Old Feb 09, 2013, 09:08 AM
bogusbob1 is offline
Find More Posts by bogusbob1
NYC
Joined Apr 2005
Bob,
You should try a APC 9x6 EP prop on that http://www3.towerhobbies.com/cgi-bin...?&I=LXPVF0&P=7 they work really good on the flight streaks and are way more efficiant than the prop you are using. if you look at the pic of my son's earlier in this thread you can see that i use1/16 aluminum angle iron for a real simple motor mount and i use some 047 music wire bent in a u throgh the fuse with hooks bent into it after it comes through. then i use rubberbands to simply hold the battery. i like everything exposed for cooling purposes.
bogusbob1 is offline Find More Posts by bogusbob1
Old Feb 10, 2013, 10:37 AM
Bob Mears is offline
Find More Posts by Bob Mears
F2D Pilot/Mechanic
Bob Mears's Avatar
United States, TX, Lubbock
Joined Dec 2011
Originally Posted by bogusbob1 View Post
Bob,
until i run into overheating issues, I will go for aerodynamics. Must be a combat thing I may have to break down and buy a better prop. But so far my goal is to use up the batch of props I have in drawers and live with their performance.
Bob Mears is offline Find More Posts by Bob Mears
Help! Top Flite Flite Streak C/L ARF .25-.40,41.5" saab2 Control Line 14 Apr 24, 2015 10:24 AM
Discussion ARF Flite Streak lead-out position brokenspar Control Line 5 Aug 09, 2012 04:54 PM
Sold Brand New Electro Streak ARF with rare Fiberglass Fuse lafuerza Aircraft - Electric - Airplanes (FS/W) 0 Jul 16, 2012 11:45 AM
New Electro Streak ARF Joe Yap Sport Planes 1 Feb 18, 2002 02:26 PM
E-Streak ARF Hammer Electric Plane Talk 6 Dec 30, 2001 09:53 AM
