Old Jan 15, 2013, 03:14 PM
Boonzie is offline
Find More Posts by Boonzie
Australia, NSW, Sydney
Joined May 2012
FPV 12v camera with step up regulator
Hi there.
I have the following setup which isn't working for me. I'm trying to use a step up regulator off the 5v output to power my 12v camera but I don't get a picture, just white screen.
Do I need to ground the camera differently? If I power it directly from 12v it works fine.
cheers,
Alex
Boonzie is offline Find More Posts by Boonzie
Old Jan 16, 2013, 01:08 AM
ommadawn is offline
Find More Posts by ommadawn
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
Originally Posted by Boonzie View Post
Hi there.
cheers,
Alex
I wonder if the regulator is too noisy for the camera?
Why not run the camera off your lipo balance lead. Is it a 4s? You can easily pick up 12v from there. Connect between (-)balance lead, and the lead that has 12V.
ommadawn is offline Find More Posts by ommadawn
Old Jan 16, 2013, 01:18 AM
Sad Sack is offline
Find More Posts by Sad Sack
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Not to be cheeky, are you sure its not a 12V-5V regulator?
If it IS a step up, there must be something wrong, maybe the output of the Immersion RC is too low (<5V), and you are getting sub-12V out of the end?
I would ditch the regulator and get 12V from a JST lead, just splice into the cable that is going too the AV TX.
Or like above, get the 12V from the balance lead using a cable like this:
http://www.hobbyking.com/hobbyking/s...0pcs_bag_.html
You just cut the plug off, keeping the socket, and remove all the wires only keeping the black and red wires, giving 12V
Sad Sack is offline Find More Posts by Sad Sack
Old Jan 16, 2013, 01:32 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
You could try the common ground buck inverter I used on my quad for more than a year with no problems, and no need for additional filtering. I never tried it with a 5v source but it powered my 12v cam and VTx ok off 2S (7.4v). Eventually though I just went to a 5v cam (kpc vsn505) and VTx to simplify everything and am glad I did. Less electronics to worry about failing.
patricklupo is offline Find More Posts by patricklupo
Old Jan 16, 2013, 03:31 AM
jarred1993 is offline
Find More Posts by jarred1993
Fully Sick Bro!
jarred1993's Avatar
Australia, QLD, Ipswich
Joined Nov 2012
Hi there.
cheers,
Alex
You need to connect the power for the camera to the input power for the vtx so they share power but keep the ground connected to the vtx just make a y cable for the power I'd draw you a diagram but I'm replying to this off my phone :P
jarred1993 is offline Find More Posts by jarred1993
Question how to step up 11.1V 3 cell lipo DC to 12V DC for my FPV monitor? TheSelf FPV Talk 17 Sep 09, 2015 10:28 AM
Found 12v Step Up nautique FPV Equipment (FS/W) 4 Nov 30, 2012 12:10 PM
Found 12v Step Up nautique FPV Equipment (FS/W) 3 Nov 14, 2012 12:42 PM
Help! Looking for 5 > 12V step-up reg.n FOUND Hugeone FPV Talk 0 May 01, 2012 10:32 AM
Discussion Step up / Step down 5V regulator NC1 DIY Electronics 2 Jan 25, 2006 11:05 AM
