Old Jan 13, 2013, 08:25 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
FPV on a budget? Hook me up if you can!
I've got a fairly decent flying hexacopter going right now as part of an independent study course for school, and they just approved me for $300 for an FPV system.
I already have a gopro which I believe I can tap off of, so does anyone have suggestions for a good solid system (as in everything I need, from goggles or a ground station to tx/rx and anything extra) that will work?
I'm flying on a JR X9303 2.4 right now, and in terms of range I want as much as I can get, but right now I can't see flying more than a mile out, though I'd like the capability of course.
If anyone can point me in the right direction it's be great, there's just an absolutely overwhelming array of information out there. Thanks!!
Endlesslag is offline Find More Posts by Endlesslag
Old Jan 13, 2013, 08:33 PM
jolyboy is offline
Find More Posts by jolyboy
Australia, NSW, Sydney
Joined Sep 2012
Fatshark Predator costs $300 and gives you everything you need to fly FPV. No soldering, just plug and play
jolyboy is offline Find More Posts by jolyboy
Old Jan 13, 2013, 08:36 PM
Ascended is offline
Find More Posts by Ascended
Ascended's Avatar
Canada, AB, Calgary
Joined May 2012
You'll need to use a screen for a <$300 system. Goggles are simply too expensive.
http://www.readymaderc.com/store/ind...ex&cPath=11_22
http://www.hobbyking.com/hobbyking/s...ansmitter.html + http://www.hobbyking.com/hobbyking/s..._Receiver.html will give you more range than the 600mw immersionrc system.
Ascended is offline Find More Posts by Ascended
Old Jan 13, 2013, 08:47 PM
Endlesslag's Avatar
Joined Jan 2011
For the fatshark predator, what kind of range are we talking? I've heard that 5.8 can have some issues sometimes, and by nature has bad object penetration.
Assuming it was set up correctly, what kind of ballpark range would I be getting?
Old Jan 13, 2013, 09:57 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
range is 100% dependent on your antenna. With an omni, probably 1 miles tops. With a patch a couple miles or more. With a high gain antenna, farther than you'll be flying any time soon lol.
Also depends on your environment. MUCH shorter (<1mile) in urban locations, and much much farther in farmland. Depends on the humidity in the air too, alignment of the stars, what you had for breakfast, etc.
ashdec87 is offline Find More Posts by ashdec87
Old Jan 13, 2013, 10:02 PM
Endlesslag's Avatar
Joined Jan 2011
Gotcha. Well with the stock amtenna I should be good for a while, and if I'm reading right I can always swap the antenna or if I want I can get a totally different Vtx/Rx and pipe that into the goggles, correct?
That might be the way to go, and keep it clean and simple. I can go for the high performance stuff later, for right now It'll just be nice to be able to frame shots and such for the gopro.
Old Jan 13, 2013, 11:25 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Get the V2 predators and buy a live out cable(if you are too stupid/lazy to make one, like me) for the gopro. Basically plug and play.
The next step after that will be buying or building some CP antennas.
gundamnitpete is offline Find More Posts by gundamnitpete
Discussion Can you FPV on a budget of $500? (US) dalton1981 FPV Talk 11 Oct 17, 2012 01:06 PM
Question Can you hook up a GoPro to a transmitter and recieve in 1080p? Willanhanyard FPV Talk 11 Oct 16, 2012 10:09 AM
Question How Can I Hook Up the Included Nav Lights On my Plane? ClevelandBaller Electric Plane Talk 11 Aug 13, 2012 11:49 PM
Cool Catch me if you can!! UlteriorModem Life, The Universe, and Politics 7 Mar 20, 2012 10:43 AM
Discussion How many servos can you hook up to a 6 pin multiplex connecter? flyboy320 Electric Sailplanes 9 Mar 05, 2012 03:07 AM
