Old Jan 14, 2013, 02:03 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
Question
diy rc vehicle design
I plan on designing my own RC SCT or truggy with aluminum or CF/GF only (a few exceptions) and wanted your opinions. for ex: what parts should be which material. CF would be the best for the base plate. Aluminum for the shafts. steel gears etc. waterproof.
another thought was having steering in the front and back. has anyone done this or bought one? I think i'd improve turns, and general stability. Although, it would need some tuning for the separate servos.
I am new to cars, but i have done my fair share of reading and watching youtube videos. Plus, im awesome at CAD.
sirbow2 is offline Find More Posts by sirbow2
Old Jan 14, 2013, 02:10 PM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Nice idea, quite an undertaking, but you sound like you could be up to the challenge.
4 wheel steering is nice for tight slow turns, but when going fast, it can actually work against you. First, you need to have the rear steering assy fully slop-free, or the car will do unwanted 180s at higher speeds. Also the added steering might increase the chance on grip-rolls, in fast corners.
Technically it's a nice feature, but if you want to go fast, it's not recommended.
SoloProFan is offline Find More Posts by SoloProFan
Old Jan 14, 2013, 02:30 PM
sirbow2 is offline
Emress
Joined Nov 2011
im probably taking this part to seriously, but i could use the servo to "lock" (use a tx switch to keep them at the correct channel value) the rear wheels. or maybe even add a mechanical lock (some sort of pin?) to protect the servo. could add some nice versatility.
Old Jan 14, 2013, 02:43 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Keeping the servo centered is only a partial solution. The steering mechanism also has slop, and this can't be locked.
Old Jan 14, 2013, 03:49 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Are you building this to race, or just as a fun thing to do? If you want to race you'll have to look at the rules for dimensions and what is and isn't allowed.
wparsons is offline Find More Posts by wparsons
Old Jan 14, 2013, 03:50 PM
sirbow2 is offline
Emress
Joined Nov 2011
now, its just for fun. maybe 1/10 scale. although that would be interesting to read. nevermind. found the roar rules
Old Jan 19, 2013, 10:33 PM
sirbow2 is offline
Emress
Joined Nov 2011
ok, i need some help :P i dont know nearly enough about rc design. i know the theory, just not the size of everything, i guess.
Old Jan 20, 2013, 12:58 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
You have the means and knowledge to manufacture your own gears etc? Did you ever build an RC car kit for instance? Perhaps you are trying to run before you can walk, at least that's the impression I get a little.
How about altering the ambitious plan of building a vehicle from scratch to modifying an existing car to 4 wheel steering instead? That way you can also see if it improves the handling by first making it stock, then starting the conversion.
Old Jan 20, 2013, 02:04 AM
sirbow2 is offline
Emress
Joined Nov 2011
means: not currently. looking for a good machine shop for my college choices as im currently a senior in high school. i have taken the PLTW courses (basically the intro eng courses in college) so i know about gear ratios, stress, strain, etc. id need small gear on the motor, big on the trany, and then maybe that same ratio again in the trany-> wheels to lower the speed. no specifics yet.
knowledge: working on it now
I was think of that with my tuirnigy SCT. the front and back are essentially the same. just no steering rods on the back. id need another front end assy and maybe some front->back drive shaft mods. and another servo. and then i thought "oh what the h*ll, i have a week before it gets here, why not do something fun"
Old Jan 20, 2013, 02:17 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Soms cars feature identical front and rear bulkheads. The LRP Blast series for instances are pretty much identical front and rear, such a vehicle would be more easy to convert to 4 wheel steering.
As for gear ratios, you could look at existing brands. Some print the final drive ratio for each pinion gear in their manuals, combined with pinion teeth count and spur gear count you can calculate the transmission ratio for the section after the spur. Mostly this is around 2.92 : 1 but it can vary a little, depending on wheel size for instance. Bigger wheels require more torque.
Old Jan 22, 2013, 06:27 AM
remondo is offline
Find More Posts by remondo
remondo's Avatar
Joined Nov 2005
It seems your skills may be valuable to the OpenRC project- an almost fully printable RC truggy. I have just posted a thread trying to gather some great minds to help finish the project, is this something you would be interested in? The design files can be downloaded here http://www.thingiverse.com/thing:42198
remondo is offline Find More Posts by remondo
Old Jan 23, 2013, 08:06 PM
rustlererad3 is offline
Find More Posts by rustlererad3
Outdoor Extremist
rustlererad3's Avatar
Pennsylvania
Joined Jul 2010
are you going for four wheel drive or rear wheel drive
rustlererad3 is offline Find More Posts by rustlererad3
Old Jan 23, 2013, 08:10 PM
sirbow2 is offline
Emress
Joined Nov 2011
i haven't even got to where it matters whether i do or not in my design, but it would be significantly easier for designing. might as well do rear only now. good tip
Old Jan 23, 2013, 09:46 PM
Outdoor Extremist
Pennsylvania
Joined Jul 2010
your welcome and i would think a mid mounted or rear mounted trans would be easier too
Old Jan 23, 2013, 10:36 PM
sirbow2 is offline
Emress
Joined Nov 2011
going off that. i have a question. in a typical rc SCT, rally or whatever, is the diff used for gear reduction also, or is just the spur gear?
Poll Do you think a chief designer of RC planes can design and build real plane? jcervantes11 Chit Chat 31 Mar 17, 2014 08:45 PM
For Sale allot of rc vehicles. nitro and brushless. jared86 Cars - Cars and Parts (FS/W) 0 Nov 05, 2012 11:00 AM
For Sale rc vehicles for sale or trade jared86 Cars - Trucks and Parts (FS/W) 1 Nov 05, 2012 10:57 AM
Build Log Neill's DIY Gimbal Design BIGTACO Multirotor Talk 2 Jul 26, 2012 11:13 AM
Yippee! Free Sumo RC Truggy with purchase of Redcat XTE Vehicle! Goanna Keyporthobbies.com 0 May 12, 2012 01:08 PM
