Old Jan 16, 2013, 03:43 AM
fried onion is offline
Find More Posts by fried onion
Australia, NSW, Sydney
Joined Aug 2010
Dynamite Passport Ultra Hidden Menu
Hi,
I have a charger with 1 cell's voltmeter off by 20mv and while looking for a solution I thought it might have a calibration menu like the icharger. I held down the mode and start buttons while powering up the charger and it came up with "input pass word" and 4 0's which you can change with the wheel. Now they've got me interested in what is in that menu I guess this is all pretty useless unless someone finds the password (its not 0000)
fried onion is offline Find More Posts by fried onion
Old Jan 16, 2013, 04:41 AM
Elios000 is offline
Find More Posts by Elios000
United States, MO, Springfield
Joined Jul 2010
brute force it only 4 digits shouldnt take to long
Elios000 is offline Find More Posts by Elios000
Old Jan 16, 2013, 05:21 AM
Joined Aug 2010
true ill post back in a bit after I find it
Old Jan 16, 2013, 05:27 AM
Joined Aug 2010
I have had way too long of a holiday... just remembered that there are 9^4 possibilities so unless some people want to divy up the numbers I can't do that many passcodes
Old Jan 16, 2013, 10:18 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
First are you sure that the volt meter you are using to determine it is off by 20mv is calibrated then your charger?
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 16, 2013, 03:05 PM
turko is offline
Find More Posts by turko
Canada, BC, New Westminster
Joined Oct 2009
passport charger
I recently bought the passport ultrasport charger and while balance charging my 3 cell lipos,it beeps that battery is full(4.2v) per cell but before I can even unplug the battery the voltages drop to 4.18-4.17.Its not good for a brand new charger and I would love to be able to re calibrate it.Check yoursout.After charger beeps,dont stop the charge just turn the dial to the voltage screen and you can see the volts dropping.I'm going to have to send it in to Horizon Hobby for warrenty repair, if I;m not able to fix the problem.If after I disconnect the battery and through it onto my el cheapo eflite 3115 plastic pos charger,it finishes charging to 4.2 Well, the code is not 1234.
turko is offline Find More Posts by turko
Old Jan 16, 2013, 04:53 PM
Joined Aug 2010
The voltmeter itself is probably not very accurate, however over 5 different lipo packs and multiple charges, it has consistently showed a 0.02v higher reading on the voltmeter. The charger also constantly needs to balance out the other 2 cells, with the 2nd cell being low across all of my batteries (making balance charging so very slow ). My dad brought some highly accurate power supplies home when his work was throwing them out, I'll have a look at them and see if they are accurate enough to test my charger.
Am I over reacting to this, I just got some new batteries and want to treat them properly.
the code is also not 1111, 1000, 1100, 1110 only 6556 possibilities left (we'll do this in no time)
Do you think its worth a try asking Horizon?
Old Jan 19, 2013, 10:10 AM
Bruin12 is offline
Find More Posts by Bruin12
Bruin12's Avatar
United States, CA, Gardena
Joined Mar 2011
Another question for Horizon
I also have this charger and have noted the same characteristics. I picked it up used for a good price and it gets the job done, so I am OK with it. One important thing to know about it is that the lipo discharge setting takes your cells down to 3.0v per cell and this setting is not user adjustable. It would be great if the password gave you access to this setting.
Bruin12 is offline Find More Posts by Bruin12
Old Jan 20, 2013, 10:49 PM
Joined Aug 2010
I think the only way we will ever discover what functions are hidden is through numbers
we need to either get enough people to make brute forcing viable (if we got a bit more than 200 people to do 30 combos we would find it) but that probably won't happen so what we need to do is get enough people to petition horizon for it.
Or some super smart guy can reverse engineer the software on the mcu
Old Mar 16, 2013, 04:06 PM
networker is offline
Find More Posts by networker
Today is a good day to fly.
networker's Avatar
United States, TX, Richardson
Joined Nov 2011
Heads up. Ya gotta count the "0", it's 10^4, 10000 possibilities.
In other words, 0000 -> 9999
Just sayin.
networker is offline Find More Posts by networker
Old Oct 21, 2015, 01:04 AM
crazydan82 is offline
Find More Posts by crazydan82
Joined Jun 2015
Im having the same problem only my charger is out by 0.2v on cell number one. Emailed horizon on this issue and requested the password so ill post it here if they get back to me with it.
crazydan82 is offline Find More Posts by crazydan82
Old Oct 22, 2015, 12:02 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Originally Posted by fried onion View Post
Hi,
Just a guess but I expect the pass code is for the use of beta testers. Possibly so that they can make adjustments or allow them to report data back to the manufacturer.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Nov 18, 2015, 02:37 PM
chuck75 is offline
Find More Posts by chuck75
Georgia
Joined Jun 2007
While this is an old post, it bares some added information.
To charge a battery, it's necessary to have current flow. In order for this to happen, the charge voltage needs to be greater than the battery voltage would be by itself. We all sort of agree that a fully charged Lipo is about 4.20v per cell. This means that the charger must actually apply slightly more that 4.20v to charge the battery.
As the charge starts, it's usually current limited, based upon the battery characteristics (Capacity), or the charger's maximum current capability at the charging voltage. As the charge progresses, and the battery voltage increases, eventually the current decreases to hold the charge voltage to 4.20v + the necessary additional to allow charge current to flow.
How the charge terminates can differ. One method looks at the battery capacity, and sets a low charge rate limit. If the battery voltage is at 4.20v, and the current is below a calculated value,
Charging is terminated.
Another similar method also looks at the battery cell voltages during a short pause in charging current flow. Some of the Bantam chargers and clones used this method.
A "high resistance" battery may drop more between the while charging voltage limit, and the at rest voltage. There can easily be about a .03 volt difference, even with a good battery.
Measurement accuracy can also be a contributing factor when dealing with Lipos and the typical DMM. That is another lengthy subject. When you consider that the common inexpensive "pocket"
DMM has a 3 1/2 digit display, and about a 1% of full scale accuracy rating, it also has a +/- one least significant digit spec that gets added. So, an actual 4.20 cell voltage might read something less or more. Most of these meters measure 4.2 v on a 0-10v range, so 1% is actually .1v If you were to add the +/- uncertainty, this might increase to .11. Begin to see the problem?
I ended up having to get a high accuracy 6-1/2 digit bench DMM to resolve differences between various chargers, checkers, and readings.
chuck75 is offline Find More Posts by chuck75
Help! Dynamite Passport Ultra voltmeter calibration fried onion Batteries and Chargers 5 Jul 08, 2012 12:19 AM
Sold Dynamite Passport Ultra AC/DC charger lammbn Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 29, 2012 08:48 PM
Mini-Review Dynamite Passport Ultra Review bladecpfreek Batteries and Chargers 1 May 21, 2010 10:57 AM
Discussion Dynamite RC Passport Ultra AC/DC Charger chickenwing Batteries and Chargers 3 Feb 24, 2010 10:55 PM
