Old Jan 28, 2013, 09:19 AM
R.M. Gellart is offline
Find More Posts by R.M. Gellart
R.M. Gellart's Avatar
Joined Nov 2005
Originally Posted by Wiker View Post
I donít know. I speak Norwegian, but that didnít help me much with that German video.
They all look the same to me, so I'm screwed, LOL!
Marc
R.M. Gellart is offline Find More Posts by R.M. Gellart
Old Jan 28, 2013, 09:29 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by satinet View Post
on the other hand the servo can also put force back in to the servo to cause it slide, which isn't what you want either.
I don't think that matters at all in RDS, Tom.
Only securing the servo radially is what matters. That and gear slop, and torsional stiffness in the wiper and shaft.
R,
Target
target is offline Find More Posts by target
Old Jan 28, 2013, 10:12 AM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
R,
Target
And bending stiffness of the shaft I'm looking forward to hearing the results.
djklein21 is offline Find More Posts by djklein21
Old Jan 28, 2013, 10:28 AM
Just flyy is offline
Find More Posts by Just flyy
Yep it's Phil!
Just flyy's Avatar
United States, CA, San Diego
Joined Apr 2007
Hey..
Can't the pocket shape be changed to facilitate the proper shaft position at each point in the range of motion (con vexed or con caved or whatever shape you want to control the movement)? I want my servo's to stay put! So, once the exact shape is determined, a CNC'd pocket can be made out of some tough light stuff and inserted into the pocket space and glued in. No more custom installs or moving parts to come loose and/or flutter... Just thinking!
Phil
Just flyy is offline Find More Posts by Just flyy
Old Jan 28, 2013, 06:08 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I don't follow you, Phil....
I'm not sure if you understand what the issue is...
The bend of the wiper ideally will stay centered over the hingeline. On a bottom hinged surface, that means the bend needs to be slightly forward of the hinge line with reflex, and aft of the hinge line with down travel.
Its not TOO big an issue with normal aileron travel.
But with flaps, it becomes advantageous for the bend to travel for and aft to stay in the proper location.
That's a simplistic explanation. There are a lot of other variables.
I hope that helps, and if I am missing your arrangement my apologies.
R,
Target
Old Jan 29, 2013, 09:59 AM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
So is the axially movable RDS frames offered by Ober one of the best solutions out there right now to keep the wiper bend over the hinge line? Are there any disadvantages to this design?
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Jan 29, 2013, 10:22 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I can tell you that one advantage should be ease of servo removal. Should make it super easy to get a servo out should you ever need to, you will have room to slide the servo back.
If it works as it is intended to, it should be an improvement. I would think it would help eliminate any tendancy to double center, and also allow more the power of the servo to actuate the surface, by allowing the wiper to be in the ideal spot.
R,
Target
Old Jan 29, 2013, 10:44 AM
glderguy is offline
Find More Posts by glderguy
4 wheels move a body; 2 a soul
Saratoga, Ca
Joined Feb 2004
Yes I too thought about servo access with this set up. We will know very soon here.
glderguy is offline Find More Posts by glderguy
Old Jan 29, 2013, 08:19 PM
RetoF3X is online now
Find More Posts by RetoF3X
F3B and F3K
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
Less complicated RDS frames that allow back movement of the servo for quick removal:
http://www.rcsolutions.ch/index.php?show=64
They work great, I successfully changed a servo during and it was really simple and quick.
However, a sliding servo mount for the flaps would be really great, especially for the flaps.
Reto
RetoF3X is online now Find More Posts by RetoF3X
Old Feb 02, 2013, 09:06 PM
F3B and F3K
RetoF3X's Avatar
Joined Mar 2009
Shimming slopy RDS pockets with u shaped stell sheet
Hi Gents
I have a new plane that had some slop on some surfaces and I located the problem to be wear in the pocket.
I had tried shimming with thin steel foil, but the inserts always worked their way back out when the RDS was actuated.
Then I had an idea. I completely uninstalled the RDS (i.e. removing the torque rod with the wiper). I then folded a thin steel foil into a U and pushed it into the pocket. I then tested if I can still push the wiper in (it was hard, but possible). Then I just reinstalled everything.
The U makes sure that the shimming always stays in the pocket, essentially the wiper keeps it in.
Worked like a charm and the RDS is again as tight as it gets.
Reto
Old Feb 02, 2013, 10:45 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Is there any downside to metal on metal in RDS?
R,
Target
Old Feb 10, 2013, 02:09 AM
glderguy is offline
Saratoga, Ca
Joined Feb 2004
Well my Ober sliding RDS are in. Im not home so havent seen em yet. Will start installing them in Needle this week.
Walter
Old Feb 10, 2013, 03:38 PM
Laurent31 is offline
Find More Posts by Laurent31
Toulouse , France
Joined Dec 2007
Sliding frame from Ober for MKS, in my Shooter :
http://www.f3news.fr/t320p210-une-ex...ite-le-shooter
Laurent31 is offline Find More Posts by Laurent31
Old Feb 10, 2013, 04:26 PM
glderguy is offline
Saratoga, Ca
Joined Feb 2004
Ober RDS Pics
New Ober RDS pics before install. I got two planes worth.
Old Feb 10, 2013, 04:27 PM
glderguy is offline
Saratoga, Ca
Joined Feb 2004
Couple more pics
Two more pics.
Discussion Brand New Freestyler 4 - LDS System David Olson Multi Task F3X 51 Jun 09, 2013 10:56 PM
Discussion LDS (Mormon) Timpanogus Temple, American Fork, Utah JONBOYLEMON Aerial Photography 2 Oct 09, 2007 11:15 AM
Discussion Are you LDS and do you fly on Sunday.. fly4fun Life, The Universe, and Politics 21 Jan 02, 2007 07:55 AM
Discussion The new LDS Temple California Condor Aerial Photography 16 Aug 20, 2006 07:45 PM
RDS vs. servocity? fprintf Thermal 8 Feb 20, 2005 06:44 PM
