Old Jan 15, 2013, 04:27 PM
TedD60 is online now
Find More Posts by TedD60
Joined May 2012
Need Help ID'ing Transmitters NOW WITH RCVRs
I have been given a large batch of micro RC gear. It came in boxes and was largely without instructions, manuals and unidentified. Since I received these things it, I've been trying, without much success, to determine what the stuff is, and its usefulness.
My interest is to build micro a/c and fly them in my yard, about the area of a two or three basketball courts, so I don't think range is a real issue.
I need to know what aircraft they were originally designed for, what receivers would work with these transmitters, and where I might find manuals for each.
Will any of this gear work with the AR6400 receiver?
Are they "bind and fly" and will work with a number of receivers or are they "aircraft specific" and will only work with the plane they were built for?
There are 4 types and I will post fotos below.
Thanks for any help/info you can offer.
TedD60 is online now Find More Posts by TedD60
Old Jan 15, 2013, 04:38 PM
Joined May 2012
This would be Group "A" . The markings indicate that its Parkzone and is 2.4 GHz. There is also "Minimum 3" written on the front.
Old Jan 15, 2013, 04:40 PM
Joined May 2012
Here we have group B. This one is also marked Parkzone ... but has a larger ETOMIC sticker on the bottom. The sticker also indicated "2.4 GHz Spread Spectrum Radio.
Old Jan 15, 2013, 04:44 PM
Joined May 2012
Moving along, we come to Group C.
This one is a Tactic 2.4 GHzx. TTX402
The sticker indicates that it is a 4 channel and has "Secure Link Technology".
Unlike the others, these transmitters have NO external antenna.
Old Jan 15, 2013, 04:47 PM
Joined May 2012
Finally we come to group D.
This one is labeled Flyzone, FZT-324. It is also 2.4 GHZ and the stickers on the face indicate that its a 3 channel micro radio system.
Wait untiI I post the pictures of the receivers and motors/gearboxes.
Again, any help you can give will be greatly appreciated.
Old Jan 15, 2013, 06:45 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
ParkZone Cessna transmitter. May also work with the micro RX out of the early Kyosho micros. The "brick" looks like a Vapor brick with a red LED. If you don't have the RX brick to match it, you might get a few bucks for it in the classifieds.
Check the link for more info and pics.
http://www.rcgroups.com/forums/showthread.php?t=701562
Tim Wolff is online now Find More Posts by Tim Wolff
Old Jan 15, 2013, 06:52 PM
Quartza is offline
Find More Posts by Quartza
United States, TX, Mansfield
Joined Mar 2008
Group B is a DSM2 transmitter and should work with most spektrum Rx's. It will not bind to a surface rx
Quartza is offline Find More Posts by Quartza
Old Jan 15, 2013, 06:58 PM
Tim Wolff's Avatar
Joined Sep 2002
ParkZone Citabria, Ember transmitter. Same compatibility as the last TX you posted. ParkZone Cessna, Citabria, and Ember. The ParkZone micros were not DSM2 until the Ember 2 was released
http://www.horizonhobby.com/products...rtf-PKZ3200#t4
Old Jan 15, 2013, 07:01 PM
Tim Wolff's Avatar
Joined Sep 2002
I think these will bind with with FlyZone brand gear, but I'm not sure if it is only the early (pre-Anylink) Playmate and Albatros, the current generation, or both. Check Flyzone, Hobbico, Tower Hobbies sites for documentation.
Old Jan 15, 2013, 07:02 PM
Tim Wolff's Avatar
Joined Sep 2002
First generation RTF FlyZone Playmate and Albatros only.
Old Jan 15, 2013, 07:07 PM
Tim Wolff's Avatar
Joined Sep 2002
If you didn't get any receivers with the lot, you'll have to decide if you place a wanted ad for a compatible RX (buy CHEAP only) new AR6400L clones are ~$20 @ targethobby.com, sell them off, or usher them into the dumpster.
You should also be able to get a DSM2 compatible TX that looks like the one in your second post in the classifieds for ~$20 or less.
Old Jan 15, 2013, 08:50 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The tactic TX's will work with Tactic bricks, which can be had for cheap from people converting their planes to Spektrum. These are 4 Channel and 1.7g servos will plug in. They are a little heavier than an AR6400, but aren't too bad.
UNGN is offline Find More Posts by UNGN
Old Jan 17, 2013, 01:37 PM
Joined May 2012
OK ... now its gets a bit tougher.
I have 6 different types of receivers ... all without any identifying marks. What makes this tough is that what manuals I can find generally do not show pictures of the receivers.
Above I labeled the transmitters with LETTERS.
I am labeling the receivers with NUMBERS.
If possible, could we match transmitters with receivers (i.e., A-3) and, as above, perhaps tell me which manufacturer and plane each came from?
Thank you for all your help.
Old Jan 17, 2013, 01:38 PM
Joined May 2012
OK ... this is number 1
Old Jan 17, 2013, 01:41 PM
Joined May 2012
Here is Number 2
Discussion Need help ID'ing and value... NMills Fuel Plane Talk 2 Nov 27, 2012 08:52 PM
Discussion Need help ID'ing engine.. RCbossman Engines 5 Oct 13, 2006 09:56 PM
Need help ID'ing music. dstout Life, The Universe, and Politics 6 Jun 05, 2004 10:39 PM
Need help ID'ing Corsair DrBill Scale Kit/Scratch Built 2 May 23, 2004 12:04 PM
