Old Nov 21, 2001, 08:34 PM
KMKAZE is offline
Find More Posts by KMKAZE
Question gravity.
KMKAZE's Avatar
Kane County, Il
Joined Sep 2000
Easy way to break in a .61?
Got an Avenger pattern plane and a brand new super tigre .61
Is there an easy way to break it in? My manual is missing
KMKAZE is offline Find More Posts by KMKAZE
Old Nov 22, 2001, 06:12 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Is it ABC or ringed?
If ABC, it doesn't really need much running in. Just set it slightly rich and fly it. Important not to run it too cool (rich) as the ABC setup is intentionally very tight at low temps and will wear rapidly if you run it that way for any length of time, resulting in poor compression when hot. If you really want to ground run, short runs slightly rich, giving time to cool down inbetween, are OK.
If ringed, I'd probably run a tank or two through on the ground at a fairly rich setting, then fly it (still set on the rich side for at least two or three flights). If you have loads of surplus power just fly it very rich right from the start.
Bill Glover is offline Find More Posts by Bill Glover
Old Nov 22, 2001, 07:51 AM
davecee is offline
Find More Posts by davecee
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
Hook it up to one D cell and run it in under water.
Sorry, just couldn't resist.
davecee is offline Find More Posts by davecee
Old Nov 23, 2001, 07:05 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Good one Dave C!
One cell will light the glo plug, but its going to be a real bitch to start it under water!!!!!!
heh heh heh
Dave W
DaveW is offline Find More Posts by DaveW
Old Nov 24, 2001, 08:00 AM
Joined Nov 2000
Compression would be impressive though
Discussion Emoli break in ? way out of balance [swift] rcmarty Electric Heli Talk 7 Jun 18, 2006 03:38 PM
Quick easy way to make tabs in Autocad 2006?? duhaas88 The Builders Workshop 9 Oct 26, 2005 10:16 PM
Yippee! Easy way to cut pockets in foam. MX Foamies (Kits) 13 Apr 18, 2005 06:04 PM
