Old Jan 30, 2013, 12:14 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Originally Posted by phil_g View Post
Ok, arrogant and pretentious. And rude. Further, you seem to take a strange pride in that attitude. Maybe its a culture thing.
culture? i got sh!tloads 'a culture!
Did it occur to you that some of us teach the stuff you've been learning?
"Those who can do, do; those who can't, teach".
sorry that WAS rude. as part time ta (that dont stand for what some of you are thinking) i should show more respect. imagine having me as a student though. count your blessings.
dave1993 is offline Find More Posts by dave1993
Old Jan 30, 2013, 12:20 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
Originally Posted by jakestew View Post
So what is the logical dispute against Dave's theory that the load bearing reg heats faster causing the resistance to increase and thus decrease it's current load?
hi jake,
but thats not my theory. i never said anything like that and makes no sense. sound like something a guy who recommends homemeade copper tips for soldering and thinks resistive dividers make good regulators for high current. fortunately theres nobody around here like that.
want any milk duds with that popcorn?
Old Jan 30, 2013, 03:04 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Originally Posted by dave1993 View Post
i should bring up another point that maybe hasnt been discussed much here. did you know that most escs actually have a row or two of linear regulators on the back? and they are ALL wired in parallel. rarely with any "equalizing" resistors. i kid you not.
Yep. Did you know that many modern voltage reg ICs now have what you call "equalizing" resistors built in ? Even some of those marketed as 78XX replacements ?
It's almost as though the manufacturers had noticed that people weren't bright enough to follow instructions and decided to save them from the results of their own foolishness .
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 30, 2013, 03:25 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
or maybe they are parametric rejects due to process failure and they decided to re-market with "built-in equalizing resistor". in my own experience any added resistance at all did little more than reduce current capability. and little benefit in reliability either.
one thing cheapo chinese controllers might have that help level things off at lower drain is the parts are from same batch and bandgap probably varies little.
Old Jan 30, 2013, 05:47 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
Sounds to me like nobody here really knows the answer and would rather continue the argument endlessly rather than risk a pair of regulators to find out and settle the issue once and for all.
Makes for some good drama at least.
jakestew is offline Find More Posts by jakestew
Old Jan 31, 2013, 01:37 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Probably because it would not prove a lot.
So one pair of regulators from a particular batch from a particular manufacturer do work in parallel. Can you then say the same applies to all regulators ?
Prudent design means following manufactures advice, if they advise against paralleling of regulators ...............
Linear changed the architecture\design of some of thier regulators specifically to allow paralleling, was that not necessary maybe ?
srnet is offline Find More Posts by srnet
Old Jan 31, 2013, 04:54 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Here's one that Linear says you can parallel providing you insert 15mOhm current sharing resistors in the outputs but it has a specification that goes up to 7.5A which means you probably wouldn't want to.
http://www.linear.com/docs/3741
I haven't read the entire datasheet so there may some "gotchas" in there, but isn't that what we've been discussing here.
A.
AndyOne is offline Find More Posts by AndyOne
Old Jan 31, 2013, 05:06 AM
future88 is offline
Find More Posts by future88
Joined Oct 2012
A.
I used ic linear AMS1084, It is very vey hot
future88 is offline Find More Posts by future88
Old Jan 31, 2013, 11:26 AM
AndyOne is offline
Oxford Panic
AndyOne's Avatar
Joined Feb 2003
There's no getting away from heat dissipation with a linear regulator (or any number in parallel), that's why it's best to use a switching regulator for high current.
A.
Old Jan 31, 2013, 12:16 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
there are some applications where a linear can be far more efficient than switching. also switchers are noisy and usually cost more so i only consider them as a last resort..
please note my tests were done with venerable 7805/lm340 5v. however i suspect the same principles apply to other types and its safe to parallel any of them. imo mfg spec sheets, even if they did recommend against (which, apparently, they dont), might only be a consideration in mission critical or life support apps where liability is an issue. not the case here anyway.
Old Jan 31, 2013, 01:45 PM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
If its perfectly safe it obviously would not be a concern in mission critical or life support apps or where liability is an issue.
Its safe and or recommended or its not, which is it ?
Old Jan 31, 2013, 02:56 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
yes. its safe and or recommended or its not.
Old Feb 03, 2013, 04:46 AM
xader is offline
Find More Posts by xader
Polska, Zachodniopomorskie, Szczecin
Joined Aug 2011
Little different question:
I'm about to build kind of Zagi mainboard (connections between rx, vid tx, servos, camera, 2 dividers for frsky & bec for servos).
As I don't want regular radiator on the vreg I came to conclusion to use LM2940 together pass transistor (tip42C).
Additionally 200ohm transistor with jumper in paraller to switch between 5/6v.
Up to 0.6A power wasted is about 2W per IC - should be fine without radiator, and little aluminium plate should make 1A safe.
Can you find anything wrong with this solution? (except caps - as I need to adjust them..)
xader is offline Find More Posts by xader
Old Feb 03, 2013, 05:40 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
[QUOTE=xader;24018421Can you find anything wrong with this solution?[/QUOTE]
The circuit diagram does not relate to your description, different pass transistor, different regulator.
Old Feb 03, 2013, 07:35 AM
xader is offline
Joined Aug 2011
Yes - I cannot find LTSPICE models for LM2940 or TIP42C, thus I've used somehow similiar models - I'll try it next week on breadboard if i'll get ic's. But preffer get opinions earlier especially that I'm just starting having fun with electronics.
Attached schema without correct caps yet. (need to find ones with appropriate esr and adjust position)
Build Log DIY Headtracker (Easy build, No drift, OpenSource) Dennis Frie FPV Equipment 3406 Today 02:18 AM
Discussion my very diy long range bixler (16.7km on 5.8GHZ) quix-fz FPV Talk 41 Nov 16, 2015 03:40 PM
Discussion any easy diy to measure thrust chuckinnc Power Systems 5 Jun 06, 2012 02:13 PM
Help! Diy bec jvpercia DIY Electronics 2 Jun 06, 2012 03:22 AM
Cool Very Easy DIY 4G6 FB -to- FBL head conversion with 3D and crash tests! Timewerx Micro Helis 5 Aug 11, 2010 02:57 AM
