Old Jan 13, 2013, 02:38 PM
haiduk is offline
Find More Posts by haiduk
Pronounced "High Duck"
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Build Log
Snickersnee design and build
Santa left us a new machine under the tree. A 40watt CO2 laser cutter! Our CnC router has a new cousin to keep it company in the shop. After setting it up we've done a few tests and it works wonderfully. The laser has more cutting power than I expected. Now I just need to design up a new plane to cut with the new laser cutter.
Back in the day, my dad designed a slow-combat control line that he called the Snickersnee. In his honor I want to design, laser cut, and build a 400 sized electric stick for r/c streamer combat. Since this will be a stick type design, I'm going with a variation of the third definition here:
snickˇerˇsnee (snkr-sn)
n.
1. A knife resembling a sword.
2.
Archaic The act of fighting with knives.
3. To Stick or Snee.
Pops original Snickersnee design was characterized by its diamond shaped wing tips and sharp corners. The slow-combat control line model looked very similar to this model I set up for the RealFlight simulator a while back:
My design process usually starts by drafting a simple scale drawing to import into 3DS Max so I can generate a 3D model for design testing in RealFlight. Once I'm happy with the shape and size of the flight surfaces and the handling in the sim I start designing the structure.
I will be keeping notes and documenting my design and build process in this thread...
EDIT (20Jan2013):
- added the prototype and streamer cut 3d models to the RealFlight Swap Pages
- StickerSnee_EA
- StickerSnee (streamer cut)_AV
EDIT (15Apr2013):
- added link to Haiduk Aeromodels
- posted full size PDF plans on www.haidukaero.com
NoStep's Maiden Flights:
NoStep SnickerSnee Maiden 4-22-2013 (5 min 57 sec)
First SnickerSnee combat NoStep vs. Haiduk:
P1060594 (6 min 0 sec)
haiduk is offline Find More Posts by haiduk
Old Jan 13, 2013, 03:07 PM
maxxnut is online now
Find More Posts by maxxnut
Hoarding balsa is a sickness
smokey point, wash.
Joined Dec 2003
I will be dropping by for a visit...with proper notice of course.
maxxnut is online now Find More Posts by maxxnut
Old Jan 13, 2013, 03:27 PM
dz1sfb is offline
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Duk,
Would you mind sharing what this laser setup costs? Santa might have to make a mid season delivery.
Ken
dz1sfb is offline Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Jan 13, 2013, 04:02 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
5th Generation Full Spectrum Laser
This laser setup is from Full Spectrum Laser. The laser unit has a base price of $3500, but you will also need a dry air compressor, a water pump (in a bucket of distilled water) for cooling, a filtering device, and a computer to drive it. It is quite an investment, but FSLaser does have a lower cost model that's under $2k as well.
5th Generation Full Spectrum Laser - base $3500
40W Basic Hobby Laser - base $1850
Old Jan 13, 2013, 06:11 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
3DS work - wings
RealFlight requires the wings of the model to have a left and a right main wing panel as well as a left and right aileron. They will also have to be set up with a specific hierarchy. More about that later.
Old Jan 13, 2013, 09:19 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Looking awsome already. The lazer is the bomb, congratulations. I'm now subscribed... . I'll be watching and wishing the best on a short learning curve. When you get some time on the lazer it would be interesting to know what the cost of run time is on the machine is at, per hour say.
Thank you for sharing your great new machine and process.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jan 13, 2013, 09:57 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Hey thanks Fred. I think a replacement laser tube is around $350. They say they last about 1,250-1,500 hours on average. Time will tell.
I did get some work done shaping the fuselage on the 3d model. Hopefully, I'll get some more work done tomorrow.
Old Jan 14, 2013, 01:48 AM
No Step is online now
Find More Posts by No Step
My hangar is,... "almost" full
No Step's Avatar
United States, WA, Marysville
Joined May 2003
Very cool! The ultimate tool for the discriminating scratch builder. This will be fun to watch. Good luck with it.
Fred
No Step is online now Find More Posts by No Step
Old Jan 14, 2013, 07:51 AM
madbomber is offline
Find More Posts by madbomber
Hatters gonna hat.
madbomber's Avatar
United States, CO, Denver
Joined Apr 2011
What software are you using to make the 3D model?
Also, subbed.
madbomber is offline Find More Posts by madbomber
Old Jan 14, 2013, 12:51 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Modelling the Outrunner
I'm using Autodesk 3ds Max 2010 to create the 3d model for RealFlight.
I took my drawings of a 400 sized outrunner (2830) that I am planning on using with this airplane and imported them into 3dsMax. I used a "Lathe" operation to make the motor parts and extruded the X-mount. Looks fairly convincing for a low-poly count 3d model.
All of the 3d images I've rendered so far have no textures mapped. They are still just basic random colors. I'll document the setting up of the texture map for color scheme after I get all of the 3d parts modeled.
Old Jan 14, 2013, 01:21 PM
smokey point, wash.
Joined Dec 2003
I think the fin should be a little taller
Old Jan 14, 2013, 04:25 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
I checked the area of the vertical stabilizer and it does seem a bit small at 9.5% of main wing area. Currently it's 5" tall. If I scale up the fin so it's a half-inch taller, the area of the fin would be boosted by a couple percent. More fin area will definitely help the bird track through corners with less adverse yaw.
We're still looking at the lines from a cosmetic point of view. I will know more about the flight characteristics with different sized flight surfaces while tweaking the flight model in RealFlight. This is just a basic initial model for verifying these things before committing to a final shape and before designing the parts of the structure.
Think it needs more than 11.5% total area?
Does it look better larger?
Old Jan 14, 2013, 04:40 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
[QUOTE=haiduk;23814360
Does it look better larger?[/QUOTE]
Looks wise, it looks good in either size. So... I would make it the larger size. The only thing to look out for is the shift rearward of the CG. That may not be an issue though.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Jan 14, 2013, 06:00 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Duk,
Many variables affect things like the vertical fin area. If you have a moment measured from the trailing edge to the hinge line on the horizontal of 1.8x to 2.4x the cord, you should have 13% area of the wing. Height is often derrived by similar formulas to get a fairly good 'look' to a design.
I have a great 2-3 page standard moments and area caculations sheet (from a book that probably dates back 50-60 years), but works out everytime. It was designed by model builders, for model builders and is quite simple to apply. If you want I can either scan and post here, email, or even snail mail you a copy, just let me know.
Fred
Old Jan 14, 2013, 07:09 PM
haiduk is offline
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Originally Posted by Freddie B View Post
Duk,
Fred, if you could scan and post that document, I would be grateful. Sounds like it would help out a lot.
I measured the moments to the hinge lines of the tail-feathers. The basic wing (without the ailerons) has a 7.5" chord. The distance between the aileron hinge line and tail hinge lines is 16.2". If I calculated it correctly, that would give a moment of 2.16.
Sounds like I should bump up the vertical fin to 13% of the wing area. Let me see what it looks like.
