Old Jan 16, 2013, 01:49 PM
Joined Feb 2011
SimonK esc and pancake motors problem?
I am looking for some ESC's that are preloaded with the SimonK firmware. Hobbylobby sells a line called rapidrive that are preloaded with the SK firmware. I went to Hobbylobby and they have a warning on their site "*Note - Current inventory is non-bootloader firmware and not compatible with pancake style motors. Next shipment will include updated firmware."
I am confused since they state it is using SimonK firmware and they even have a button to send him money.
Is the SK firmware pancake motor compatible? If so, does anyone know what HL is talking about?
Any better sources for preloaded SK firmware ESC's?
milo12 is offline Find More Posts by milo12
Old Jan 16, 2013, 02:24 PM
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Yes, it's true that there have been some issues. Have a look at this thread for some more detail: http://forums.openpilot.org/topic/11...-esc-rapidesc/
lovegroove is offline Find More Posts by lovegroove
United States, NE, Omaha
Joined Oct 2005
The latest fw is compatible w/ pancakes. HL esc are probably loaded with an earlier version.
Blue Collar is offline Find More Posts by Blue Collar
Old Jan 16, 2013, 03:18 PM
Joined Feb 2011
Thanks for the info.
Does anyone know where I can buy esc's that are flashed with the latest firmware? I don't really want to flash the esc myself.
Old Jan 17, 2013, 03:08 PM
Jersey, St. Helier
Joined Jan 2013
I bought six rctimer 40amp opto simonk flashed esc's for my hexa. I unfortunately have an intermittent problem with a motor or motors cutting when on 4S (motors are Multistar 690kv "pancake's". I replaced the esc's with some cheap basic ones and it flew perfectly. I'm trying to re-flash them at the moment but without success, so whilst they look terriffic on paper, and perhaps I just have a dud, I would suggest you steer clear for the moment.
I've pm'd simon to see if he has a newer .hex file for these esc's but I've not had a response yet, although I imagine the poor guy gets bombarded with pm's every day.
baldric_ba is offline Find More Posts by baldric_ba
Old Jan 18, 2013, 01:40 AM
hacker
Canada, BC, North Vancouver
Joined Dec 2010
Hello! I'm not sure where to suggest buying them pre-flashed, but you can check that you have at least the 2012-09-30 release (which should work with all motors) by running a jumper wire between the white and red wires on the servo/radio connector. Wait two seconds, then remove the wire from the red and connect it to black. You are basically bringing up the white signal input wire to 5V, then connecting it to ground (don't connect red to black ). After this, you should hear the ESC reset. If you do not, then you have an older version that will have problems.
simonk is offline Find More Posts by simonk
Old May 06, 2013, 12:41 AM
Explorocam
Canada, ON, Ottawa
Joined Feb 2012
Hi SimonK,
Never spoke to you before, so Hi!
I noticed a thread started about the T-Motor ESCs. Do you know if they are using your code? Are you able to confirm this or is this still an unknown issue?
Exploroman is offline Find More Posts by Exploroman
Discussion Timing problem with SimonK ESC ? i3dm Multirotor Talk 23 May 12, 2013 10:20 AM
Question F-30A ESCs with SimonK firmware - problems?!?!?! vineet_p Multirotor Electronics 13 Oct 19, 2012 04:38 AM
Discussion How upgrade firmware (simonk) on Turnigy plush 30a esc slidins15 Multirotor Talk 20 Oct 15, 2012 08:01 AM
Sold F-30A SimonK esc's and RCTimer SimonK esc's and programer hallstudio Aircraft - Electric - Multirotor (FS/W) 2 Oct 14, 2012 01:01 PM
Discussion pancake motors "jumpy" pulsing with rc timer escs helifrek Multirotor Electronics 4 Oct 11, 2012 03:53 PM
