Jan 13, 2013, 06:21 PM
Blade MCPX $80.00 OBO not shipped in orig. box
Up for sale is my heavily used Blade MCPX V2. It is about a year old and has about 60 or 70 flights on it. I learned a lot on the heli so it has been crashed a lot. The canopy shows heavy signs of being crashed but is still in one piece. It comes with a Microheli Red X-Swash. I have glued another AR bracket on to the back of the frame so that the AR pin is at the back of the heli instead of pointing to the side. To me this makes it fly like it's a bigger helicopter. The landing gear are glued in place because the little nubs broke off and I am sick of buying landing gear because the little nubs break off and even though they are glued on they still break off. One of the canopy pins is broken off of the frame. The elevator servo was broken in a crash a while back so I replaced it with a servo from one of my airplanes, so it has the longer wire lead than the stock servo and it has some glue stuck to the wire that is wrapped around the tail boom that I didn't want to try and strip off for fear of stripping the coating off of the wires. The heli flies good, it's not perfect. I extended the battery wires because I hated stretching the wires when trying to fit batteries that are a little longer like the Nano-Tech's into the battery holder. The board works fine, it is the original V2 board that came with the heli when it was new. It has the new longer tail boom on it that probably should be replaced, but it still works.
Comes with the following extra parts.
Used stock Swash Plate
1 300 mah Nano-Tech Battery
1 NIP Set of KBDD Yellow Blades
1 NIP Set of Rotor Head Linkages
2 Used Sets of KBDD Yellow Blades
1 Set Used Bullet Blades
3 Stock Tail Blades
1 Instruction Manual
Will come shipped in it's original box.
I am asking $95.00 OBO Shipped to the CONUS. Paypal only please. I will also do $80.00 OBO Not shipped in original box.
I cannot stress enough that this MCPX has been used and has been crashed and it shows. It is being sold as is.
