Old Jan 14, 2013, 03:58 PM
In-Flight is offline
Find More Posts by In-Flight
United States, TX, Arlington
Joined Jan 2013
Novice wiring questions
I'm just curious how many people are using a standalone BEC for their flight controller and receivers rather than a BEC from one of the ESCs. I would assume a dedicated BEC would be ideal.
Also, does the flight controller supply power to the receiver or does that need to be wired directly to the BEC as well?
If i have it all wrong here, please let me know. I've looked at some of the wiring diagrams and while they make sense for the most part, photos usually work better than diagrams for me.
In-Flight is offline Find More Posts by In-Flight
Old Jan 14, 2013, 04:06 PM
jlouden is offline
Find More Posts by jlouden
Joined Nov 2003
I installed a standalone BEC. The BEC in my ESCs were only 2 amps and I thought that was kind of low.
The flight controller receives its power from whichever BEC you are using.
jlouden is offline Find More Posts by jlouden
Old Jan 14, 2013, 04:12 PM
Joined Jan 2013
What about the radio RX? Is that also powered by the BEC or does it get power from the flight controller connections?
Old Jan 14, 2013, 04:14 PM
Pelagic is offline
Find More Posts by Pelagic
Joined Jan 2013
I'm confused why anyone would want to use the BEC of an ESC? I've read they are less efficient than stand alone BEC's so why not always have a seperate BEC and use becless or OPTO ESC's?
Is it just to save a little weight?
Pelagic is offline Find More Posts by Pelagic
Old Jan 14, 2013, 04:18 PM
flitelab is offline
Find More Posts by flitelab
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Usually because it is simple/easy and most ESCs begin used have it already and unless you are driving servos for a gimbal the power draw of the flight controller and Rx are pretty low.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 14, 2013, 04:19 PM
Pelagic is offline
Joined Jan 2013
Maybe this helps: http://www.rcplanes4beginners.co.uk/...ng-diagram.php
Looks like it's getting it's power from the controller.
Old Jan 14, 2013, 04:20 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Most Rx get the power via the servo leads that connect it to the flight controller.
Site Sponsor
Old Jan 14, 2013, 04:22 PM
Pelagic is offline
Joined Jan 2013
Ok that makes sense. So as long as I use a seperate BEC there is no reason I couldn't use OPTO's for any copter?
Old Jan 14, 2013, 04:26 PM
Joined Jan 2013
Thanks and Thanks.
Pelagic, that image helped my understanding a bit more.
You would just connect the BEC to the battery the same way you connect the ESCs right?
And the only output from the BEC would be to the flight controller?
flitelab, thats what I assumed, but I wasn't sure. Would all leads need power or just one of them (throttle) while the rest were signal only?
Old Jan 14, 2013, 04:35 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Thanks and Thanks.
Just one of them really needs power from the ESC to the flight controller. Some flight controllers are picky about having more than one ESC connected so you may need to pull the Red lead on the others. Other boards don;t care as much and some only take power from one ESC (KK2.0)
From the Rx to Flight controller just one needed as well, but I typically run all between Rx and flight controller but you could just run the signal from the others as long as one has a full connection for the power.
Site Sponsor
Old Jan 14, 2013, 04:36 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
That is correct, no harm in using Optos. The DJI kits all have Opto ESCs for example, as they use a separate BEC/VU unit for power.
Site Sponsor
Old Jan 14, 2013, 05:21 PM
Joined Jan 2013
Any quality BEC recommendations?
Old Jan 14, 2013, 05:25 PM
flitelab is offline
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
I've been using the Hobbywing ones when required:
http://www.hobbywing.com/product_show.asp?id=209
Site Sponsor
Discussion Novice questions gwinhh Electric Competition Soaring-F5J/ALES/e-Soaring 8 Sep 29, 2012 11:21 PM
Discussion Battery and ESC wiring setup question depronair Electric Plane Talk 6 Apr 23, 2012 03:19 PM
Discussion simple question about wiring ? BillyJo FPV Talk 7 Mar 05, 2012 03:37 PM
Question Aurora 9/Optima 7 wiring questions Os7213 Hitec/Multiplex USA 7 Mar 04, 2012 11:40 PM
Help! Remzibi OSD wiring question TexasAggie FPV Talk 0 Feb 24, 2012 10:38 PM
