Espritmodel.com Heli Air
Old Feb 03, 2013, 10:50 AM
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Remember that the 2940 is an LDO, the combination of a 2940 and an external pnp is no longer LDO.
Cheers
Phil
phil_g is online now Find More Posts by phil_g
Old Feb 03, 2013, 11:00 AM
Stuart
UK, Cardiff
Joined Dec 2008
Cheers
Phil
Quite so.
And 2W dissipation for a LM2940 with no heat sink is not 'fine' the device would be on the point of its thermal limit, it will get very hot, 140C or so.
srnet is offline Find More Posts by srnet
Old Feb 03, 2013, 01:59 PM
Polska, Zachodniopomorskie, Szczecin
Joined Aug 2011
It will be used with LiPO 3s so LDO + pass should be still stable.
Btw Do you know what is the thermal resistance of aluminium plate over TO220?
What's difference between pure plate and heatsinks like this http://www.digikey.com/product-detai...1023-ND/340321
Maybe I'll stay with single heatsinked IC.
xader is offline Find More Posts by xader
Old Feb 04, 2013, 04:13 AM
Joined Mar 2006
My opinion is that there are many applications which are not specifically outlined in manufacturer data sheets that have been in service and operating reliably for years. The fact that so many ESC's contain parallel regulators leads me to believe this is one of those applications that the manufacturers did not cover. This does not mean it doesn't operate properly.
If a regulator starts cutting back it's voltage for reasons of overcurrent or temperature, the paralleled regulators will start taking load. I see no reason that a regulator run at current or temperature limit will fail. The regulator protection circuits are usually very well designed. Does it really matter if one regulator takes all the load until it reaches it's operating limits?
spog is offline Find More Posts by spog
Old Feb 04, 2013, 09:16 PM
New Zealand, Wellington, Porirua
Joined Jan 2013
dave1993, you sir, should go here: http://bit.ly/YyWfQ9
viperidae is offline Find More Posts by viperidae
Old Feb 05, 2013, 01:16 AM
"MAYONNAISE"
Acetronics's Avatar
Le Treport, France
Joined Jun 2004
MIC 29750 could be a number to consider ... if looking for a linear regulator.
btw. I got nice switching boards here ... but not LDO.
http://dx.com/p/mini-dc-dc-voltage-s...ule-red-126106
amazing , no ???
Alain
Acetronics is offline Find More Posts by Acetronics
Old Feb 06, 2013, 09:48 AM
Joined Oct 2012
switching bec 3a
fantasy1988 is offline Find More Posts by fantasy1988
Old Feb 07, 2013, 12:28 AM
Joined Jan 2013
R1 and R2 would need changing to up the output voltage from 3.3V to 5 or 6V. Depending on the MP2365, the inductor may need changing or the efficiency may not be very good.
These kinds of buck converters are a dime a dozen on dx.com
Old Feb 07, 2013, 01:24 AM
Joined Oct 2012
yes, but Mp2365 very small, integrated FET .
3A is enough for RC
Old Feb 07, 2013, 02:03 AM
Joined Mar 2006
3A is enough for RC
Correction, 3 amps is enough for your rc. I doubt anyone would run a 3 amp BEC on anything that uses high end digital servos.
Old Feb 07, 2013, 02:30 AM
Joined Oct 2012
if your servo use currents 5-10a, you should use the battery separate
use BEC for ampe large is not feasible
Build Log DIY Headtracker (Easy build, No drift, OpenSource) Dennis Frie Video Piloting (FPV/RPV) 1218 Yesterday 07:10 PM
Discussion my very diy long range bixler (16.7km on 5.8GHZ) quix-fz Video Piloting (FPV/RPV) 40 Aug 20, 2012 02:56 AM
Discussion any easy diy to measure thrust chuckinnc Power Systems 5 Jun 06, 2012 02:13 PM
Help! Diy bec jvpercia DIY Electronics 2 Jun 06, 2012 03:22 AM
Cool Very Easy DIY 4G6 FB -to- FBL head conversion with 3D and crash tests! Timewerx Micro Helis 5 Aug 11, 2010 02:57 AM
