Old Jan 14, 2013, 01:37 AM
mongdex is offline
Find More Posts by mongdex
If it flies, I like it.
Thailand, Sing Buri, In Buri
Joined May 2012
How to make a very thin, airfoil wing?
Hi,
I would like to make a very thin airfoil wing for a pylon racer. I have made Armin wings before with a thicker airfoil. I would like to step the lift down and make smaller airfoil wings for faster planes. Can anyone tell me how to make thin airfoils out of foam board?
Thanks in advance.
mongdex is offline Find More Posts by mongdex
Old Jan 14, 2013, 07:08 AM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
I guess you'd need to form a solid foam wing with a full-depth spar (or spars) and cover it with epoxy-glass or similar.
Paper covering stuck of with WBPU would also work well.
Whiskers is online now Find More Posts by Whiskers
Old Jan 14, 2013, 07:46 AM
RWData is offline
Find More Posts by RWData
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
How about 3mm depron with KFm2 ?
A 4mm x 1mm carbon flat spar just behind the top 3mm depron (so 1mm into lower main wing sheet). Cover with brightly coloured packing tape to add strength. What about some pictures of your build
RWData is offline Find More Posts by RWData
Old Jan 14, 2013, 08:10 AM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
I have had good luck on my last few builds by sanding an airfoil into a wing cut from 6mm Depron. First I embed a carbon fiber spar into the bottom of the wing and then start the sanding. I start with 80 grit paper on a half sheet sanding block as used on drywall seams. Round the leading edge about 25% of the cord back on the top and taper the rear 60% to a thin trailing edge. Cover the bottom with 3/4 oz fiberglass cloth wrapping about 13mm around the leading edge onto the top surface. I use water based polyurathane rather than epoxy to save weight and work. After the bottom is dry feather out the edge of the glass on the top surface and cover the top wrapping around the leading edge about 13mm onto the bottom. This gives a double layer on the leading edge for a bit more ding resistance. This has worked well on small wings up to about 22-24 inches. The actual airfoil is not all that critical at these sizes but try to keep the left and right panels symetrical.
Dr John
pmpjohn is offline Find More Posts by pmpjohn
Old Jan 14, 2013, 09:05 AM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Start on page 2 and begin reading http://www.rcgroups.com/forums/showt...1504266&page=2
Wilfor is offline Find More Posts by Wilfor
Old Jan 14, 2013, 09:40 AM
grant31781 is offline
Find More Posts by grant31781
United States, GA, Americus
Joined Jun 2003
http://www.rcgroups.com/forums/showthread.php?t=1802556
You can follow the same method but do away with the foam spar and Use the CF for the spar. You will have to use the CF or the wing will fold up when that thin.
grant31781 is offline Find More Posts by grant31781
Old Jan 14, 2013, 03:09 PM
Whiskers's Avatar
Joined Feb 2010
Originally Posted by Wilfor View Post
A master class, right there...
Old Jan 15, 2013, 05:32 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
I have built both wings for different planes ,the master freddie's wing was great for my BD-5 wing because its a thin airfoil and the other wing is great for thicker ones on their planes like my das canard stick iam scratch building. joe
cracksmeup is offline Find More Posts by cracksmeup
Discussion How do I make a flying wing fly knife edge? Evil Twin Flying Wings 11 May 11, 2013 05:13 AM
Discussion How to make thinned goop? chopperdoc Flying Wings 3 May 22, 2012 10:33 PM
Discussion How to make perfect wing rib.... schusterjo The Builders Workshop 22 May 21, 2012 11:24 PM
Question How to make an airfoil in speed position? soholingo Hand Launch 2 Apr 23, 2012 08:23 AM
Discussion how do you make a foam wing airfoil??? helivsFMX Foamies (Scratchbuilt) 11 Aug 29, 2009 07:34 PM
