Old Nov 21, 2001, 06:33 PM
Tom Viper is offline
Find More Posts by Tom Viper
Joined Nov 2001
eLMH110 flight times? What to expect?
How long can the LMH110 fly on a standard 17 turn car engine?
Iīm using the Speed 500 SP and I only get around 3 minutes on my new 7x1400 SRC cells.
Tom Viper is offline Find More Posts by Tom Viper
Old Nov 21, 2001, 08:26 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
On a 17 turn, if you were to gear for 8 cells and use 1400AE cells, you should get about 5-6 minutes I would think. THis based on my tests with a 16T and a 19T motor and 8x1400AE cells.
Good luck and let us know how it goes!
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Nov 22, 2001, 08:36 AM
Joined Nov 2001
Whops, that time wasīnt real true, today i went flying outside, it was blowing "too" much, but i couldīnt wait for a calm day... And guess what, in thoose bad conditions i flew it "hard" for 5 minutes, and did some hoover for the last minute.
It seems that the NiCadīs just needed some recycling before performance went up.
But it also seems that it will need more power flying indoors on low altitude (just 1 meter over ground), then flying outside in cold wheather and 5 meter altitude? It flew perfect even in theese harsh conditions! Wow, i really gonna like this (lite) machine.
I flew it 5 times, then I was to cold to continue, its 4 degrees C outside and blows, so....
Old Nov 22, 2001, 10:23 AM
Agra, Oklahoma
Joined Feb 2000
Flight times will increase with forward flight (or in this case windy conditions). On a calm day, fly it until it won't get out of ground effect, then put it into forward flight - you will find it going up.
Have fun!
Steve
Old Nov 22, 2001, 10:08 PM
Fred Bronk is online now
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
You said you are using 1400SCR cells? Are these older car sub C cells or are they 1400AE "A" size cells?
If you are using sub C cells, you should go to the 2400 if you stay in that size, or try the CP1700 cells, which will save you a couple ozs.
The "A" 1400 cells are being pushed a little with a S500, the CP1700's will handle the draw fine.
AUW is critical in something like the LMH and you should be getting around 5 minutes.
Fred Bronk is online now Find More Posts by Fred Bronk
How do you measure what your flight times will be? Mike Parsons Batteries and Chargers 7 Jul 15, 2003 10:43 AM
What flight durations can I expect from an electric? konaboy Beginner Training Area (Aircraft-Electric) 10 Nov 18, 2002 10:40 AM
What flight durations can I expect with a slowflyer? konaboy Parkflyers 7 Nov 13, 2002 04:42 AM
What to Expect: Increasing Static Thrust Over In Flight Thrust kelvin Power Systems 11 Jul 13, 2002 07:46 AM
First Parkflyer flight! What to expect? brudford Parkflyers 1 Apr 06, 2002 09:08 PM
