Old Jan 14, 2013, 03:52 PM
HelgeBe is offline
Find More Posts by HelgeBe
Steamers & Military Ships
Bergen, Norway
Joined Jul 2007
What 2.4 GHz DIY will work with Robbe Multiswitches?
Hello all,
The Robbe F14, F14N and FC16 are only sold as FM radios. These radios can be expanded by installing multiswitch modules. One module will allow you to controll for example 8 functions on one channel (on/off or proportional functions). You will also have to connect a module to the receiver.
Graupner has a similar system.
Reports on the net says that these multiswitch modules in general do not work with 2.4 GHz. It is however indicated they will work with Jeti Duplex.
Can anyone explain why these modules do not work with 2.4 Ghz, or do you know what 2.4 GHz systems in addition to Jeti that will work? Hopfully it should be FrSky.
I am not using the F-series myself, and will never do, but some of my fellow club members fancy the F14N and I would like to help them convert to 2.4 GHz.
HelgeBe
HelgeBe is offline Find More Posts by HelgeBe
Old Jan 15, 2013, 07:58 PM
rascalflyer is offline
Find More Posts by rascalflyer
Joined Jan 2013
I can assure you that the 2.4 modules will not work with the multi prop modules for the Robbe radios. You can use them but only the linear channels will work. If you want to use the multi channels modules you have to stay with FM which for boats and such is actually better. There was a guy that use to convert the robbe radios but he passed away not too long ago and he explained to me that it has to do with multiphasing the channel. I really don't remember much else but he was in pretty bad shape at the end. I prefer FM for boats myself.
rascalflyer is offline Find More Posts by rascalflyer
Old Aug 19, 2013, 05:00 PM
cheeta is offline
Find More Posts by cheeta
Joined Jul 2006
unfortanly i'm not here often.
But there is a 2.4Ghz solution.
The only kit i would say works for 100% is jeti duplex. You need the jeti box to program the receiver
settings to change:
signal: by transmitter
timebase at max 0.8 - 2.2ms if i'm right (dont have the documents here)
cheeta is offline Find More Posts by cheeta
Old Aug 23, 2013, 11:30 AM
powella is offline
Find More Posts by powella
Joined Nov 2008
Fwiw some of the Graupner HOTT radios have the functionality built in... So it should work.
powella is offline Find More Posts by powella
Old Sep 12, 2016, 01:04 PM
Kenneth Eriksson is online now
Find More Posts by Kenneth Eriksson
Sweden, Skåne County, Malmö
Joined Feb 2013
Anyone that confirm this statement?
settings to change:
Kenneth Eriksson is online now Find More Posts by Kenneth Eriksson
Sold JR 347 transmitter with receiver (TX will work with 2.4 spectrum module) flybabycx Aircraft - General - Radio Equipment (FS/W) 0 Nov 03, 2012 05:13 PM
Sold NIB Corona CT8Z DIY 2.4 GHz with CR8D Rx Lonemountain Aircraft - General - Radio Equipment (FS/W) 5 Mar 29, 2012 07:50 PM
Discussion What Rx will work with DX7 Spectrum 2.4 skylane42 Radios 2 May 12, 2011 10:28 PM
Wanted fpv system that will work with my 2.4 ghz plane bradsears Aircraft - General - Radio Equipment (FS/W) 2 Aug 24, 2010 11:53 AM
Discussion Model locator that will work with 2.4 ghz spectrum reciever chessmonster Sailplane Talk 3 Mar 31, 2009 03:25 PM
