Espritmodel.com Heli Air
Old Jan 14, 2013, 06:32 PM
sub-noob
colj00's Avatar
Australia, WA, Perth
Joined Aug 2012
can i charge a NIMH at 1c?
it may be a stupid question but the charger that came with a nimh battery charges at 1.2 amps, but the pack is 2400mah.
its a flat 6 cell nimh, C cells.
15c discharge...
colj00 is offline Find More Posts by colj00
Old Jan 14, 2013, 06:51 PM
United States, NJ, Phillipsburg
Joined Mar 2012
Yes
iflircaircraft is offline Find More Posts by iflircaircraft
Old Jan 14, 2013, 07:13 PM
sub-noob
colj00's Avatar
Joined Aug 2012
Originally Posted by iflircaircraft View Post
Yes
wont shorten the life of it right?
Old Jan 14, 2013, 07:22 PM
Joined Mar 2012
Been charging mine for 3 years that way. The initial charge should be at .1C .
Tom
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Simple answer is ask the manufacturer of the cells. I would never do it. If you want to try it keep an eye on the packs temperature, don't let it get hot to the touch.
Evan D is online now Find More Posts by Evan D
Old Jan 14, 2013, 07:53 PM
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
There are high-output NiMH cells which tolerate 1C and higher charge rates, but they're typically sub-C, C, and D sized cells. The RC car and truck people use these but they aren't used in planes very often due to their weight.
Most AA and AAA NiMH cells are designed for low power output and they typically don't tolerate 1C charging very well. Some will argue that the damage is insignificant, but the insignificant damage is cumulative and will eventually become significant.
Pete
PGR is offline Find More Posts by PGR
Old Jan 14, 2013, 08:31 PM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
+1 What Pete said.
Consumer type cells are NOT the same as Hi-Output power cells and don't take as well to higher charge rates.
If it gets HOT......don't do it.
flydiver is offline Find More Posts by flydiver
Old Jan 14, 2013, 08:36 PM
sub-noob
colj00's Avatar
Joined Aug 2012
Originally Posted by flydiver View Post
+1 What Pete said.
they are C cells
Old Jan 14, 2013, 08:44 PM
Evan D's Avatar
Charlotte, NC
Joined Jan 2004
Are you going to believe what is said here? If 1/2 the people say yes and the other half say no what are you going to do? A guy with 18 posts says he's been doing it for three years... Three others with 4726, 7281, and 4324 posts say no or it's not that simple...
So what are you going to do?
Old Jan 14, 2013, 09:04 PM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
Most AAA NiMh cell will tolerate a 1C rate, but it will shorten the life of the battery significantly if you do that every time... If you have the time you should trickle charge your packs, but an occasionaly 1C charging session won't do major harm to the battery. That said, I prefer convenience over getting every last ounce of life expectancy out of a battery and typically charge my NiMh (AA and AAA) receiver packs at a 2-3 hours rate, 1/3 - 1/2C.
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Jan 14, 2013, 09:11 PM
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
Heh ...
Back when I had just eclipsed 3000 posts I used that argument when someone with only two posts disagreed with me. Turned out the guy was a Dryden Flight Research Center test pilot with several thousand of hours in high performance jets in his log book and he'd been an active model aviator since he was a kid. We eventually agreed that I was more correct than he was about the subject we were discussing, but I still cringe when I remember questioning his knowledge based on his join date and the number of his posts.
Then there was the time I tried to argue a LiPo charging issue with the head charging systems engineer for Motorola's cellular products division. That was in an Android forum and he only had five posts to my 452.
Bottom line is judging someone's knowledge by the number of posts they have under their avatar isn't a good idea. It's better to save it for when they post something stupid.
Pete
Old Jan 14, 2013, 09:49 PM
flydiver's Avatar
Seattle, WA
Joined Jan 2007
Originally Posted by colj00 View Post
they are C cells
I have a lot of consumer C-cells. They are about 2200mA and I tend to charge them around 1A. I would push them to 2A if I was in a hurry but that is seldom.
Old Jan 15, 2013, 12:47 AM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
Pete, the reverse is often true as well. A high post count or old join date is often taken by newcomers as a sign of experience/knowledge/expertise, but we can all think of examples where some of the most vocal posters also happen to be the ones who know the least... *COUGH*Chuck*COUGH*...
Hell, I'm closing on 10k right now and I don't know a shoot damn thing neither
C₄H₁₀ is online now Find More Posts by C₄H₁₀
Old Jan 15, 2013, 03:08 AM
Staffs, UK
Joined Nov 2003
As usual....the correct answer is "It depends". Some NiMH cells will handle 1C or even more. Some won't. And you can't tell purely by the size or capacity though the old rule that short fat ones are more likely to take high charging currents than long thin ones still works pretty well .
So try 'em at 1C and if they get really really warm...don't do it again. You probably won't have done too much harm .
Steve
slipstick is offline Find More Posts by slipstick
Old Jan 15, 2013, 03:36 AM
sub-noob
colj00's Avatar
Joined Aug 2012
Steve
i did try at 1C, its the same temperature as charging it at 1.2 amps. its a flat pack 6 cell nimh, C cells.
Question Is There A Charger That Can Charge 2 NIMH Batteries At Once? 08charger3.5 Off-road Cars 7 Nov 17, 2012 09:47 AM
Question charging at less than 1C tm77 Batteries and Chargers 3 Oct 07, 2012 10:10 PM
Discussion charging at 1c taking 2 hours mick3485 Batteries and Chargers 28 Oct 07, 2012 11:36 AM
Discussion Can you charge a 1c 3.7v LiPo on a onxy245 plane58 Batteries and Chargers 2 Sep 06, 2012 03:45 PM
Can you Charge NIMH at greater than 1C? BoneDoc Batteries and Chargers 5 Mar 19, 2005 05:55 AM
