Old Jan 15, 2013, 05:15 PM
shamrock1990 is offline
Find More Posts by shamrock1990
Fly A Mile High
shamrock1990's Avatar
Aurora, Co
Joined Jan 2004
Hangar 9 60 corsair engine question...
Hello I am finally building my hangar 9 60 size corsair arf. I want to put a 4 stroke into it and my question is about engine weight. I know the Saito 100 is highly recommended due to its light weight and power output, however I was looking at the thunder tiger fs 91 as a less expensive alternative. The biggest difference is the weight- saito 19.2 oz minus muffler. Thunder tiger-26.20 oz without muffler. Im sure the Saito is much better in other areas as well from what ive read. Money is an issue, so what kind of performance do you think I can expect from the 91? Any and all opinions and suggestions would be great!!
Brendan
shamrock1990 is offline Find More Posts by shamrock1990
Old Jan 15, 2013, 06:04 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
How do you like to fly? I run OS.91fs and saito .91 in my .60 sized H9 warbirds. (Hellcat, P-40, P-51) They are no barn burners but they fly pretty good with that power. Loops can be done from the straight and level. I have no experience with TT but I think you'll be fine with the TT.91 4-stroke. But if you like zoomin high speed passes over the runway, that saito 100 would be my choice.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Jan 15, 2013, 06:16 PM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
Here is my Funtana 90 with a Thunder Tiger 91FS. I am using a 16X4 prop so the speed is kept low.
My favorite Funtana movie (2 min 49 sec)
jeffie8696 is offline Find More Posts by jeffie8696
Old Jan 15, 2013, 06:33 PM
Fly A Mile High
Aurora, Co
Joined Jan 2004
Engine sounds good!
That should sound good in the Corsair I would think. So you like the power with that engine??
Old Jan 15, 2013, 06:34 PM
Fly A Mile High
Aurora, Co
Joined Jan 2004
My first larger non electric warbird, so Im not real sure how I would like to fly it yet!! I am thinking the tt 91 should be just fine. plus $100 cheaper too!!
Old Jan 15, 2013, 06:49 PM
TEAM BOCA
jeffie8696's Avatar
Joined Oct 2009
My plane is not at a loss for power and look how easy it starts.
Thunder Tiger 91FS easy startup purrs like a kitten roars like a lion (0 min 13 sec)
Old Jan 15, 2013, 09:00 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
One thing to think about is that the Saito does weigh less than the Thunder Tiger engine. But you may need the weight to get the plane's CG to come out right. Normally with a radial engine plane, the nose is more short. Thus you wind up adding lead weight to the front of the plane to get it to balance. So with a heavier engine you need to add less weight to the nose to balance the plane. Anyway the Thunder Tiger engine is pretty good, so you shouldn't have any problems with it.
earlwb is online now Find More Posts by earlwb
Old Jan 15, 2013, 09:46 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
Might want to look at a Magnum XL91FS as an alternative. Its weight is quite a bit lighter than the TT (22.4 oz with muffler). And less expensive.
jjkupinski is offline Find More Posts by jjkupinski
Old Jan 16, 2013, 05:07 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
DLE 20 and a MA 16x8x3 prop. Great power and balanced perfectly.
Lifer is offline Find More Posts by Lifer
Old Jan 16, 2013, 10:45 AM
Disarray is offline
Find More Posts by Disarray
Disarray's Avatar
United States, GA, Gray
Joined Apr 2007
I have the 100 on my H9 corsair. It has plenty of power and did not require any additional weight to balance. I have two 2000 mah NiMH batteries mounted just aft of the cockpit. The .91 should have plenty of power but I don't know about the balance.
Disarray is offline Find More Posts by Disarray
Sold Hangar 9 Corsair .60 ARF New in Box Kkroto Aircraft - Fuel - Airplanes (FS/W) 2 Jul 17, 2012 11:49 PM
Discussion Hangar 9 Corsair 60 Size Retract Ball Joints gva1956 Scale Fuel Planes 0 Jul 16, 2012 11:43 PM
Found Hangar 9 Corsair 60 ARF mjcelli Aircraft - Fuel - Airplanes (FS/W) 1 Jun 29, 2012 07:43 PM
Sold Hangar-9 Twist 60 with JBA-15 Gas Engine - $200 waynemia Aircraft - Fuel - Airplanes (FS/W) 4 Apr 29, 2012 05:05 PM
Sold hangar 9 corsair,60 size. $65 obo, trades wellcome. Turqui Aircraft - Fuel - Airplanes (FS/W) 7 Apr 13, 2012 09:37 AM
