Old Jan 12, 2013, 09:06 PM
SuperBarlow is offline
Find More Posts by SuperBarlow
No place like cloud base......
SuperBarlow's Avatar
United States, VT
Joined Aug 2012
AR6400 Challenge!
Ok- I'm challenging myself to build a micro model around an AR6400 (OR clone) for less than $40!
But first, I have to decide what plane to make.
I'm not looking for a nutball, but I want something I can really beat on, is fairly slow, but has power for a good strong climb (Low Wing Loading ). Scale is cool but not my thing.
Two questions- What should I make, and is there a sub $40 AR6400 clone?
SB
SuperBarlow is offline Find More Posts by SuperBarlow
Old Jan 12, 2013, 09:36 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
targethobby.com
25 shipped. slow, noisy and centering is iffy. but they have not failed me yet. DO NOT trim the antenna. (or so i ve been told )
can usualy find them on ebay for 35.
ar6400 offical usualy go for 15-25, or 35-45 with guts in here on RCG.com
nemoskull is offline Find More Posts by nemoskull
Old Jan 14, 2013, 07:51 AM
TedD60 is offline
Find More Posts by TedD60
Joined May 2012
Originally Posted by nemoskull View Post
ar6400 official usually go for 15-25, or 35-45 with guts in here on RCG.com
I'm sorry. I'm still playing catchup with a lot of terms that get used on this site. I didn't understand a lot of this sentence.
1. What is ar6400 "official"?
2. "With guts", which implies that the board is sold without "guts". What "guts" are missing one from another?
3. Where are these sales found on RCG.com?
Thankyou
TedD60 is offline Find More Posts by TedD60
Old Jan 14, 2013, 09:22 AM
United States, VT
Joined Aug 2012
There are the AR6400's and then there are the 3CH receiver type that comes with the Night Vapor, Champ, Etc.
Guts means motor, gearbox, battery, prop, extra linear actuators, Etc.
Sales are found in the classified section of the forums.
Old Jan 14, 2013, 11:19 PM
nemoskull's Avatar
Joined Sep 2009
there is the 'offical' spektrum ar640 that retails for 60.00
then there is teh targethobby.com brick the retails for 20.00 and is of questionable origin and lower (but seemingly, reliable) quality.
guts generally refer to ar6400, 1 external servo and 1 brushed motor and prop.
Old Jan 15, 2013, 12:30 PM
United States, VT
Joined Aug 2012
Sorry for the wait- I have to convince my parents to let me buy an AR6400 and motor, and then wait for one to pop up in the classifieds
Old Jan 15, 2013, 07:54 PM
nemoskull's Avatar
Joined Sep 2009
its better to buy used ar6400. they are pretty reliable.
Old Feb 09, 2013, 05:38 PM
United States, VT
Joined Aug 2012
Ok! Now I have some UM Sukhoi guts and I bought a second servo for it, so that puts me at $41. Guess it'll be the $45 dollar challenge now!
I decided to build the Axis V4 by Scott Neeman, (Here) as an attempt at a mild 3D plane. I'm not much of a 3D pilot yet, but that's why I want to make a 3D plane to practice on!
I printed out the plans taped them together, and had at it with a razor blade. I ended up with an airframe that was too heavy, so I took another shot at it and the second attempt was lighter. I'll take pictures soon.
Then I installed the Suk motor, and did a thrust test. I could hover at half throttle! Pretty good for a first attempt. I still have about 8 grams of weight to add with the two aileron servos and pushrods, but that's fine. I'm expecting the weight W/O battery to be about 36 grams, and weight with 160 MAH 1 Cell to be 40 g.
Wish me luck!
Old Feb 09, 2013, 08:43 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Good luck! looking forward to seeing your build. I've been thinking about building the V4 for a while now... But for brushless and 2S.
Here is my version of Scott's Axis (ver1?). I scaled the original plan down for the AR6400 and guts from the UM Suhkoi XP. The plane has 15" WS and only one servo for the ailerons. The weight was under 40g.
http://www.rcgroups.com/forums/showp...postcount=1954
My video.
Axis V3 F3P practice plane. (3 min 7 sec)
KC is offline Find More Posts by KC
Old Feb 09, 2013, 08:47 PM
miatamama is offline
Find More Posts by miatamama
miataman
miatamama's Avatar
Erie Pa.
Joined Oct 2007
You say nutball! I sdee you have decided but you can build either of these for 2 bucks + 6400 and motor. Nutball and my own design.
JCS
miatamama is offline Find More Posts by miatamama
Old Feb 09, 2013, 08:53 PM
United States, VT
Joined Aug 2012
KC,
That's Great! I hope mine turns out that good.
The WS on the V4 is 20" and the chord is a bit bigger, so I think that mine'll come out a little bit floatier, par the wing loading. The only thing is the weight- I might have to cut some holes.
How did you pull off the one servo aileron?
And brushless would be AWESOME! just maybe scale the plans up a bit?
Old Feb 09, 2013, 08:54 PM
United States, VT
Joined Aug 2012
Miatamama, something's wrong with your images- it won't let me view them?
EDIT-Wait, no they look fine now. That's the PI Yak that you posted in the AR6400 forum, isn't it?
I tried an elevon sumo first, scratch built from pictures by I R Irv, but it couldn't fly at all.
Old Feb 09, 2013, 08:59 PM
United States, VT
Joined Aug 2012
And what do you use for covering?
Old Feb 09, 2013, 09:14 PM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
The aileron set up is just like the stock setup in the Suhkoi... one aileron with the bell crank.
Old Feb 09, 2013, 09:20 PM
United States, VT
Joined Aug 2012
Ok. I bought the guts from a Suk XP, and never got to see the airframe, so I wouldn't know.
Discussion BLADE Micro Invitational Challenge tntangel The RCGroups.com ETOC 5 Apr 15, 2012 12:33 PM
Found AR6400 rx or crashed um with good AR6400 in it. rcbobcat55 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Nov 20, 2011 09:09 PM
Joke Vertically challenged... Weight challenged... Mentally challenged.. And now! zultone Humor 35 Sep 20, 2009 10:23 AM
Poll A.P. Challenge, Why not A.V. Challenge? darenm Aerial Photography 10 Aug 21, 2006 08:31 AM
