Old Jan 14, 2013, 09:36 PM
r/cmark is offline
Find More Posts by r/cmark
200 mph club
r/cmark's Avatar
United States, AZ, Fort Mohave
Joined Mar 2005
3 meter Radian
I want a 3 - 4 meter Radian 'like' plane for ALES. Configuration would be RES , REF or just RE anyone know of such a plane?
r/cmark is offline Find More Posts by r/cmark
Old Jan 15, 2013, 06:08 AM
tlar633 is offline
Find More Posts by tlar633
Joined Aug 2010
Buy a spare Radian wing cut off the tips to give "new" center panels add new center panels (1 left and 1 right to old center sections. You will have to replace the carbon fiber tube with a longer one. You than will have a roughly three meter Radian.
tlar633 is offline Find More Posts by tlar633
Old Jan 15, 2013, 08:22 AM
edfmaniac is offline
Find More Posts by edfmaniac
Joined Jul 2009
You might look at the Multiplex Cularis. It's not quite 3 meters but is a bit larger than the Radian.
Nevermind. I just saw the Radian part and it didn't sink in that you were looking for a RE.
edfmaniac is offline Find More Posts by edfmaniac
Old Jan 15, 2013, 11:00 AM
Schwemmer is offline
Find More Posts by Schwemmer
Sherpa
Schwemmer's Avatar
La Quinta, Ca.
Joined Sep 2003
If you want to upgrade to a 3-4 meter glider and want a foam glider you will need to modify one. If you want a 3-4 meter glider then this is a good choice.
http://www.mmglidertech.com/oculus.php
Sherpa
Schwemmer is offline Find More Posts by Schwemmer
Old Jan 15, 2013, 11:49 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
I reckon there's a good reason why a 3m foam glider isn't being manufactured. It may be worthwhile thinking about that before cutting up a bunch of existing kits....
Chris
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Jan 15, 2013, 12:04 PM
Windknot is offline
Find More Posts by Windknot
Canada, PE, Stratford
Joined Aug 2006
I'm with Woodstock on this one. What about the Bird of Time ARF? It's a 3m RE sailplane, and the electric conversion is fairly straightforward by all accounts.
Windknot is offline Find More Posts by Windknot
Old Jan 15, 2013, 12:49 PM
soarx4 is offline
Find More Posts by soarx4
United States, IL, New Lenox
Joined Feb 2005
Mystique by Horizon Hobbies.
http://www.horizonhobby.com/products...9m-arf-EFL4905
soarx4 is offline Find More Posts by soarx4
Old Jan 15, 2013, 04:21 PM
pablo pinto is offline
Find More Posts by pablo pinto
FLY FOR FUN - GLIDE FOR LOVE
pablo pinto's Avatar
United States, FL, Miami
Joined Jan 2011
you can try with the foam glider Phoeneix Evolution
http://www.ebay.com/itm/2-4GHz-6Ch-R...item4160551f77
or with the Mystique from e-flite.
pablo pinto is offline Find More Posts by pablo pinto
Old Jan 15, 2013, 08:24 PM
soarsimon is offline
Find More Posts by soarsimon
United States, NC, Tryon
Joined Sep 2005
Yeah, a buddy of mine and I tried increasing the wingspan of a radian by adding new center sections to the tip sections. We even bought a 6 foot carbon tube to use as a spar. Had to increase the rudder size as there wasn't sufficient authority with the stock one. I still felt like tke 2m Radian was a better plane. The extra weight of the increased span did help with penetration but the wing was still too flexible in "moving" air. I suppose one could spend some time fine tuning the design and show enough improvement to make it worth the effort, but I'm not gonna do it. The stock Radian flies too well for me to try to improve it. I'd just buy/build a bigger plane. If I was going to spend as much time as would be necessary to dial in a 3m radian, I'd rather build a woody. How bout' an OlyII or an Oly3...
http://www.skybench.com/index.html?h....com/home.html
soarsimon is offline Find More Posts by soarsimon
Old Jan 15, 2013, 11:10 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
One way might be to get, used, one of those old gliders with 7037 airfoil that are now considered obsolete. At least if it's not too heavy. Ought to outperform a 3 meter Radian, anyway.
lincoln is offline Find More Posts by lincoln
Old Jan 17, 2013, 07:15 AM
Steve Boone is offline
Find More Posts by Steve Boone
founder of the SSP
Steve Boone's Avatar
Walkerton, Indiana
Joined Jul 2004
I built a 120" Radian. It flies great. The wings needed to be covered with packing tape under tension to help with the flex. It's by no means a windy day plane. On calmer days it's a blast to fly. You don't have to increase the rudder throw or size to maintain authority but it sure helps. Here it is sitting next to the original version.
Steve Boone is offline Find More Posts by Steve Boone
Old Jan 17, 2013, 10:05 AM
skydvejam is offline
Find More Posts by skydvejam
Once you taste flight...
skydvejam's Avatar
United States, ME, Garland
Joined Dec 2011
Another 2.5m option http://www.bananahobby.com/diamond-2...5395-prd1.html Not saying it is a good plane, or a bad one, but an option.
skydvejam is offline Find More Posts by skydvejam
Old Jan 17, 2013, 01:05 PM
r/cmark is offline
200 mph club
r/cmark's Avatar
Joined Mar 2005
H i Steve,
Do you have any details on the build? Pictures?
Old Jan 18, 2013, 03:04 PM
founder of the SSP
Walkerton, Indiana
Joined Jul 2004
For the beginning of how I did it, see page 49 post #727 in the Radian thread. Link
Old Jan 18, 2013, 06:13 PM
Ken Lilja is offline
Find More Posts by Ken Lilja
I'm slow but I'm expensive
Ken Lilja's Avatar
United States, GA, Snellville
Joined Nov 2003
One of our club members did an exquisite mod to stretch a Radian wing. He spliced in as much of the flat section of a second wing as possible. It turned it into a REAL sailplane. In winds less than 12 or so mph I would expect it to hold it's own with anything short of an AVA.
Ken
Ken Lilja is offline Find More Posts by Ken Lilja
Build Log 1:3 Scale PWS 101 Gull Wing @ 6.3 meter span SPasierb Scale Sailplanes 22 Apr 02, 2016 09:33 AM
Discussion Looking for a 3 meter glider Stepping up from a Radian eng30 Thermal 19 Nov 07, 2012 02:21 PM
For Sale Sharpwind 3.3 meter Mauihiflyer Aircraft - Sailplanes (FS/W) 4 Apr 23, 2012 03:52 PM
Discussion 3 Meter Bird of Time plus Parkzone Radian = amazing conversion QuietRiot Electric Sailplanes 14 Oct 26, 2010 06:11 AM
