Old Jan 14, 2013, 02:45 PM
FloridaFlyBob is online now
Find More Posts by FloridaFlyBob
FloridaFlyBob's Avatar
United States, FL, Fort Myers
Joined Nov 2011
4 servo Wing Biplane on a DX8
I've been doing some research on how to set up the servos on a 1/5 Waco Biplane and have been getting conflicting opions. I have a AR8000 rx, and I have it set up now as a 2 servo wing and a 2 servo elevator. The rudder is a pull/pull on 1 channel. I have my kill switch on the gear channel and the aileron on the top wing on one channel with a Y and the lower wing on another channel with another Y which uses all the channels I have on the RX. The DX8 doesn't support 4 servo wings and I wouldn't have enough channels anyway. The servos are HS625mg's except the rudder is a hs5965mg. I know I can use matchbox's with would be another $150 for 2. What is the down side of using 2 Y's on the wings. Each control surface has 1 servo so there won't be 2 fighting each other. The HS625mg servos are analog servos
FloridaFlyBob is online now Find More Posts by FloridaFlyBob
Old Jan 14, 2013, 11:46 PM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
The only advantage I can see to using the matchbox is the ability to fine tune subtrim and endpoints but I doubt there would be enough difference to matter. I would just use the Y.
600Bob is offline Find More Posts by 600Bob
Old Jan 15, 2013, 05:55 AM
Joined Nov 2011
Thanks bob, I didnt think with 8 channels i would need more, but 18 would be nice.
Old Jan 15, 2013, 10:24 AM
Ken Barnes is offline
Find More Posts by Ken Barnes
S.F. Bay Area, California, USA
Joined May 2005
Originally Posted by rstekeur View Post
I've been doing some research on how to set up the servos on a 1/5 Waco Biplane and have been getting conflicting opions. I have a AR8000 rx, and I have it set up now as a 2 servo wing and a 2 servo elevator. The rudder is a pull/pull on 1 channel. I have my kill switch on the gear channel and the aileron on the top wing on one channel with a Y and the lower wing on another channel with another Y which uses all the channels I have on the RX. The DX8 doesn't support 4 servo wings and I wouldn't have enough channels anyway. (deleted)
Remenber, that when a transmitter supports a 4 servo wing that refers to a wing with 4 servos operating the following surfaces........ left aileron, left flap, right flap, right aileron. It doesn't mean a biplane with 2 left ailerons, and 2 right ailerons.
Ken
Ken Barnes is offline Find More Posts by Ken Barnes
Old Jan 15, 2013, 08:58 PM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
I set up my pitts python just as you have and have never had an issue lower on a channel and the upper wing on another...I am a Futaba guy I think I am 1 and 6
jetmech05 is offline Find More Posts by jetmech05
Old Jan 15, 2013, 10:53 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
I fly a GP Giant Aeromaster with a DX8. I run all 4 ailerons on a single channel with a double "Y". I fly most everyday for several months and never had a problem with it.
BTW, the servos are HS 625mg's
Fokker DII is offline Find More Posts by Fokker DII
Old Jan 16, 2013, 09:05 AM
Jacksonville Fla.
Joined Mar 2007
You can fly off of a single channel.....but with two channels if you loose a y you still have some ailerons
Old Jan 16, 2013, 10:49 AM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I use dual Y's on my sig sundancer, 4 servo ailerons. Works fine. But I also do it using a split power bus. The servos are on a separate battery. Receiver has a dedicated battery. No ignition, G-62 mag.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Jan 16, 2013, 02:57 PM
Joined Nov 2011
I have the top wing on 1 channel and the bottom wing on the other. I feel safer with 2
Old Jan 16, 2013, 09:18 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
+1. whatever you are most comfortable with works best for you.
Discussion Spektrum DX8 on 4 digit electric glider any good? arobotbrain Electric Plane Talk 11 Jul 27, 2012 05:11 PM
Question Tips on installing the top wing on a biplane with only two hands? 56S Scale Kit/Scratch Built 6 Jan 09, 2009 12:46 PM
Discussion Throttle on Ch3 with 4-Servo Wing FlyingW Radios 4 Jul 21, 2006 04:34 PM
Graphite 3.1m full D-box (4 servo wing) versus Graphite 3.45m D-box (4 servo wing)? bfraser Electric Sailplanes 9 Jul 07, 2003 01:44 PM
9Z and butterfly help on 4 servo wing. Giovanni Day Electric Sailplanes 0 Jul 28, 2002 01:44 AM
