its auw is. I'll have to weigh it soon.
Any suggestions?
Isaac.S
I would prefer to avoid 3 cells b/c then I have to build a charger
isaac-bees is offline Find More Posts by isaac-bees
Old Dec 21, 2003, 08:34 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Why not try to use 2x340mah cells - that will save some weight. It would be nice to know the weight so someone who knows what kind of thrust can be had from GWS drives can give advice.
Michael
epilot is offline Find More Posts by epilot
Old Dec 21, 2003, 08:43 PM
Matthew Cotten is offline
Find More Posts by Matthew Cotten
Joined Oct 2003
This doesn't give your prop size but,will give an idea of what happening.
IPS-DX-A (M0.3) 82 / 14 = 5.86
PROPELLER Volts (v) Amps (A) Thrust (g) Power (w) Efficiency (g/w)
EP9070 6.0 1.26 86 7.56 11.38
7.2 1.65 110 11.88 9.26
EP1047 6.0 1.28 101 7.68 13.15
7.2 1.67 129 12.02 10.73
Matthew Cotten is offline Find More Posts by Matthew Cotten
Old Dec 21, 2003, 08:49 PM
Joined Oct 2003
Or don't even bother with it and trade in your small block for a big block with aluminum heads
W/IPSD-RXC-A
CN12-124X2 (M0.3) 82T / 14T = 5.9
PROPELLER Volts (v) Amps (A) Thrust (g/oz) Power (w) Efficiency (g/w)
EP1080 6.0 2.7 151 5.29 16.20 9.3209
7.2 3.4 195 6.83 24.48 7.9656
8.4 4.3 244 8.54 36.12 6.7552
EP1147 6.0 2.6 172 6.02 15.6 11.0256
7.2 3.3 226 7.91 23.76 9.5117
8.4 4.2 286 10.01 35.28 8.1065
EP1180 6.0 3.1 180 6.30 18.6 9.6774
7.2 4.0 231 8.09 28.8 8.0208
Old Dec 21, 2003, 08:51 PM
Joined Oct 2003
http://www.aeromicro.com/Catalog/gws...v__1162837.htm
Old Dec 21, 2003, 08:57 PM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
Try a 10x4.7 a finer pitch will be better for hover .
Stewart
clipclop is offline Find More Posts by clipclop
Old Dec 21, 2003, 09:06 PM
Marked is offline
Find More Posts by Marked
Marked's Avatar
United States, FL, Titusville
Joined Jan 2001
I run the following and can hover.
IPS DXa 10x4.7 prop cirrus CS-10s GWS rx 4 CH....FMA ESC 5A...a 750 mah lithium 2s 1p...weight.....4.9oz
A savings in .4 oz(I was running a heavier battery) made all the difference in this plane.
I also found it will fly a little better WITH the spinner.Air flow or something.....not C/G,,Mark
Marked is offline Find More Posts by Marked
Old Dec 21, 2003, 09:26 PM
epilot is offline
Joined Nov 2000
Good point guys, the 10X8 prop could very well be stalled when static and would not be suitable for vertical manouvering.
Michael
Old Dec 22, 2003, 02:01 PM
isaac-bees's Avatar
Newport, WA US
Joined Aug 2000
I weighed it this morning and it came in at 5.5 oz. Seems when I tried the 10x47 I had to be on full throttle to motor around nicely without descending.
I suppose I could go to a dual drive but isn't there another option?
Isaac.S
Old Dec 22, 2003, 07:33 PM
MKH is offline
MKH
Find More Posts by MKH
MKH
Ohio
Joined Mar 2000
If you use the stock GWS A drive, as you are, it all comes down to weight. 5.5 ounces is not bad for a Mini, but the A drive will only pull so much weight straight up. You can either use smaller, lighter cells, like the 340's, or add power thru a dual IPS or small brushless. The lighter battery will be the easiest way to achieve vertical, but remember, it will still be a slow vertical. You can, of course, do both, and use smaller cells and a brushless motor, like the Nippy 0508, and you'll get good vertical, but you'll have to throw some money into the system to get this. Even the tiny DC1524 coreless will take a Mini straight up, but we're talking under 4 ounces here. It really does come down to weight, at least with the smaller powersystems.
MKH
MKH is offline Find More Posts by MKH
Old Dec 22, 2003, 10:23 PM
Salto is offline
Find More Posts by Salto
Australia, NSW, Sydney
Joined Feb 2003
For hovering I use either 3 cells, or an E or an F gearbox on 2 cells with a 13" prop. For my faster planes I use the lower A or B ratios with 9070 or 1047 props.
I've also done my own static thrust tests and confirmed that the GWS published thrust/power figures are roughly in the ball park, although it appears that they use a constant voltage supply to get their figures which does not really model real life conditions where battery voltage sag can be significant.
Graham.
Salto is offline Find More Posts by Salto
Old Dec 22, 2003, 11:11 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
If you want to stay with the lightweight IPS, I'd take DeanInMilwauke's advice, and use an IPS-C with a 1047 and 3 cells. Personally, I'd try the ET250's, or the K340's. Seems like there should be a cell between these, since the 340's are almost as heavy as the ET700's...
Personally, I gave up and went to a Wattage 180 in an EPS-C box with an 1147 prop on 2xET700. It's 1/2oz heavier than the IPS, but lots more speed and thrust. A 1047 gives more speed, and just enough thrust to climb vertically (if you can hold it). AN M-100 in the same box is just about the same.
Gene Bond is offline Find More Posts by Gene Bond
Old Dec 23, 2003, 12:01 AM
Joined Oct 2003
The 500ma irate cell from CBP is the same weight as the 340ma at 10 grams each and can handle 10C contiuous and 15C in short bursts.Probably the best IFO battery out there.Matt
Old Dec 23, 2003, 10:14 PM
isaac-bees's Avatar
Newport, WA US
Joined Aug 2000
Appreciate your advice guys. I am thinking of the dual IPS since I am running 1200 HD kokams. They sure are more money though. I would love to go to the brushless but they cost too much for a college student or at least for this one. I saw a friend fly a mini max(?the purple small ones.) motor today. It was IMPRESSIVE! full vertical on dual 3cell 1300!
My only problem to going with 3 cells is a charger. Any ideas for that problem?
Isaac.S
Old Dec 24, 2003, 08:19 PM
Nowell York is offline
Find More Posts by Nowell York
Nowell York's Avatar
Columbus, Ohio
Joined Nov 2001
It's all about thrust to WEIGHT
Use an A drive, 10x4.7 with 2s 340s.
My mini with rudder weighs in at about 4.1 ounces and will climb vertically like a slow elevator. If you build light and more importantly select light componets you'll be fine on 2 cells.
Nowell York is offline Find More Posts by Nowell York
Question Why can't I see anything in my "sent PM's" folder? birdlives1955 Site Suggestions / Complaints 3 Aug 08, 2007 03:39 PM
Discussion Why can't I get comfortable w/ my Heli? sobamaflyer Micro Helis 5 Dec 07, 2006 07:05 PM
why can't i use CC35 with 4s-5s?? gapth8888 Mini Helis 3 Feb 15, 2005 12:34 AM
Why can't I parallel my car battery with another? Quacker Batteries and Chargers 16 Oct 17, 2004 07:40 AM
Why can't I pull Directories & Data off my Burned CD-R's? mrebman Life, The Universe, and Politics 4 Oct 04, 2001 11:17 PM
