Old Feb 06, 2013, 08:50 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by wyowindworks View Post
How then do you prep for solid secondary bonding when joining the wing halves, spars, and other guts?
I was wondering too!
edit: What vacuum do you achieve when your pump is running continuous Adam?
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Feb 07, 2013, 02:49 AM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Hey Adam, i used to use a strip of peel ply over where the spars will go. This doesnt risk pulling the layup out as much as you aren't pulling from right at the edges. Now I skip it all together and just give the bonding surfaces a sand with some coarse grit paper- seems to work pretty well.
josh18 is offline Find More Posts by josh18
Old Feb 07, 2013, 05:57 PM
AUSELECTRIC is online now
Find More Posts by AUSELECTRIC
Joined Nov 2004
I've never used a regulator is all my years of composites work. I always just used a continuous duty pump. I guess I'm weird that way.
Only issue is that the AC vac pump will probably not be rated for continual duty and woul probably burn out.
With a well seals bag you may get away with regulating the vacuum manually (turning the pump on and off) but this would lead to significant changes in vacuum over the cure time
AUSELECTRIC is online now Find More Posts by AUSELECTRIC
Old Feb 07, 2013, 06:28 PM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
I had a leaking mould once so my pump had to run full time till the part cured. Next morning it was way too hot to touch. I dont think it would be very good for it. Mick (auselectric) and I both have the same vacuum switch, it was cheap and makes the whole thing much easier.
http://www.veneersupplies.com/produc...er-18-NPT.html
Old Feb 21, 2013, 08:05 PM
Joined Aug 2008
No forward link provided!
Deleted post.
For Sale Rohacell structural foam! Wing skins, Tail cores FairlyFaded Aircraft - Sailplanes (FS/W) 7 Jun 25, 2014 10:43 AM
Question Wing Structure Question payne9999 Giant Electric Planes 8 Feb 29, 2012 10:34 PM
Idea Another ridiculous idea? Glass skinning a built up structure... MCarlton The Builders Workshop 11 Sep 18, 2011 04:07 AM
Discussion pre-fab composite wing skins luger007 Composites Fabrication 23 Jan 30, 2010 10:48 PM
