Old Jan 23, 2013, 03:02 PM
motorhead is offline
Find More Posts by motorhead
motorhead's Avatar
Kansas, USA
Joined Sep 1999
The EzFly Icon is now in production and on the web site.
http://www.fancyfoam.com/index.php?m...roducts_id=345
motorhead is offline Find More Posts by motorhead
Old Jan 23, 2013, 09:12 PM
maurice076 is offline
Find More Posts by maurice076
maurice076's Avatar
United States, MI, Warren
Joined Aug 2011
Great Mike,Thank you.
maurice076 is offline Find More Posts by maurice076
Old Jan 23, 2013, 09:25 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
I like this one alot. I have an Icon from parkzone but this would be great for my daughter.
rcrich is offline Find More Posts by rcrich
Old Jan 24, 2013, 05:22 PM
maurice076's Avatar
Joined Aug 2011
I couldn't wait no longer,order sent.WooHoo
Old Jan 30, 2013, 05:39 PM
maurice076's Avatar
Joined Aug 2011
Kit recieved,all looks great,I will post some pics of the finished product.The only thing i'm not figuring out is the elevator pushrod setup.Is It a straight run or curved?I havn't seen it in any pics so far.
Old Jan 31, 2013, 10:02 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
I have it set up for a strait run. Leadfeather did not want that on his so he put 1mm carbon in a plastic tube.
Old Jan 31, 2013, 11:28 AM
maurice076's Avatar
Joined Aug 2011
Thanks for the pic,that is what I thought.The 1mm c/f rod is pretty flexible,that's a smaller dia. that I'm used to.I think I've been using 1.5mm.Being winter now gives me time to gather what I need.Really all I need is corrosion x and a prop adapter.The build shall commence,with a few months to nice warm weather, I'll be taking it slow.
One more Question,I'm assuming the wingtips have the same angle as the first ezfly?Looks to be around 25 degrees?
Old Jan 31, 2013, 06:09 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Wingtips are at the same angle.
I used 1.5 rod in the picture.
LF used 1mm but it was in a plastic tube so he could route it along the fuselage.
Old Jan 31, 2013, 08:15 PM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
I pulled my servos forward...for some reason my build was coming out tail heavy. The rudder was easy and I used the 1.5 mm carbon. With the forward servo, the elevator push rod needed to be curved. I used .032" wire in a plastic tube for this job.
leadfeather is offline Find More Posts by leadfeather
Old Feb 01, 2013, 04:22 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
After LF's model I stretched the nose a little to help on the CG.
Old Feb 01, 2013, 04:37 PM
rcrich is offline
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
very cool , nice vid
Old Feb 02, 2013, 02:27 PM
maurice076's Avatar
Joined Aug 2011
Thanks for all the info,well I said I would take my time,Yeah right.All assembled and gluing motor stick on.I taped 9g servos in their spots and with my 850 3s up front I am balancing about 1/2" forward of the spar.
Were you guys flying with the c.g. on the spar?
Old Feb 03, 2013, 08:35 AM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
About 1/2" in front of the spar.
Old Feb 06, 2013, 09:18 AM
maurice076's Avatar
Joined Aug 2011
I Thought I'd post a couple pic's of where I'm at.Waiting on Corrosion x to finalize.On the bottom I mixed GG+black paint and coated it,then before it was totally dry I applied clear packing tape,then hit it with the iron.Seems to stick really well.
LF I think you said it would slide on grass with the tape,will it fly off grass?
Old Feb 06, 2013, 03:29 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Looks good.
Mine will slide on grass with just the bare foam and will take off easily. With the high thrust line it helps to give some up elevator while on the ground to keep the tail from wanting to tip up.
Discussion EzFly free plans for great trainer plane motorhead Foamies (Scratchbuilt) 2228 Jun 21, 2016 03:53 AM
Sold Parkzone Icon A5 Sea Plane BNF $240 Shipped Johnnymeg Aircraft - Electric - Airplanes (FS/W) 9 Jun 11, 2012 05:00 AM
Sold Parkzone Icon A5 Sea Plane BNF $260 Shipped Johnnymeg Aircraft - Electric - Airplanes (FS/W) 3 May 20, 2012 06:25 PM
Sold Parkzone Icon A5 Sea Plane BNF $260 Shipped Johnnymeg Aircraft - Fuel - Airplanes (FS/W) 2 May 18, 2012 11:22 PM
