Joined Apr 2009
You can improve the situation a little once you have it trimmed out. Shim the fixed portion to be very slightly nose down, so that once retrimmed, it looks like it is flying with perhaps a degree of down elevator. That lessens the up elevator required compared to the native airfoil and will drop the drag slightly in tighter turns.
Gerald |
Tail Foill tables from CharleRiver ...
http://www.charlesriverrc.org/articl...t-airfoils.htm As Oleg stated, I've hinged many full flying stab foils and they work fine ! |
Joined Jan 2004
I really need a set of tail feathers - bagged hinged whatever - i have an xp4 kit that needs building - yes u read that correctly.... i guess the balsa stuff is worth upgrading ...is there someone on rcgroups that sells them? - i see them from time to time in the classifieds but man they last like 5 minutes ! spent a lot of time reading the single cell thread and topdrive servos is a new thing for me and i like that idea a lot (have seen Oleg's validol installation man that is sweet) ...
a lot has changed in my 5 yr absence - should be fun...sorry for the minor drift there |
| Thread Tools | |
| Discussion Robart Hinges vs Brass Tube/Piano Wire Hinge | Dirty Dee | The Builders Workshop | 7 | Dec 18, 2012 10:38 PM |
| Question can i use CA hinges instead of robart hinges on a 65" edge 540? | out of stock | 3D Flying | 2 | Mar 31, 2012 05:53 PM |
| Discussion Silicon Hinge on Elevator | edulago | Sailplane Talk | 23 | Mar 04, 2012 10:13 PM |
| Help! Hinges, hinges, hinges… | planefun | Scale Sailplanes | 11 | Jan 22, 2010 10:34 AM |
| Question Pinned Hinges VS Hinge Points VS CA Hinges? | bronicabill | The Builders Workshop | 35 | Sep 03, 2008 01:23 AM |
