Old Jan 14, 2013, 02:35 PM
JimHSoars is offline
Find More Posts by JimHSoars
Do Not Feed The TROLLES!
United States, OK, Tulsa
Joined Jun 2003
Powerlab 6 or Powerlab 8?
Hi Guys:
Does anyone know if there is a PL6 vs PL8 features thread or post someplace on RCG?
Threads with PowerLab 6 vs PowerLab 8 comparisons:Thanks to all of you who replied.
- Jim
JimHSoars is offline Find More Posts by JimHSoars
Last edited by JimHSoars; Jan 16, 2013 at 01:27 PM. Reason: Added list of comparison sites to post #1.
Old Jan 14, 2013, 02:53 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
If you scroll down past the Quick Reply box beneath this thread, you'll see a couple of discussion threads about PL6 and PL8
abenn is offline Find More Posts by abenn
Old Jan 14, 2013, 04:49 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Software features wise they are identical I believe. The main difference is their input and charging power and of course 6s vs 8s.
Revolectrix has a comparison page:
http://www.revolectrix.com/product_selector.htm
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 14, 2013, 05:18 PM
Joined Jun 2003
Thanks guys!
Old Jan 14, 2013, 07:12 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
There is one difference to consider between them.
The PL6 does not support balance tap only charging, the PL8 does.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jan 14, 2013, 07:15 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
One very important thing that’s not is the comparison is balance current. If you charge large packs at high C you sometimes need a high balance current. Not sure about the PL6 but my PL8 V2 has up to 1 amp for each cell and each preset can have a different max value if you like. There are so many features and settings that you really have to own one to appreciate all the features. If you get one be sure and get the PC interface. It adds a whole additional level of flexibility and ease of use.
RC Man is online now Find More Posts by RC Man
Old Jan 14, 2013, 09:30 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
I've answered this question a few times and decided to just add an PL6/PL8 FAQ to the FMA subforum.
http://www.rcgroups.com/forums/showt...7#post23817006
Let me know if that doesn't address the question and I change, or add to it.
Gregor99 is offline Find More Posts by Gregor99
Old Jan 15, 2013, 11:34 AM
United States, MN
Joined Feb 2011
I have to wonder what it would take for them to make a PL8 approximately the same size as the PL6. I have to think the majority of the size difference is the increased discharge capacity (which I don't need).
I want a PL6 but have a hard time swallowing the poor voltage range support. 408W on 12V isn't great for field charging from deep cycle.
Old Jan 15, 2013, 12:59 PM
United States
Joined Feb 2001
Most put two 12v batteries in series for high wattage charging.
Old Jan 15, 2013, 01:35 PM
United States, MN
Joined Feb 2011
I would sooner buy a generator then lug around 2 batteries. One deep cycle has enough capacity for me.
Old Jan 15, 2013, 01:45 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Heat is generated during charging as well as during discharging and keeping electronics cooler adds to thier service life in most all cases. Building chargers with mininum heat sinking and cooling causes way to many problems. One of the very popular charger lines is fairly well noted for developing issues if operated at anywhere near thier rated max. discharge rates.
I feel the 12V or even 24V power levels should be takem with a grain of salt if one is using deep cycles that are not under constant charge as voltage drop can be rather serious at 20,30,40,50,60 amps. Many try to get by with lower Ah Pbs that likely will quickly fall to 11V or less under serious loads.
Powerlab 6 was developed and released to be cost competitive with some of the other charger for those who felt the Powerlab 8 was just to much charger for thier needs and budget.
I casualy questioned the logic of a PL6 as I had no idea it could be pulled off at the reduced price point that it was.
Charles
Old Jan 15, 2013, 02:30 PM
United States, MN
Joined Feb 2011
The price point confuses me a little as well when you look at the price of the 10XP. Only $15 price difference between those two just doesn't make sense to me.
Old Jan 15, 2013, 03:01 PM
Gregor99 is offline
Seattle
Joined Sep 2007
Really, two different chargers. The Cellpro10 platform is smaller sized but goes up to 10s and has dual port safe serial charging. There are some modelers that prefer to charge serially, up to 10s and this works well for that scenario. I have an old Cellpro10s and I still enjoy using it charge some of my 3s packs (two at a time) which do not do well when parallel charged.
Old Jan 16, 2013, 07:02 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I suspect the Cellpro 10 series is very popular with the pattern guys who fly a lot of 10s packs almost exclusively.
Ohmic is offline Find More Posts by Ohmic
Old Jan 16, 2013, 10:12 AM
United States, MN
Joined Feb 2011
I actually got into 1/10 car racing recently and was shocked at just how many Cellpro 10S I see at the track. It's the most common charger there without a doubt.
Discussion Powerlab 6 and 8 ryanbe15 Batteries and Chargers 17 Dec 03, 2012 04:43 PM
Wanted PowerLab 6 or PowerLab 8 v2 Charger JC Spohr Aircraft - Electric - Batteries & Chargers (FS/W) 2 May 08, 2012 09:54 AM
Wanted iCharger 306B or PowerLab 6 or Similar 30 Amp Charger JC Spohr Aircraft - Electric - Batteries & Chargers (FS/W) 1 May 05, 2012 03:32 PM
Discussion Powerlab 8 and powerlab 6 ndamico FMA Direct 2 Apr 22, 2012 12:03 PM
