Old Jan 15, 2013, 04:16 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
All things ASK-21 UMX!!!
Hey folks,
There is starting to get a little bit of a cult following with this little beauty glider, so i thought id start a thread for all things ASK-21.
Maybe some posts like longest flight off the stock bungee and flying tips ect.
Last weekend a few of the Hammo guys had there little ASK's out for a bit of fun and as there were 2 carbon cubs there too, it didnt take long for the tow's to get going! Without much luck, i came up with the idea of using my Multiplex FunCub to tow them up!! But, being such a larger plane than the glider, it was just too much pull for the glider to handle.
Bing!! on went the idea light in my head once again, so i have a fully controllable RC freefall skydiver that is dropped out of a drop box on the bottom of the FunCub, the FC being piloted by usually Mr.K and the freefall skydiver controlled by whoever wants a jump at the time. The freefaller is fully controllable from pulling the chute, to flaring on landing!! But thats another story, if you want more information on the skydiver just PM me and i can start a thread for Punxatawny Phil the freefaller.
So i decided to mount the drop box on top of the wing, over the CG of the FunCub cause its literally just velcroed onto the plane (HK's blue velcro, its strong as nails) and voila! Instant piggy back!!
The first few flights were a little hairy as the speed of the cub and the drag on the gliders wings was a little too much for the proud owners of their little bubs, so we decided the only way up is quick, and vertical!! The FC is way overpowered and is often seen being 3D'd by Mr.K after a para drop!!
Once we had a few successful flights piggy backing we were going up one after the other, it turned out to be an awesome way to get them to altitude where they could get longer glides, and the guys were nice enough to let me have a little flight down and i ended being the longest up there!! lol
Crashmatt and myself have both spent the last 2 nights dreaming then making up a few little power pods to get the gliders to altitude with power, then eject the pod to see it parachute safely to the ground for the next flight!! Both our pods are very different in design, but both are powered by the internal electrics found on most of the UMX range like the GeeBee and BeastX ect.
To have control over the throttle, we bind the 2 receivers at the same time so when climbing the glider pretty much becomes a powered glider, when at the chosen height we want to glide back from, we use the gear switch that disconnects the tow hook thats attached to the front of the pod and nose down and throttle up till we see a deffinate separation, at that stage we hit throttle cut or throttle down and the pod should be falling back with a nice slow descent rate. Well, all that is theory so far as we havent maidened the pods yet, but will do tomorrow morning and report back on how they went.
For now, here is the pic of the FunCub with the ASK-21 on its back ready for a piggy back!
Here is one of the pod im building very early on in its build stage and the electrics i'll be using thanks to Matt!!!
Essentially, the pod is a centre piece from an old Zagi 400 wing i have spares of. The 2 sides are corflute where the wings will be saddled in, and at the nose you can just make out the small metal wire where the tow release mechanism locks in. The motor esc/rx with be fixed to the bottom of the pod and the parachute will be packed in under the belly of the glider. Its all slightly snug, enough that the chute wont pull out on power but not too tight that the pod wont pull away from the glider.
We got the pod idea from this video:
E-Flite UMX ASK-21 Glider Power Pod Upgrade in HD By: rcinformer (8 min 50 sec)
But unlike in the video, we wont be using a kill switch. We did buy the switches and plan on using them, but though it easier to just utilise the throttle and throttle cut off.
Enjoy the thread, i look forward to some more pilots checking in!!!
Teamsherman is offline Find More Posts by Teamsherman
Old Jan 15, 2013, 05:12 AM
MclF1 is offline
Find More Posts by MclF1
CRASHING IS THE EASY PART
MclF1's Avatar
Australia, NSW, Oatley
Joined Sep 2011
very nice thread to start TS
im also after the ask-21
thats such a great idea now why didnt E-flite think of that
MclF1 is offline Find More Posts by MclF1
Old Jan 15, 2013, 05:34 AM
ChrisJ800 is offline
Find More Posts by ChrisJ800
Tassie Electric, Heli, Glider
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
The k21 is a nice little sloper too. Here is a vid of me sloping it in Taz. Sorry its from an iPhone and the slope had the lift a long way out so its not great quality. It slopes with AS3X either on or of nice and spins loops and fles inverted ok. Rolls not so good yet.
Slope soaring UMX ASK 21 (0 min 51 sec)
ChrisJ800 is offline Find More Posts by ChrisJ800
Old Jan 15, 2013, 06:49 PM
Member #1
Joined Aug 2011
We tried one of the pods today (Matt's bling one) and it was slightly under powered but flew well. Only real problem had was that the wing cradles were slightly too tight not releasing off the glider so I think he's at home fixing that as I type.
I've got all the necessary parts now so I'll get mine done this afternoon hopefully and give it a try soon. I'll get a pic up of the finished product too.
On another note, I tried the supplied bungee and that was quite disappointing to say the least! I think the pods and FunCub piggy back are going to be the best ways to get this thing to thermal hunting height.
Old Jan 15, 2013, 08:50 PM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
was in winter so no thermals but this little glider is a beauty, here is a couple of my bungee launches.
Also a couple of posts with power options
cheers chuck
http://www.rcgroups.com/forums/showp...postcount=1349
http://www.rcgroups.com/forums/showp...postcount=1298
E-Flite UMX ASK-21 Glider Bungee Launch Maiden (7 min 51 sec)
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Jan 15, 2013, 11:50 PM
Member #1
Joined Aug 2011
Edit. Vid coming.
Old Jan 16, 2013, 12:59 AM
MclF1 is offline
MclF1's Avatar
Joined Sep 2011
could you make a bungee to say 30m long would that work?
Old Jan 16, 2013, 12:18 PM
Crashmatt72 is offline
Find More Posts by Crashmatt72
Crashmatt72's Avatar
Joined Feb 2012
Ask-21 Power Pod Mod Maiden (2 min 0 sec)
Short clip of the first power pod maiden, mods needed. But has potential!!
Crashmatt72 is offline Find More Posts by Crashmatt72
Old Jan 17, 2013, 12:26 AM
Nam Lemmi is offline
Find More Posts by Nam Lemmi
This thing runs real nice...
Nam Lemmi's Avatar
Joined Jun 2012
This a short vid of my ASK-21 slope soaring. Flies inverted very well I thought!
E-Flite ASK-21 slope soaring (2 min 34 sec)
Nam Lemmi is offline Find More Posts by Nam Lemmi
Old Jan 17, 2013, 02:53 AM
junglegym is offline
Find More Posts by junglegym
3 Strykers,your out !
junglegym's Avatar
Lurking Melbourne Australia
Joined Apr 2008
http://www.youtube.com/watch?feature...&v=4722u5CysA0
http://www.rcgroups.com/forums/showthread.php?t=1801206
junglegym is offline Find More Posts by junglegym
Old Jan 17, 2013, 04:12 AM
Joined Feb 2012
http://www.youtube.com/watch?v=SXuKbV1ua0M
Nice flight, it slopes great!!
The bungee and tow are a waste of time.
Keep up the nice flying
Old Jan 17, 2013, 04:18 AM
Member #1
Joined Aug 2011
Ive finally finished my power pod this evening!!
I'll give it a go tomorrow morning or afternoon, depending on if i decide to sleep in or not, i think i might sleep in actually!!! lol Plus, if it gets as hot as they say, i might want to fly in the heat of the day to get thermals, that said, its only if the pod works!! I powered it up with a load this arvo and held it vertical, and it wanted to climb out of my hand so it should do, but the main concern i have is if the glider will release from the pod or not, just like Matt's didnt want to release.
If that dont work, im buying a helium tank, a big arse balloon and a beach rod with about 200m fishing line to float the sucker up, then wind the balloon back in for another flight, but im guessing it wont work too well once the wind comes up!! LOL
Old Jan 17, 2013, 04:25 AM
ChrisJ800's Avatar
Hobart, Australia
Joined Oct 2002
Here are a couple of vids launching the K21 using a Quad, originally posted on the main ASK21 thread:
Quadcopter Tows Glider (0 min 52 sec)
Quadcopter - ASK-21 Glider launch (1 min 42 sec)
Old Jan 17, 2013, 04:27 AM
Joined Feb 2012
Awesome work with the mods Junglegym!
Old Jan 17, 2013, 08:01 PM
Member #1
Joined Aug 2011
UMX ASK-21 Power pod mod (0 min 45 sec)
Yippee! the UMX ASK-21 is here! xrx1113 Sailplane Talk 42 Jan 30, 2013 09:36 AM
Discussion Umx ask-21 Cody WIlson Slope 6 Nov 28, 2012 02:47 AM
Question E-Flite UMX ASK-21 glider Vrated Slope 3 Nov 21, 2012 10:13 PM
Discussion UMX ASK-21 Question Kevinfred Scratchbuilt Indoor and Micro Models 8 Nov 01, 2012 01:25 AM
Wanted Umx ask-21 as3x Baseman Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Aug 30, 2012 09:02 AM
