Old Jan 15, 2013, 09:20 PM
Jayray123 is offline
Find More Posts by Jayray123
OUCH!!!
Jayray123's Avatar
United States, PA, Erie
Joined Sep 2008
Chaos 600 and UH-1N RC Aerodyne
Just took delivery of the 600 size UH-1 with a chaos 600. Upon trying to assemble the frames, the tail boom mount and main shaft bearing holders are wider than the supplied spacers and tail rotor drive gear bearing holders. Basically there is no way to assemble the frames with the parts provided. I read in another build thread that the fuse was supplied with additional spacers because the Chaos is wider than the TRex, but nothing in either kit will make this combo work as is. Anyone have any ideas? I can probably get longer screws and make some spacers, but I bought these on the advertisement that they work together with no issues.
Jay
Jayray123 is offline Find More Posts by Jayray123
Old Jan 15, 2013, 09:24 PM
Keyrigger is online now
Find More Posts by Keyrigger
Love my scale Whirlybirds
Keyrigger's Avatar
Mississauga, Ont., Can.
Joined Sep 2009
Contact RCA before going any further. That should have been your first choice. I can't help you in any event as I have not built either unit. I am pretty sure that you should contact Cliff only and he should set things straight. Take care.
Don
Keyrigger is online now Find More Posts by Keyrigger
Old Jan 15, 2013, 09:31 PM
OUCH!!!
Jayray123's Avatar
Joined Sep 2008
Tried calling them, but they had gone home for the night. I'll see about it tomorrow, just have to try to get them early enough.
Jay
Old Jan 16, 2013, 08:37 AM
thenodemaster is offline
Find More Posts by thenodemaster
Mini-Me is watching you...
thenodemaster's Avatar
Hemet, CA
Joined Aug 2010
Talk to Cliff. He'll hook you up. He took care of me when I needed help.
thenodemaster is offline Find More Posts by thenodemaster
Old Jan 22, 2013, 01:05 AM
OUCH!!!
Jayray123's Avatar
Joined Sep 2008
Well, I put in a call the other day to RCA and seems there is a spacer kit, but on the particular model I chose th emenu option wasn't there. For the white version it was, but not the olive drab. Parts on the way.
Jay
Old Jan 23, 2013, 06:49 AM
lightfighter363 is offline
Find More Posts by lightfighter363
lightfighter363's Avatar
United States, IL
Joined Aug 2012
Tried to reach cliff. I did have a issue with them too. They send me a mh-6 fuselage with out the weapon, then they send me a used cracked weapon that i think they took them from a displayed model.
lightfighter363 is offline Find More Posts by lightfighter363
Old Jan 25, 2013, 03:41 PM
Kenneth is offline
Find More Posts by Kenneth
Joined Oct 2000
Do you have the special designed side frames that lower the tail. If so, are these parts in Red a sloppy fit? It affects the gear mesh when assembled.
Kenneth is offline Find More Posts by Kenneth
Old Jan 26, 2013, 06:44 AM
OUCH!!!
Jayray123's Avatar
Joined Sep 2008
The bearings have to be replaced onto the tail drive shaft, on is larger than the other. The bearing come out of the tail gearbox, and you either have to take the brass gear off or drive the pin out of the plastic gear, slide the bearings in their proper spot and reassemble the drive shaft and gears. The bearing holders have to go along with the bearings as well. The middle holder is a must, I just left off the top one until I got it installed in the frame
Jay
Build Log RC Aerodyne 600 size BlackHawk UH-60 Build Log JayNZ Scale Helicopters 195 Oct 11, 2013 04:47 AM
Sold RC Aerodyne Chaos 600 RCBilly Aircraft - Electric - Helis (FS/W) 5 Sep 01, 2012 06:10 AM
Discussion RC Areodyne 450 UH-1N smoothb10 Scale Helicopters 8 Apr 24, 2012 01:30 PM
Discussion Align 550E to 600 upgrade and scale aerodyne UH-1N conv merlin1979 Scale Helicopters 5 Jan 11, 2012 01:13 AM
Article RC Aerodyne Chaos 600 Pro Kit - Scorpion Edition Review CSpaced Electric Heli Talk 363 Nov 29, 2011 04:02 AM
