Old Jan 24, 2013, 01:35 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
multimeter reads [.28] wot ~ is that right for a 6mm geared prop ~ if so than Im simply too heavy, if not than esc not a good solution.
elvill is offline Find More Posts by elvill
Old Jan 24, 2013, 01:54 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Disconnect motor and have the voltmeter go across the motor leads. It should read close to 4 volts @ WOT and vary with throttle down to zero volts at zero throttle.
If its only 3.5 volts @ WOT, there is your problem.
UNGN is offline Find More Posts by UNGN
Old Jan 24, 2013, 02:08 PM
scousethief is online now
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Hi were did you get that little soldering gun ?
scousethief is online now Find More Posts by scousethief
Old Jan 24, 2013, 02:42 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
Hobbyking, little gun heats faster than any plug in I've owned. very nice gun much safer.
I dont even get 3.5 WOT more like 3.29 - I guess therein lies the problem
Old Jan 24, 2013, 03:12 PM
PatricMichigan is online now
Find More Posts by PatricMichigan
PatricMichigan's Avatar
United States, MI, Hillsdale
Joined Apr 2008
I've never worked with those particular servos but in years past there was a really big loss going through the transistors in the old servos. Possible that a high end-high power servo might have better quality transistors but that kind of defeats the purpose of doing it inexpensively.
Patric
PatricMichigan is online now Find More Posts by PatricMichigan
Old Jan 24, 2013, 04:43 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Now for you next trick... put 2S to everything.
The servo boards and the RX should be able to take it.
Old Jan 24, 2013, 05:57 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
Interesting, didn't even think of that. I could harness two 1s 70mah together for little wright.
Edit: never heard of a 2s running brushed 6mm pager motors b4
Old Jan 25, 2013, 03:10 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
2S is the Answer!
Gives 50% more thrust than I could even use. Thanks UNGN. Now I have lots of room to play with the throttle and diff mixing and remove reverse entirely with bigger resistor!
Never seen 6mm gb push so hard! Motors wont last long so will have to dial back alot. Excited for these projects b/c now they are way more doable old school cheap! 9g cheapy boards easily push the 8.5 too.
try get a table video of the most powerful dual 6mm brushed plane ~ The Wright!
Old Jan 25, 2013, 03:59 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Dialing the WOT voltage back to 4.2V on the multimeter should make them last as long as any other 1S motor... You can also have a "War Emergency Power" mix that gave it an extra volt or two with a switch flick.
Old Jan 25, 2013, 04:33 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
Im a little weary of my multimeter. Tried testing the servo board as I did yesterday but this time on 2S, fried the rx instantly!
Dual 6mm Pager Motors pushed by 9g servos boards on 2S (0 min 42 sec)
motors hot after 75% throttle in vid,
Old Feb 06, 2013, 04:14 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
Finally got done with the small Wright flyer!
decided to bite the bullet and get the $9.99 esc. removed wires plug, mixing perfect. This thing flies so slow and sweet; graceful figure eights in the parking lot. Excellent plane! try to get flight video shouldn't be too hard. Happy with little dsm2 Wright!
verdict~ servo board as esc work but Diff thrust mixing with 2 servo boards as esc is a head ache to get perfect almost as if boards drift... oh well - Happy now! UNGN thanks for the mix -25 is what Im using (and its perfect).
Old Feb 06, 2013, 06:09 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
2minute flight ~ breeze hard to keep plane in frame
Wright Brothers Dsm2 diff thrust (0 min 38 sec)
mixing to -35%
Be perfect indoor as breeze does move it around.
Old Feb 06, 2013, 06:37 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
good job, love the cat trying to pounce on it
derk is offline Find More Posts by derk
Old Feb 06, 2013, 09:27 PM
sredlin is offline
Find More Posts by sredlin
My dog ate my airplane
United States, CA, San Diego
Joined Dec 2008
I just found this thread and was hoping the servo boards would work, as I have heard mention of using them as low wattage brushed ESCs before. My son has some toy 27 MHz directional thrust planes that I wouldn't mind trying to modify to use a real radio, although micro soldering is pretty tedious and challenging work. That's a nice little flight video you got though, good work.
sredlin is offline Find More Posts by sredlin
Old Feb 07, 2013, 07:46 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
hi sredlin, thanx
the servo/esc thing is not worth it, rx415 9$ and two $9 esc is almost as lite as any AH/AA/ITC diff thrust setup, can push bigger motors, heavier lipo and better prop, PLUS mixing these is cake compared to mixing servo boards.
THIS is the cheapest litest DSM2 micro brushed diff thrust setup imo
http://www.hobbyking.com/hobbyking/s...dProduct=11885
http://www.hobbyking.com/hobbyking/s..._Receiver.html
I tried 4 different servo boards from 1.9g to 30g servo, none come close to 1.5a continuously on 1s. These esc DX7 diff thrust mixing is easy and manageable, motors start up perfect and mixed every time.
Discussion Dual elevator setup with DX8 - use mix or program servos? Daedalus66 Radios 15 May 09, 2015 06:33 PM
Wright Brothers Decals - Antique Gold Letters GravyBones Non R/C Items (FS/W) 23 Jul 29, 2013 09:30 PM
Help! spektrum DX6I differential thrust program mix? ballores VTOLs 1 May 29, 2012 08:30 AM
Discussion dual aileron servos mixing question nitrosportman 3D / Fun Fly Fuel Planes 4 Mar 12, 2012 08:43 AM
Mini-HowTo Dual ESC's for Differential thrust rudder control UNGN Power Systems 29 Mar 10, 2012 04:18 PM
