Old Feb 05, 2013, 06:00 PM
NighthawkF-117 is offline
Find More Posts by NighthawkF-117
Registered DLG addict
NighthawkF-117's Avatar
Minnesota
Joined Jan 2009
I would stay away from blue foam as I've heard when you cut a core with it, it likes to warp. This is due to the way it is extruded at the factory. I use pink foam and have never had any problems with warping or strength.
NighthawkF-117 is offline Find More Posts by NighthawkF-117
Old Feb 05, 2013, 06:26 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I have cut plenty of blue foam cores, and none of them warped.
Its not the color of the foam that causes warps.
R,
Target
target is offline Find More Posts by target
Old Feb 05, 2013, 06:29 PM
G Norsworthy is online now
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
I've been skinning 1/8" off the top and bottom of the blanks before cutting the cores. Most of the residual stress is in the skin and if you take that off it should not warp.
G Norsworthy is online now Find More Posts by G Norsworthy
Old Feb 05, 2013, 06:36 PM
Master of the Wind
Joined Sep 2008
All the really big planes I have built were made with 40 lb foam from Whitecap. I would be reluctant to make something this big with 25 lb foam as the finger dent resistance is not that good. 60lb will work also but is trickier to cut.
http://www.rcgroups.com/forums/showthread.php?t=1256550
http://www.rcgroups.com/forums/showthread.php?t=1073259
Also check out this thread for how to make a big hi aspect wing.
http://www.rcgroups.com/forums/showthread.php?t=1149551
Old Feb 05, 2013, 06:37 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
+1.
Also, using the least thick plank of foam that suits your needs is helpful as well.
If a plank seems curved before using for a wing core, I usually find the concave side and sand the high edges a bit with some 60grt on a block, until it sits well on the bench.
Then, slice off the convex top to flatten it.
Then, flip over and slice off a bit more to flatten that.
Then you should have a true, flat, relaxed blank to work with.
It does appear that the pink foam of the same density both cuts better and produces less hairs than the blue foam though....
R,
Target
Old Feb 05, 2013, 07:47 PM
DLGjunkyard is online now
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
What he said This is good practice with most any material you want to shave down . Even with metal on a mill
DLGjunkyard is online now Find More Posts by DLGjunkyard
Question Balsa sheeting foam core wings vs just glassing. erh7771 Scratchbuilt EDFs 74 Mar 14, 2016 10:40 PM
Discussion Making a foam cored wing using 2-part rigid polyurethane foam in the mould. AvB Composites Fabrication 272 Nov 10, 2014 11:58 PM
Discussion Resources for Foam-Core Vac Bagging acetech09 Composites Fabrication 10 Sep 16, 2012 01:07 PM
Discussion Joinable foam core wings digiex_chris The Builders Workshop 4 Apr 10, 2012 11:46 AM
