Old Jan 19, 2013, 04:36 PM
haiduk is offline
Find More Posts by haiduk
Pronounced "High Duck"
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Texture Mapping
Hey Guys,
The major flight surfaces are all texture mapped. The parts are all labeled in the texture and display properly on the model. Still have the electronics left to texture map then to setup the pivots and hinges.
- Duk
haiduk is offline Find More Posts by haiduk
Old Jan 19, 2013, 09:41 PM
maxxnut is offline
Find More Posts by maxxnut
Hoarding balsa is a sickness
smokey point, wash.
Joined Dec 2003
Ok, now I have no idea what the 4ell you are doing ??? I better drop over soon.
maxxnut is offline Find More Posts by maxxnut
Old Jan 19, 2013, 11:24 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
It's all part of getting the model prepped for RealFlight. I've got it running in the Sim. I'm pretty happy with the flight characteristics so far. Should be very easy to make changes to the color scheme too.
Old Jan 20, 2013, 12:08 AM
No Step is online now
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
Very Cool!
No Step is online now Find More Posts by No Step
Old Jan 20, 2013, 02:05 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Prototype Stickersnee posted on the RealFlight swap
I finalized the sim model and posted it on the RealFlight Swap Pages. I also made a variant for streamer cut. One of the very cool things about RealFlight G5 is the multiplayer streamer combat! I will be posting a variant of the Stevens AeroModel Shaft 400 for streamer cut too. Time for some combat practice!
Basic 400 electric stick combat rules:
- power plant: 400 size brushless (2830 type)
- top speed in a dive: < 60mph
- wing area: < 350sq"
- AUW: 14-18 ounces
- Must have enough battery to fly for no less than the duration of the 5 minute heat.
RealFlight G5 Combat Models:
StickerSnee_EA
StickerSnee (streamer cut)_AV
Stevens AeroModel Shaft 400_EA
Stevens AeroModel Shaft 400 (streamer cut)_AV
Old Jan 20, 2013, 02:50 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Now I can get started designing the structure of this plane.
Old Jan 20, 2013, 03:14 PM
Willsonman is offline
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
Looking forward to progress.
Willsonman is offline Find More Posts by Willsonman
Old Jan 21, 2013, 11:31 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Came out great. Love the color scheme. Have fun!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jan 22, 2013, 01:13 AM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
I've been busy working out the wing structure. I cut a few parts in 3DS to verify fit. Found a couple issues so far. Will get those fixed before taking balsa to laser. Enough for tonight.
Old Jan 22, 2013, 06:06 AM
No Hangar Queens!
Maryland
Joined May 2009
I know the "I" beam method is quite srong but usually only if you are using heavier woods. You may find that simple balsa spars with shear webs between each rib will be lighter and stronger. Just my $0.02. Looking good though!
Old Jan 22, 2013, 10:19 AM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
put some "feet" at the rear of the ribs to give them something to rest on while building, preventing any warps.
Old Jan 22, 2013, 10:52 AM
No Hangar Queens!
Maryland
Joined May 2009
Yes, simple tabs that can be partially cut with the laser to break off once the wing is complete would be a good building help.
Old Jan 22, 2013, 05:00 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
I am planning on using rib jig tabs ("feet") top and bottom of each rib to aid the builder in keeping the wing straight. Thinking the tabs need to be on top and bottom because of the "D" tubes on the leading and trailing edges. Pretty important to keep the wing very straight when those are glued up.
I already have the shear web pieces drawn. The plan is to glue them in behind the inside spars. I just haven't fitted them in the 3D environment yet. I'll get to more part fitting this evening.
Take a look at what I have drawn for the Tip Rib.
Old Jan 22, 2013, 08:37 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Here is an example of why I'm designing this way.
I was laying out a sequence of renders to get a better idea of the build process. While I was taking "photos," I found a part that has the wrong shape. I would have wasted a sheet of balsa had I not found the oops in the 3D environment.
Also, the ribs in the renders still don't have their "feet." They should at this point.
I'll make the changes on the plans and re-import the parts to verify fit.
edit: removed a bunch of images
