Old Jan 15, 2013, 10:52 AM
nr1 is offline
nr1
Find More Posts by nr1
nr1
Joined Feb 2012
3x 1S balanced charging lead: How to setup correctly?
Hello,
i bought a 3x 1S balanced charging lead, for charging 3 lipo batteries with my Turnigy Accucel 6 charger.
My question is following:
I'd like to charge 3x 1S 500mah with this lead.
So i will connect everything to the charger and select the 3S balanced charging program.
But which current should be selected?
From my logic i should take 1.5 A (=> 3x 500mah = 1.5 A), but as i understand this current will also be taken for the balancing process afterwards. => So if there is for example only 1 of the 3 batteries left for being balanced, this one battery would also be balanced with 1.5 A or?
(Which would surely kill the battery)
nr1 is offline Find More Posts by nr1
Old Jan 15, 2013, 10:59 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
That lead connects the cells in series not parallel, that's why you're using the 3S program. So, assuming you want to charge at 1C, the current should be that suitable for a 3S 500mAh battery i.e. 500mA NOT 1.5A.
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 15, 2013, 11:45 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
As slipstick said do not add the capacities since they are in series. So for 1C charge rate you would do a 3S 0.5A charge.
Don't worry about the balancing process, it knows what it is doing. It's actually not an afterwards thing but starts during the CV phase of the charging cycle. In short it only provides the current needed to keep the cells at 4.2v per cell and it actually bleeds off excess current across cells that are already done to keep them from getting over charged.
Also note that since it is a series adapter you MUST always charge 3 batteries at once. It will not work if you only connect one or two.
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 15, 2013, 01:55 PM
nr1 is offline
nr1
nr1
Joined Feb 2012
ok, thx a lot for your replies
Discussion Balance charging 6 1S lipo batteries at once octanejunkie Batteries and Chargers 85 Oct 30, 2015 06:11 AM
Help! 1S charging lead Assassin-8 Batteries and Chargers 7 Jan 11, 2013 02:41 PM
Discussion How to charge only using balance leads on Accucell 6? Koo Batteries and Chargers 7 Aug 03, 2012 08:50 AM
Sold 3s balance charge lead for 1s packs ohsnap Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 10, 2011 07:39 AM
Discussion How to setup digatal charger to charge 1s lipo Clouds4brains Scratchbuilt Indoor and Micro Models 1 Jun 23, 2010 11:11 AM
