Old Jan 14, 2013, 06:37 AM
bmwbob is offline
Find More Posts by bmwbob
Cocoa, Florida
Joined Dec 2001
Hobby King tunnel hull boat
I finally have both a motor and speed controller in the boat that are holding up.
Now, the flex shaft in the dummy outboard has broken near the center.
I have pulled and greased the shaft with Prather marine grease after each outing, so a lack of lube wasn't the issue.
Can anyone tell me where I can obtain some of that (slightly smaller than) 1/8" diameter flex cable?
Lacking that, can you point me to a link for those aftermarket aluminum outboard lower units that the racers use?
I'm pretty sure those items will cost more than I want to put into this "money pit" boat, but it will be worth a look.
NOTE: I did find the outboard "leg" on the Pro Boats site, but it is for a larger boat than I have.
My motor has a 3mm shaft.
Thanks!
Bob
bmwbob is offline Find More Posts by bmwbob
Last edited by bmwbob; Jan 14, 2013 at 06:59 AM. Reason: Added note about boat and motor size
Old Jan 14, 2013, 08:32 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Something like this is worth looking at too:
http://www.offshoreelectrics.com/pro...prod=OSE-80980
I believe there's a guy on here running one of these with good success on the HK Hornet tunnel.
wparsons is offline Find More Posts by wparsons
Old Jan 14, 2013, 09:32 AM
bmwbob is offline
Cocoa, Florida
Joined Dec 2001
Flex cable size needed
That mini-outboard looks great!
Too bad I already have a motor!
I just measured the diameter of my broken flex cable .
It is 0.12", or 3 mm.
The length is approximately 4.75".
Bob
Old Jan 14, 2013, 10:49 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I'm not sure where you might find replacement flexes for that lower unit. I think that's the reason people have gone to other lower units instead.
Old Jan 14, 2013, 10:58 AM
bmwbob is offline
Cocoa, Florida
Joined Dec 2001
No surprise!
That would be about par for my experience with products from this company.
I haven't had any trouble with the LiPo batteries, balance charge or R/C equipment I got from Hobby King, but the boat electronics, speed control, motors, etc. have been pure JUNK!!!
Bob
Old Jan 14, 2013, 01:01 PM
Firehawk989 is offline
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
Bob
The cheap stock ESC's you get with most chinese boats tend to be pretty useless, but some of HK's stuff can be pretty darn good. I have 2 Seaking 35A's and they have both been fantastic for my small boats. The motor I purchased from them has been great as well. Hobbyking tends to re-brand some things, and I suspect they have no control over what the original company supplies with the kit. The parts they sell separately tend to be generally good in my experience anyway. I think the key is to pay attention to the reviews.
Firehawk989 is offline Find More Posts by Firehawk989
Old Jan 14, 2013, 01:19 PM
bmwbob is offline
Cocoa, Florida
Joined Dec 2001
Sea King parts
Yes, I have a Sea King 90 controller now, as well as a Sea King motor (don't recall the numbers).
They are both fine, but I got them from Hobby Wing, not Hobby King.
Bob
Old Jan 14, 2013, 03:10 PM
Vancouver, BC
Joined Aug 2009
Also, for your flex problem, you should be able to find a 3mm flex cable somewhere. (Hobbyking, EBay, what have you.) It will probably be longer than you need, but you might be able to get 2 out of it if you cut it in half and solder your own stubs on. Just a thought.
Old Jan 14, 2013, 03:28 PM
bmwbob is offline
Cocoa, Florida
Joined Dec 2001
3mm flex cable
That was my intention.
I have found .098" and .15"and larger flex, but no .12" (3mm) as yet.
Bob
Old Jan 14, 2013, 03:48 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Outboards tend to use flex cables with square ends on both ends that fit into the stub shaft and motor coupler so it's harder to fit a generic cable into them.
Old Jan 14, 2013, 04:30 PM
triumphjon is offline
Find More Posts by triumphjon
United Kingdom, England, Southsea
Joined Apr 2011
just a thought , weve a company in the uk called speedy cables , they make speedometer cables for classic / vintage vehicles to order or from pattern , i would imagine there will be similar companies on your side of the pond too ?
triumphjon is offline Find More Posts by triumphjon
Old Jan 14, 2013, 05:34 PM
Vancouver, BC
Joined Aug 2009
Here's a 3mm flex from Hobbyking:
http://www.hobbyking.com/hobbyking/s...Magic_Cat.html
Edit: Ah, didn't notice the backorder. But at least they do exist.
Double Edit: Even better: http://www.ebay.com/itm/3mm-Dia-Spri...item1e75194ebd
Old Jan 14, 2013, 07:21 PM
bmwbob is offline
Cocoa, Florida
Joined Dec 2001
Cable is round
The cable is just round. They soldered the motor coupler end solid, then filed a flat on it for the setscrew.
The other end is soldered into the hollow end of the prop driver.
Bob
Old Jan 14, 2013, 07:28 PM
bmwbob is offline
Cocoa, Florida
Joined Dec 2001
Goal!!!!
Thanks!
I just ordered it.
Bob
Old Jan 14, 2013, 07:54 PM
Vancouver, BC
Joined Aug 2009
Thanks!
I just ordered it.
Bob
No prob! At 39" long, you should be able to make a few spares.
Sold Prather Lap Cat Racing 32" Tunnel Hull Boat $425.00 Azzmonkey Boats (FS/W) 4 Oct 04, 2012 07:14 PM
Discussion Hobby King Surge Crusher Brushless Twin-Hull R/C Boat (730mm) Texasredrider Racing Boats - Electric 37 Jul 18, 2012 03:30 PM
Cool Hobby king now offers a 1/8 Hydro and Tunnel............!! scorpion1 Racing Boats - Electric 3 May 24, 2012 07:29 AM
For Sale Hobby King "Hornet" electric tunnel hull boat bmwbob Boats (FS/W) 17 May 21, 2012 11:50 AM
Discussion A new Tunnel Hull boat from Pro Boat James K.G. Racing Boats - Electric 1 Jun 16, 2010 04:29 AM
