Old Jan 14, 2013, 12:58 PM
calle3 is offline
Find More Posts by calle3
Joined Sep 2009
Help!
Motor/ESC problem after soldering?? low beeps and motor wont start
I have convertet my mCPX V2 to brushless with a PnP fra Hawk RC.... but i didnt like all the long wires and extra connectors so I shorten them and soldered instead..
before soldring the motor to ESC everything worked perfekt :-)
hmmmm, just soldered my c05m motor directly to the XP-7A ESC
ESC initialized ok, and I can go in programming mode too..... but the beeps a very low now, I nearly cant hear them!!!
And the motor don't start...it just go like 1 round and ESC just start beeping fast rapidly, when I give throttle..
Iam thinking... iam not the best to solder ... lets say the is a little connection between to motor wires??? what will happened?? and what if one connection is bad??
update: I have now disconnected the motor from ESC... how can I test if it is the motor or the ESC is bad?? i have no extra motor or ESC :-(
calle3 is offline Find More Posts by calle3
Discussion blitzwork f-18 70mm ESC beeping (receiver wont turn on)FIX! Ziffnab Foamy EDFs 1 Feb 04, 2014 12:45 AM
Discussion ESC stuck at start up beep StewieRC Electric Plane Talk 16 Jun 07, 2012 04:54 PM
Help! ESC beeping but motor wont work..HELP! Johannez Power Systems 5 May 13, 2012 08:11 AM
Help! mystery 30A ESC beep beep beep rapidly.. having problems stevel48 Mini Helis 16 Sep 11, 2008 12:01 PM
Discussion [BCP] Motor wont start after Freestyle belt upgrade TrickyFishy Micro Helis 11 Aug 21, 2007 08:29 PM
