This thread is privately moderated by mikefromgermany, who may elect to delete unwanted replies.
Old Jan 14, 2013, 04:16 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Gallery
Hubsan X4 illuminated 1.0
The Hubsan X4 is the smallest RTF quad on the market (yet).
Due to its size (or lack of) and colour it has a quite low visual profile.
So flying outside - where it belongs - it is really missing some navlights.
This is my simple solution, I took:
  • 4x 0603 LEDs: 2x blue, 2x red
  • 2x resistors: 1x 22 Ω, 1x 47Ω
  • 32 gauge magnet wire
Soldering the 0603 LED was a pain in the **s
Wired according to following pictures:
The result surpassed all expectations:
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Jan 21, 2013, 07:27 AM
davidevo50 is offline
Find More Posts by davidevo50
Canada, QC, Montreal
Joined Feb 2007
Well done Mike! Could you post where you got your parts?
Thanks!
davidevo50 is offline Find More Posts by davidevo50
Old Jan 21, 2013, 07:33 AM
Germany, Berlin
Joined Jun 2012
Thanks!
Ebay.
search terms: "0603 LED", "resistors", "magnet wire"
-mike-
Old Jan 27, 2013, 07:32 PM
Globel is offline
Find More Posts by Globel
Joined Jan 2013
are these SMD 0603 LED ? like these?
http://www.ebay.com/itm/50-SMD-0603-...item19bafc93b2
Globel is offline Find More Posts by Globel
Old Jan 27, 2013, 11:18 PM
Germany, Berlin
Joined Jun 2012
Yes, they are. If you are unsure to solder these - try getting prewired SMDs like these:
http://www.ebay.com/itm/10x-SMD-LED-...item5650cd2fee
-mike-
Old Jan 29, 2013, 03:43 PM
ogrope1 is online now
Find More Posts by ogrope1
ogrope1's Avatar
France, IdF, Paris
Joined Oct 2011
-mike-
Great find mike!!! I looked into your "simple wiring" pic but cant' really understand it. I' m looking for an easier setup since I'm a total noob with LEDs and resistors. Do you think I could use these : http://cgi.ebay.fr/ws/eBayISAPI.dll?...84.m1423.l2649
hook them up in series with this resistor http://cgi.ebay.fr/ws/eBayISAPI.dll?...84.m1423.l2649 ?
I' ve looked at a couple videos on how to hook those things up but I need to keep it very simple for now even If some LEDs are dimmer it doesn't matter
ogrope1 is online now Find More Posts by ogrope1
Old Jan 29, 2013, 04:10 PM
Germany, Berlin
Joined Jun 2012
the LEDs look fine. using 470 Ohm resistors the LED will not even glow.
stay with the values I wrote if you hook up each colour parallel.
if you want to use 4 resistors - so for everysingle LED one you will need:
for the red LED: 82 Ohm 1/4 or 1/8 W
for the blue one: 40-47 Ohm 1/4 or 1/8 W
cheap carbon film resistors are sufficient.
Hope this helps
-mike-
Old Jan 29, 2013, 04:48 PM
Joined Feb 2007
Mike, is there a perticular value for the resistor used for a white led?
Thanks again
David
Old Jan 29, 2013, 05:09 PM
Germany, Berlin
Joined Jun 2012
Thanks again
David
Should be the same as for the blue ones.
You may calculate it for yourself:
http://led.linear1.org/led.wiz
BTW - some useful reading, there, too
-mike-
Old Jan 29, 2013, 05:39 PM
Joined Feb 2007
Cool, thanks!
Old Jan 29, 2013, 07:13 PM
ogrope1's Avatar
France, IdF, Paris
Joined Oct 2011
Hope this helps
-mike-
Superb, many thanks!!!
Old Feb 14, 2013, 10:43 PM
jason4207 is offline
Find More Posts by jason4207
Eye to the sky!
jason4207's Avatar
United States, NC, Concord
Joined Dec 2012
Hey Mike,
I have harvested a white LED from a Mini-Pet arm, and want to use it as a tail light for my X4. On the MP it plugs right into the FCB, but I'm thinking there might be resistance built into the FCB to handle it properly.
I did a quick test on a spare battery I have and the LED lit up nice and bright, but I think I might be over driving it like that.
Do you know if I need a resistor for this LED? If so, is it an ~47Ohm resistor that I need?
I'm not sure how to confirm the specs on this LED. I have a DMM if there is any way for me to test it to figure it out.
Name: X4 Tail Light LED.jpg
Description:
Jason
jason4207 is offline Find More Posts by jason4207
Old Feb 15, 2013, 01:35 PM
Germany, Berlin
Joined Jun 2012
Originally Posted by jason4207 View Post
.... Do you know if I need a resistor for this LED? If so, is it an ~47Ohm resistor that I need?
Jason
Hi Jason!
White LED need a forward voltage of 3.0 - 3.4 V @ 20mA
If you do some calculating here
you get values between 39 and 47 Ohms.
I prefer the higher value if I'm in doubt - the 47Ohm resistor will allow your LED to burn bright and fade a LITTLE the last 2 minutes until LVC.
to check take your DMM and get the real current of your actual resistor/LED/batt combination. It should not be much over 20mA with fresh charged batt.
-mike-
Old Feb 16, 2013, 03:25 AM
Eye to the sky!
jason4207's Avatar
Joined Dec 2012
Thanks Mike! I used the calculator already, but wasn't sure if the extra resistance might be built-in to this particular LED. I assumed it was built into the MP FCB, but wanted to be sure.
I was contemplating...Since the MP has white LEDs on 1 side and red/blue flashing LEDs on the other I thought that you might be able to switch them w/o any problems...basically the extra resistance/smarts would be built into the LED so that you could swap them to any corner to suit your taste w/o having issues. If it's built into the FCB I don't think that would be possible.
What do you think?
Old Feb 16, 2013, 04:37 PM
Germany, Berlin
Joined Jun 2012
What do you think?
The FCB will regulate the current needed - there are no regular LEDs with inbuilt resistors.so simply swapping the leds over shouldn't make problems. As you have a DMM - just try and read the current - itīs part of the fun
-mike-
Discussion Dealer list for Hubsan X4 Family (H107/H107L/H107C/H107D) and spareparts! bangkomit Mini Multirotors 519 Sep 24, 2015 02:12 AM
Discussion RC Logger Eye One, Hubsan X4, Heli-max 1 SQ, Walkera QR Infra X Torch8 Mini Multirotors 4 Feb 15, 2013 09:58 AM
Sold 1 LEFT!! Hubsan X4 mcashatt Aircraft - Electric - Multirotor (FS/W) 0 Dec 08, 2012 03:23 PM
Discussion Hubsan x4 vs Heli-Max 1 SQ Guad Torch8 Mini Multirotors 9 Oct 05, 2012 09:47 AM
For Sale MultiWii Nano Control Board (2.1 grams), BL Motors x4, ESCs x4, Receiver, and More boredom.is.me Aircraft - Electric - Multirotor (FS/W) 3 Jun 07, 2012 03:20 PM
