This thread is privately moderated by Kauz, who may elect to delete unwanted replies.
Old Jan 16, 2013, 03:41 AM
Kauz is offline
Find More Posts by Kauz
Fly low...fly slow
Kauz's Avatar
Somewhere in the Black Forest
Joined Oct 2009
Build Log
Powering up the "Owl"
Since I'm flying this model I always had the wish for more power. Nowadays brushless motors became much more cheaper and affordable and so I was searching for a solution to equip the Heinkel with two of them without having to do a major surgery on a ready built model. I finally found a solution that was simple to do and yet optical not to disturbing the overall appearance of my nightfighter.
The photos clearly show what I did and it was a real success
I'm using 10x6" propellers that provide a lot of thrust while having a static current of about 22Amps. She now behaves completely different and the overall performance is way better than ever. From the second flight on I had to switch to folding props, because one of the rigid propellers broke on the first landing. The diameter is now to large to use such types.
This new setup is very economic also, as I can achieve long flight times using 3-S 2200's Turnigy batteries. The first testflights lasted around seven minutes and I could recharge between 810- 840mAh's. So there's still plenty of reserve to stay longer in the air.
And now some photos of the "rebuild".
Frank
Kauz is offline Find More Posts by Kauz
Old Jan 17, 2013, 01:40 PM
mustangloyd is offline
Find More Posts by mustangloyd
Love Flying History
mustangloyd's Avatar
United States, VA, Front Royal
Joined Sep 2011
Hope to see a video of the heinkle in action. Looks great Frank!
mustangloyd is offline Find More Posts by mustangloyd
Old Jan 23, 2013, 11:01 AM
OldeWolfe is offline
Find More Posts by OldeWolfe
Airplane Nut
OldeWolfe's Avatar
United States, CA, Ramona
Joined Oct 2008
Remember to disconnect the power wire from one of the ESCs before connecting to your reciever, otherwise your ESC's BEC circuits could burn out as well as taking out your reciever.
OldeWolfe is offline Find More Posts by OldeWolfe
Old Jan 23, 2013, 01:09 PM
Kauz is offline
Fly low...fly slow
Kauz's Avatar
Joined Oct 2009
No need to be worried about that. I'm an experienced modeler and did of course disconnect the power wire from one of the ESC's, otherwise the Heinkel wouldn't have survived the flights I've had with her so far ;-)
Old Jul 13, 2013, 10:22 AM
Kauz is offline
Fly low...fly slow
Kauz's Avatar
Joined Oct 2009
Latest update: I exchanged the 10x6 Graupner folding props to Aeronaut 10.5x6 ones. The larger diameter and the wider blades now provide even more thrust. At WOT it's very hard to hold that model firm enough before releasing it into the air
I still have about 1/2 inch room before the tips of the blades touch the fuselage's sidewalls, maybe I'll give two 12x6 ones a try....
Frank
Discussion Shenyang J-21(F-60) "white Owl" Fighter bobdaeronort Foamies (Scratchbuilt) 40 Feb 17, 2014 12:48 AM
Discussion Here's on for you flappin' wing guys - an Owl in slow motion planeman Ornithopters 1 Nov 09, 2012 10:01 PM
Cool Owl Landing Video - Fantastic! LSF226 Ornithopters 2 Apr 05, 2012 12:56 AM
Discussion how to bind a Power up dsm2 6ch clone receivers mr.michael.2468 Radios 3 Mar 03, 2012 03:34 PM
Seattle, WA Indoor Flying - Barn Owls Season Starting Up Diesel 10 Electric Flight Events 2 Sep 28, 2010 12:33 PM
