Old Jan 13, 2013, 01:09 PM
oyibox is offline
Find More Posts by oyibox
Joined Jun 2011
"GPS for HK KK2.0" project
I'm thinking of a (arduino based?) GPS module to connect between Rx and KK2 inputs. Is it doable?
Any skilled guy to help developing GPS board and Firmware for KK2 ?
From where should i start for such a nice feature ?
tks
oyibox is offline Find More Posts by oyibox
Old Jan 13, 2013, 01:31 PM
supercoe is offline
Find More Posts by supercoe
Joined Dec 2010
Already exists:
http://www.kkmulticopter.kr/index.ht...Set2&id_no=115
supercoe is offline Find More Posts by supercoe
Old Jan 13, 2013, 01:37 PM
oyibox is offline
Joined Jun 2011
Originally Posted by supercoe View Post
Price: $229.00 $129.00 now but still pricey...
Old Jan 14, 2013, 04:42 PM
faccan is offline
Find More Posts by faccan
United States, CA, San Diego
Joined Jul 2012
Be ware, in the KK2.0 forum says that is not possible to conect this GPS board.
http://www.rcgroups.com/forums/showp...postcount=1242
faccan is offline Find More Posts by faccan
Old Feb 10, 2013, 09:14 PM
alwaysconfused is offline
Find More Posts by alwaysconfused
Joined Dec 2012
I never saw this GPS unit connecting to any kk2 board (with lcd)
I believe it must be in the other boards and not THAT particular board...
alwaysconfused is offline Find More Posts by alwaysconfused
Old Jun 07, 2013, 09:52 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
tks
I'm about to start to work on it.
Thinking to make two versions:
1 with 5883 magnetometer
1 without but less accurate
No baro, so alt-holding only via GPS altitude.
FrSky telemetry support
But I'm not thinking to make it open source
It is possible to connect the GPS to KK2.0 ... but it will need to rewrite most of the code ... so .. no point on it.
The feasible idea is:
Keep KK2.0 as it is.
Feed it via PPM from an external micro board that is connected to RX and to GPS ...
Simple and easy.
Main objective is enable basic missions, but mainly ... enable RTH
e_lm_70 is offline Find More Posts by e_lm_70
Old Jun 07, 2013, 10:07 AM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Good luck. It's lonely out there on your own.
Steveis is offline Find More Posts by Steveis
Old Aug 09, 2013, 02:52 PM
snooz is offline
Find More Posts by snooz
snooz's Avatar
France, PACA, Marseille
Joined Jan 2013
nice project (y) i would like to buy your system when it will works fine. i'm waiting for it now
snooz is offline Find More Posts by snooz
Old Aug 09, 2013, 03:05 PM
e_lm_70 is offline
Austria
Joined Jan 2004
Would be 19$ a fair price (price less GPS)
With GPS module 49$ ...
What you think ?
Old Aug 09, 2013, 03:21 PM
snooz is offline
snooz's Avatar
Joined Jan 2013
goooood price amazing
you will killing DJI's products ah ah ah
Old Aug 09, 2013, 03:26 PM
snooz is offline
snooz's Avatar
Joined Jan 2013
i prefer kk2.0 board at naza-M
dji naza-M have just a GPS system to make the difference... if kk2.0 board had a GPS system, DJi naza will be lost...
kk2.0 works better than naza without gps
Old Aug 09, 2013, 03:32 PM
e_lm_70 is offline
Austria
Joined Jan 2004
For sure not.
You know ... if you get s MultiWii pro board, that cost 50 or 65 with gps ... you get already a superior system to KK2.0 ... and in some aspect even better then DJI
DJI, so far has the best GPS holding and navigation ... but many open source code are getting to this level .. so far in ideal quad and ideal configuration
Still .. my +/- 1m GPS hold ( in all 3 dimensions) via 65$ multiwii pro with gps ... is good enough.
Anyhow , back to KK 2.0 ... this is a ultra easy to set up and fly control board
Adding GPS ... make sense only for ultra easy configuration, and an approximate accuracy ... let say .. mainly for panic RTH situation ... in a sense .. GPS hold is more complicated or less effective then RTH to be add on KK2.0
Old Aug 09, 2013, 03:42 PM
e_lm_70 is offline
Austria
Joined Jan 2004
In other words, without making a new board that control the KK2.0 board ... my idea is to have a simple board, connect to gps, with just a magnetometer on it ... this can do a decent job as RTH .. but it cant get anywhere near dji gps navigation
For get up tp dji navigation, the additional board connected to kk2.0 will need to be a replica of a full 10dof board ... unless .. HW chaanges on KK2.0 or firmware changes ... both approach that make no sense to me
At the moment I enjoying hacking navigation, on MultiWii 2.2 ... I may consider to try KK2.0 Return to Home rth on KK2.0 ...
I was more motivate on KK2.0 before I got the 3rd random behaviour from kk2.0 .. and on my last crash the kk2.0 lost 1 chip .. with the rest of the board totally un-hurt ... it did not get any impact on crash, but still a chip got desolder on his own ... so ... HW quality is not excellent ... and sometime strange things happen on KK2.0
So ... recent MultiWii 2.2 works spot on with default setting , as good or even better then KK2.0 ... a multiwii bord equivalent of kk2.0 ... cost 7$ shipped from eBay ... this is the killer board for me
Old Aug 09, 2013, 04:57 PM
snooz is offline
snooz's Avatar
Joined Jan 2013
i have a multiwii a naza-M, a freeflight and a kk5.5 blackboard
i had krashes with all board, cause firmwares fail or electronics fail...
no crashes with kk2.0 v1.5 → 1year crash safe.
same propellers since 6 month... last props since 1 year (and already clean and avaible to fly)... juste changing size and color
amazing kk2.0 bord
i fly over water many times and she never let me alone...
i have no RTH (of course) but i could always turnback home... many times with a default motor... when low battery, one motor stop on hexacopter and five motors run... i can fly with kk2.0 with one motor lost (not avaible for quadcopter of course )
Old Aug 11, 2013, 06:43 PM
snooz is offline
snooz's Avatar
Joined Jan 2013
i hope a GPS system for kk2.0 board one day... multiwii never work for me with hexcopter only quadcopter
so i ride this card to gimbal... multiwii is a very good open source system, but not perfect
Help! Tricopter and HK KK2.0 board - Tail servo jitter rcbif Multirotor Electronics 159 Jan 15, 2014 11:52 AM
Question V-Tail Quad copter with HK KK2.0 Multi-Rotor Control Board horst1903 Multirotor Electronics 3 Dec 16, 2012 11:14 AM
Discussion Hexcopter (Clone F550) project using KK2.0 board DYORD Multirotor Talk 1 Nov 12, 2012 07:22 PM
Discussion Tricopter talon HK + kk2.0 PID settings nocomp Multirotor Electronics 1 Sep 22, 2012 12:25 PM
Discussion ... Redemptioner Scratchbuilt Multirotors 4 Aug 12, 2012 08:18 PM
